BORLA
Old 09-30-2012, 08:09 PM   #1
indper
Drives: Toyota Supra
Stock ZL1 to modified ZL1 with datalogs and dyno sheets
I want to start off by saying I love this car I figured I would share some of our data with everyone here. Maybe it will help others and make it an interesting read for the others. I'm going to post Uncorrected, SAE and STD dyno sheets for both stock and modified. I should be posting some of the modified dyno sheets Tuesday. We're installing Kooks headers with high flow cats, Airair cold air intake, D3PE 2012+ Camaro ZL1 AfterCooler Upgrade Kit, smaller sc pulley and IP calibration tune.
- Stock 09/28/2012
09/28/12
2:53:43PM EST
3rd Gear
100.40 Degrees F
29.76 in-Hg
23% Humidity
1.02 SAE
1800RPM START
194 Degree F START COOLANT TEMP
93 Degree F 104 Degree F START AIR TEMPS
6100RPM STOP
192 Degree F STOP COOLANT TEMP
101 Degree F 113 Degree F STOP AIR TEMPS
09/28/12
2:53:43PM EST
3rd Gear
100.40 Degrees F
29.76 in-Hg
23% Humidity
1.04 STD
1800RPM START
6100RPM STOP
09/28/12
2:53:43PM EST
3rd Gear
100.40 Degrees F
29.76 in-Hg
23% Humidity
1.00 UNCORRECTED
1800RPM START
6100RPM STOP
09/28/12
2:54:49PM EST
4th Gear
100.45 Degrees F
29.76 in-Hg
24% Humidity
1.02 SAE
1800RPM START
192 Degree F START COOLANT TEMP
95 Degree F 109 Degree F START AIR TEMPS
6100RPM STOP
110 Degree F 124 Degree F STOP AIR TEMPS
09/28/12
2:54:49PM EST
4th Gear
100.45 Degrees F
29.76 in-Hg
24% Humidity
1.04 STD
1800RPM START
6100RPM STOP
09/28/12
2:54:49PM EST
4th Gear
100.45 Degrees F
29.76 in-Hg
24% Humidity
1.00 UNCORRECTED
1800RPM START
6100RPM STOP
09/28/12
2:56:10PM EST
3rd Gear
100.42 Degrees F
29.76 in-Hg
24% Humidity
1.02 STD
1800RPM START
201 Degree F START COOLANT TEMP
99 Degree F 115 Degree F START AIR TEMPS
6100RPM STOP
201 Degree F STOP COOLANT TEMP
112 Degree F 124 Degree F STOP AIR TEMPS
09/28/12
2:56:10PM EST
3rd Gear
100.42 Degrees F
29.76 in-Hg
24% Humidity
1.04 STD
1800RPM START
6100RPM STOP
09/28/12
2:56:10PM EST
3rd Gear
100.42 Degrees F
29.76 in-Hg
24% Humidity
1.00 UNCORRECTED
1800RPM START
6100RPM STOP
09/28/12
2:57:38PM EST
4th Gear
100.61 Degrees F
29.76 in-Hg
24% Humidity
1.02 SAE
1800RPM START
210 Degree F START COOLANT TEMP
104 Degree F 121 Degree F START AIR TEMPS
6100RPM STOP
210 Degree F STOP COOLANT TEMP
115 Degree F 131 Degree F STOP AIR TEMPS
09/28/12
2:57:38PM EST
4th Gear
100.61 Degrees F
29.76 in-Hg
24% Humidity
1.04 STD
1800RPM START
6100RPM STOP
09/28/12
2:57:38PM EST
4th Gear
100.61 Degrees F
29.76 in-Hg
24% Humidity
1.00 UNCORRECTED
1800RPM START
6100RPM STOP
RunFile005
09/28/12
3:04:19PM EST
3rd and 4th Gear
101.10 Degrees F
29.76 in-Hg
23% Humidity
1.02 SAE
1800RPM START
196 Degree F START COOLANT TEMP
108 Degree F 121 Degree F START AIR TEMPS
6100RPM STOP
199 Degree F STOP COOLANT TEMP
115 Degree F 135 Degree F STOP AIR TEMPS
RunFile006
09/28/12
3:06:17PM EST
3rd and 4th Gear
101.15 Degrees F
29.76 in-Hg
23% Humidity
1.02 SAE
1800RPM START
216 Degree F START COOLANT TEMP
108 Degree F 126 Degree F START AIR TEMPS
6100RPM STOP
221 Degree F STOP COOLANT TEMP
119 Degree F 142 Degree F STOP AIR TEMPS
RunFile005
09/28/12
3:04:19PM EST
3rd and 4th Gear
101.10 Degrees F
29.76 in-Hg
23% Humidity
1.04 STD
1800RPM START
6100RPM STOP
RunFile006
09/28/12
3:06:17PM EST
3rd and 4th Gear
101.15 Degrees F
29.76 in-Hg
23% Humidity
1.04 STD
1800RPM START
6100RPM STOP
RunFile005
09/28/12
3:04:19PM EST
3rd and 4th Gear
101.10 Degrees F
29.76 in-Hg
23% Humidity
1.00 UNCORRECTED
1800RPM START
6100RPM STOP
RunFile006
09/28/12
3:06:17PM EST
3rd and 4th Gear
101.15 Degrees F
29.76 in-Hg
23% Humidity
1.00 UNCORRECTED
1800RPM START
6100RPM STOP
indper is offline   Reply With Quote
Old 09-30-2012, 08:10 PM   #2
indper
A few pictures
Old 09-30-2012, 08:16 PM   #3
blackcam2ss
Drives: 2013 ZL1 #659
Could not ask for a better group of guys working on my ZL1, I would recommend to anyone that is looking for a shop who is very attentive to detail and performs top notch work! Can't wait to see the end result !!
Order# QKTDRT
2013 ZL1
Ashen Gray
blackcam2ss is offline   Reply With Quote
Old 09-30-2012, 09:10 PM   #4
blackcam2ss
Quick video I made with my phone more to come soon
Order# QKTDRT
2013 ZL1
Ashen Gray
Old 10-01-2012, 09:44 AM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
This thread has a lot of potential. I like seeing all the data posted. Keep up the GREAT work!
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 10-01-2012, 09:59 AM   #6
sammyv
sammyv's Avatar
Drives: 2013 red Lingenfelter ZL1
Curious, why some runs in 3rd gear and some in 4th? Thanks!
sammyv is offline   Reply With Quote
Old 10-01-2012, 10:34 AM   #7
indper
I love data and I know others on the internet do as well. This is why I post all the data and will continue to
The owner and others wanted to see wheel horsepower in third gear and fourth gear. At the same time it was also to help induce heat soak.
Old 10-01-2012, 12:22 PM   #8
tnspd
tnspd's Avatar
Drives: 18 Camaro ZL1 1LE (WILSON)
All the data looks like it indicates Torque starts dropping at 4500 rpm in 3rd and 4th gear unless I read it wrong.
tnspd is offline   Reply With Quote
Old 10-01-2012, 10:54 PM   #9
indper
Correct
Old 10-01-2012, 11:00 PM   #10
blackcam2ss
Headers and intake baseline pulls were done today, nice gains with just boltons !!!
Order# QKTDRT
2013 ZL1
Ashen Gray
Old 10-01-2012, 11:04 PM   #11
indper
Round two is finished. We installed Kooks headers, Kooks high flow cats and Airair cold air intake. One thing the dyno sheets will not show. The car feels much better accelerating partial throttle. Tomorrow we will install the smaller pulley. Dyno. Install the aftercooler kit. Dyno. Then finally set it up with an IP calibration tune.
Old 10-01-2012, 11:24 PM   #12
indper
- Kooks headers, Kooks high flow cats and Airair cold air intake 10/01/2012
A lot of time and work going through, editing and posting all this data. Hopefully this helps some people
10/01/12
4:20:09PM EST
3rd Gear
97.36 Degrees F
29.52 in-Hg
30% Humidity
1.03 SAE
1800RPM START
189 Degree F START COOLANT TEMP
93 Degree F 95 Degree F START AIR TEMPS
6100RPM STOP
190 Degree F STOP COOLANT TEMP
99 Degree F 110 Degree F STOP AIR TEMPS
10/01/12
4:20:09PM EST
3rd Gear
97.36 Degrees F
29.52 in-Hg
30% Humidity
1.00 Uncorrected
1800RPM START
6100RPM STOP
10/01/12
4:20:09PM EST
3rd Gear
97.36 Degrees F
29.52 in-Hg
30% Humidity
1.05 STD
1800RPM START
6100RPM STOP
10/01/12
437PM EST
4th Gear
97.84 Degrees F
29.53 in-Hg
29% Humidity
1.03 SAE
1800RPM START
97 Degree F 100 Degree F START AIR TEMPS
6100RPM STOP
196 Degree F STOP COOLANT TEMP
108 Degree F 121 Degree F STOP AIR TEMPS
10/01/12
437PM EST
4th Gear
97.84 Degrees F
29.53 in-Hg
29% Humidity
1.05 STD
1800RPM START
6100RPM STOP
10/01/12
437PM EST
4th Gear
97.84 Degrees F
29.53 in-Hg
29% Humidity
1.00 Uncorrected
1800RPM START
6100RPM STOP
10/01/12
4:27:16PM EST
3rd and 4th Gear
98.64 Degrees F
29.53 in-Hg
29% Humidity
1.05 STD
1800RPM START
207 Degree F START COOLANT TEMP
99 Degree F 106 Degree F START AIR TEMPS
6100RPM STOP
212 Degree F STOP COOLANT TEMP
110 Degree F 126 Degree F STOP AIR TEMPS
10/01/12
4:27:16PM EST
3rd and 4th Gear
98.64 Degrees F
29.53 in-Hg
29% Humidity
1.03 SAE
1800RPM START
6100RPM STOP
10/01/12
4:27:16PM EST
3rd and 4th Gear
98.64 Degrees F
29.53 in-Hg
29% Humidity
1.00 Uncorrected
1800RPM START
6100RPM STOP
10/01/12
5:04:32PM EST
3rd Gear
102.49 Degrees F
29.52 in-Hg
25% Humidity
1.06 STD
1900RPM START
95 Degree F 108 Degree F START AIR TEMPS
6100RPM STOP
101 Degree F 122 Degree F STOP AIR TEMPS
10/01/12
5:04:32PM EST
3rd Gear
102.49 Degrees F
29.52 in-Hg
25% Humidity
1.00 Uncorrected
1900RPM START
6100RPM STOP
194 Degree F STOP COOLANT TEMP
111 Degree F 122 Degree F STOP AIR TEMPS
10/01/12
5:04:32PM EST
3rd Gear
102.49 Degrees F
29.52 in-Hg
25% Humidity
1.04 SAE
1900RPM START
6100RPM STOP
10/01/12
5:05:37PM EST
4th Gear
102.52 Degrees F
29.53 in-Hg
25% Humidity
1.00 Uncorrected
1800RPM START
203 Degree F START COOLANT TEMP
97 Degree F 115 Degree F START AIR TEMPS
6100RPM STOP
207 Degree F STOP COOLANT TEMP
108 Degree F 133 Degree F STOP AIR TEMPS
10/01/12
5:05:37PM EST
4th Gear
102.52 Degrees F
29.53 in-Hg
25% Humidity
1.04 SAE
1800RPM START
6100RPM STOP
10/01/12
5:05:37PM EST
4th Gear
102.52 Degrees F
29.53 in-Hg
25% Humidity
1.06 STD
1800RPM START
6100RPM STOP
10/01/12
5:09:02PM EST
3rd and 4th Gear
102.71 Degrees F
29.52 in-Hg
25% Humidity
1.04 SAE
1800RPM START
104 Degree F 111 Degree F START AIR TEMPS
6100RPM STOP
198 Degree F STOP COOLANT TEMP
110 Degree F 133 Degree F STOP AIR TEMPS
10/01/12
5:09:02PM EST
3rd and 4th Gear
102.71 Degrees F
29.52 in-Hg
25% Humidity
1.06 STD
1800RPM START
6100RPM STOP
10/01/12
5:09:02PM EST
3rd and 4th Gear
102.71 Degrees F
29.52 in-Hg
25% Humidity
1.00 Uncorrected
1800RPM START
6100RPM STOP
RunFile001 BLUE
10/01/12
4:20:09PM EST
3rd Gear
97.36 Degrees F
29.52 in-Hg
30% Humidity
1.03 SAE
1800RPM START
6100RPM STOP
RunFile001 RED
09/28/12
2:53:43PM EST
3rd Gear
100.40 Degrees F
29.76 in-Hg
23% Humidity
1.02 SAE
1800RPM START
6100RPM STOP
RunFile001 BLUE
10/01/12
4:20:09PM EST
3rd Gear
97.36 Degrees F
29.52 in-Hg
30% Humidity
1.00 Uncorrected
1800RPM START
6100RPM STOP
RunFile001 RED
09/28/12
2:53:43PM EST
3rd Gear
100.40 Degrees F
29.76 in-Hg
23% Humidity
1.00 Uncorrected
1800RPM START
6100RPM STOP
RunFile001 BLUE
10/01/12
4:20:09PM EST
3rd Gear
97.36 Degrees F
29.52 in-Hg
30% Humidity
1.05 STD
1800RPM START
6100RPM STOP
RunFile001 RED
09/28/12
2:53:43PM EST
3rd Gear
100.40 Degrees F
29.76 in-Hg
23% Humidity
1.04 STD
1800RPM START
6100RPM STOP
RunFile003 BLUE
10/01/12
4:27:16PM EST
3rd and 4th Gear
98.64 Degrees F
29.53 in-Hg
29% Humidity
1.05 STD
1800RPM START
6100RPM STOP
RunFile005 RED
09/28/12
3:04:19PM EST
3rd and 4th Gear
101.10 Degrees F
29.76 in-Hg
23% Humidity
1.04 STD
1800RPM START
6100RPM STOP
RunFile003 BLUE
10/01/12
4:27:16PM EST
3rd and 4th Gear
98.64 Degrees F
29.53 in-Hg
29% Humidity
1.03 SAE
1800RPM START
6100RPM STOP
RunFile005 RED
09/28/12
3:04:19PM EST
3rd and 4th Gear
101.10 Degrees F
29.76 in-Hg
23% Humidity
1.02 SAE
1800RPM START
6100RPM STOP
RunFile003 BLUE
10/01/12
4:27:16PM EST
3rd and 4th Gear
98.64 Degrees F
29.53 in-Hg
29% Humidity
1.00 Uncorrected
1800RPM START
6100RPM STOP
RunFile005 RED
09/28/12
3:04:19PM EST
3rd and 4th Gear
101.10 Degrees F
29.76 in-Hg
23% Humidity
1.00 Uncorrected
1800RPM START
6100RPM STOP
RunFile002 BLUE
10/01/12
437PM EST
4th Gear
97.84 Degrees F
29.53 in-Hg
29% Humidity
1.03 SAE
1800RPM START
6100RPM STOP
RunFile002 RED
09/28/12
2:54:49PM EST
4th Gear
100.45 Degrees F
29.76 in-Hg
24% Humidity
1.02 SAE
1800RPM START
6100RPM STOP
RunFile002 BLUE
10/01/12
437PM EST
4th Gear
97.84 Degrees F
29.53 in-Hg
29% Humidity
1.00 Uncorrected
1800RPM START
6100RPM STOP
RunFile002 RED
09/28/12
2:54:49PM EST
4th Gear
100.45 Degrees F
29.76 in-Hg
24% Humidity
1.00 Uncorrected
1800RPM START
6100RPM STOP
RunFile002 BLUE
10/01/12
437PM EST
4th Gear
97.84 Degrees F
29.53 in-Hg
29% Humidity
1.05 STD
1800RPM START
6100RPM STOP
RunFile002 RED
09/28/12
2:54:49PM EST
4th Gear
100.45 Degrees F
29.76 in-Hg
24% Humidity
1.04 STD
1800RPM START
6100RPM STOP
Old 10-02-2012, 08:56 PM   #13
indper
I may not be able to posts the dyno sheets and data until next week. So I am posting a quick update. 590whp @ 12.5lbs heatsoaked without the aftercooler.
Old 10-02-2012, 10:36 PM   #14
blackcam2ss
The car sounded so amazing, can't wait to drive it!!!
Order# QKTDRT
2013 ZL1
Ashen Gray
