Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 09-30-2012, 02:18 PM   #1
hapisok
crazier than a coconut
hapisok's Avatar
Drives: 2010 2SS/RS LS3
TIG, MIG or both?
looking to pickup a welder for my garage but can't decide between a tig or mig. i'd like to be able to weld both SS and aluminum. im not a welder, but gonna learn as i've got some projects that i want to do without paying an arm and a leg for somebody else to f* up. pro's and con's of working with them would be appreciated.
thanks
hapisok is offline   Reply With Quote
Old 09-30-2012, 08:14 PM   #2
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
What are you welding? Mig is for sure going to be more novice friendly.
JLE58 is offline   Reply With Quote
Old 09-30-2012, 08:32 PM   #3
AirManFL
Mid-Florida Camaro Club
AirManFL's Avatar
Drives: 2012 2SS/RS/M6 COTW 10/7/13
Mig is cheaper to use, easier to learn, messier welds, and throws a lot of sparks.
Tig is more expensive, harder to use, is cleaner, and makes much nicer welds.
Search Google for mig vs. tig and you'll find a ton of info out there.
Good luck.
Rob
AirManFL is offline   Reply With Quote
Old 09-30-2012, 09:24 PM   #4
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
You will need a spool gun for mig aluminum, tig is stronger cleaner but if you tig aluminum you'll need a variable machine TIG aluminum not too easy to do, just practice TIG is easy if you go mild steel a 7018 base,
Old 09-30-2012, 09:25 PM   #5
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
I just MIG'd in a O2 sensor took two minutes it is faster
Old 10-01-2012, 02:20 AM   #6
hapisok
hapisok's Avatar
thanks for the responses so far.
i've done some searches on google and i really like the look of TIG. im willing to put the time in to learn how to do it right for a nice clean finished look.
after taking headers in to have O2 bungs welded on and exhaust systems, if i had bought one and learned how to do it, investing in a welder would have paid for itself already. i'll be welding up my header/exhaust system which is SS and some other projects which are aluminum.
thanks again.
Old 10-01-2012, 05:17 AM   #7
CFD
Drives: 2SS/RS L99 BLACK
There are a few things to consider. Tig welding is the cleanest of all welding and can eaily be changed to weld various metals with the flick of a switch. Mig welding is most common in most production shops as it is easy to learn and very versitile. Mig welding requires one hand operation, tig requires two as well as a foot or hand switch for temperature control. Personally, I prefer Tig welding but on occasion I use my mig welder but it is a rarety, the welds do not compare with Tig.
CFD is offline   Reply With Quote
Old 10-01-2012, 05:48 AM   #8
hapisok
hapisok's Avatar
PERFECT! just what i was looking for.
thanks!
Old 10-14-2012, 12:11 AM   #9
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
If you get a source to run GTAW (tig)and it is versatile, you should be able to also use it for GMAW (mig) and FCAW (flux core or dual shield). Dual shield with 75% argon, 25% CO2 is also very clean other than the slag produced but nice weld.
Aluminum tig will take a lot of practice and your parts must be absolutely clean. I've welded all my life and am now an AWS Certified Welding Inspector. If you have never welded I would recommend (mig). Either way, aluminum will require more expensive 100% argon or even more expensive tri mix. Mig can use relatively cheap CO2 for gas coverage.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 10-14-2012, 02:06 AM   #10
NicKey
Drives: Nickey Super Camaro
We use both at the shop, but the tig welder gets used most often.
It will generally require much more skill than a mig.
It is generally more expensive to purchase and operate.
Generally generates less heat and more concentrated heat onto the parts being welded.
Proper welds with both will be less obtrusive with a tig.
Mig can be much faster in some types of projects.
If I could only have one welder it would be a tig.
NicKey is offline   Reply With Quote
Old 10-15-2012, 12:15 PM   #11
GlennP
Drives: 2011 Camaro 2SS
Tig is much better but more difficult.
I'm certified to do unlimited thickness welding on MIG (like, bridge welds) but I cant even make stuff stick together with tig. Im sure if I tired for more than 20 minutes I can get better but its definately not a cake walk.
GlennP is offline   Reply With Quote
Old 10-15-2012, 01:31 PM   #12
hapisok
hapisok's Avatar
fair enough, and i appreciate all the input. i do like the pretty welds of tig. and seeing how all i've got is time and im learning then it looks like i'll get a dual setup so i can effectively use one and learn the other once i've got it down. only way to get better is by doing.
Old 10-15-2012, 03:00 PM   #13
SC2150
Tig for sure.
Also, can refer you to some good units for reasonable that you will love. Take the time to learn and you will be amazed at what you can do, and make sure the tig you get is both AC & DC to do both Aluminum and steel.
Old 10-15-2012, 06:30 PM   #14
Jason@JacFab
Jason@JacFab's Avatar
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
I enjoy TIG welding much more than MIG... I've got both here at the shop, and TIG just seems more fun. It can be hard(er) to learn though, however some people can just pick up the torch and run with it... A lot of hand/eye/foot coordination going on.
I'd say the best thing about MIG is it's waaay faster that's for sure.
Jason@JacFab is offline   Reply With Quote
