BeckyD @ James Martin Chevy
Old 10-01-2012, 11:58 AM   #1
dsmcfarland
Drives: 2013 ZL1
Anyone having awful grinding sounds when making sharp turns??
I noticed the other day while going around a round about that I heard a grinding sound or scrape. Instantly I thought I hit something and screwed my front end. After looking it over there was no noticeable damages and I shrugged it off. Later that afternoon I heard it again on a sharp left turn. I immediately took it to the closest empty parking lot and did figure 8s and sure enough about every turn and a half I hear a grinding sound.
I took the car to the dealership to have it checked out and they heard it aswell and ordered replacement fluid for the stabletrack system. Just curious if anyone else has experienced it and what the dealerships have said or done to fix it?
She's a 2013 zl1 automatic for reference.
dsmcfarland is offline   Reply With Quote
Old 10-01-2012, 12:04 PM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
sounds like the clutches in the rear "posi" unit. The clutches are very aggressive in the ZL1 and will moan and growl when making tight turns. The fluid swap should fix it. They must use a specific fluid for the ZL1.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 10-01-2012, 12:08 PM   #3
dsmcfarland
Drives: 2013 ZL1
That makes me feel better. It sounds like its coming from the front end but really hard to tell. Any issues diving it this way until I get the fluid swap?
Old 10-01-2012, 12:11 PM   #4
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
The 5th Gen differential uses a GM slip additive. My guess is they are going to add more slip additive. I wouldn't spend the day at a road course or drag strip but see no reason why you can't drive normally.
Old 10-01-2012, 12:25 PM   #5
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
I appreciate what you guys are saying about the rear end, but what does that have to do with stabiltrack. Also what fluid would the stabiltrack use that would need to be changed. I thought the stabiltrack worked off the brake system.
Old 10-01-2012, 01:39 PM   #6
dsmcfarland
Drives: 2013 ZL1
I just asked the dealership exactly what they were doing so I can clarify here. They are infact adding the gm LS gear oil. I must have heard wrong when they mentioned the stabletrack
Old 10-01-2012, 02:59 PM   #7
Chevrolet Customer Svc
Drives: GM Vehicles
Please let us know how the service goes. We are here at your convenience!
Brandon
Chevrolet Customer Service
Old 10-01-2012, 03:00 PM   #8
JusticePete
Brandon
Old 10-01-2012, 03:18 PM   #9
littlecammi
littlecammi's Avatar
Drives: '87 Pontiac Fiero GT
Anyone hearing awful grinding sounds when making sharp turns?
Yes, but not coming from the car. I just figured its because I'm getting older.
littlecammi is offline   Reply With Quote
Old 10-01-2012, 04:24 PM   #10
DRKS1D3
DRKS1D3's Avatar
Drives: 2011 Camaro SS Convertible LS3
Did the goofballs at the dealer remove the shipping blocks from the suspension?
MY RIDE: 2011 TRIPLE BLACK SS CONVERTIBLE (BOUGHT NEW 4-2011)--6 SPEED MANUAL, K&N TYPHOON INTAKE, FLOWMASTER FORCE II MUFFLERS, HOTCHKIS SUSPENSION, BLACKED OUT BOWTIES, GLOSS BLACK 20x9 STYLE 41 WHEELS, 285-35-20 GOODYEAR EAGLE SUPERCAR G2'S, JBA HIGH-FLOW CATS, BBK HEADERS, LUNATI CUSTOM GRIND CAM: 227/235 .619/.626 114 +3
DAD'S RIDE: 2012 ZL1 #1866 (BOUGHT NEW 6-2012)--BLACK, 6 SPEED, EXPOSED CF HOOD, POLISHED WHEELS, SUNROOF, ROTO-FAB INTAKE
"Silly Americans, taking from the rich and giving to the poor only works in fairy tales. Success is earned here!".
DRKS1D3 is offline   Reply With Quote
Old 10-01-2012, 05:46 PM   #11
68vert
68vert's Avatar
Drives: 2010 SIM SS/RS, 1968 RS convertible
The rear end clutch's usually produce more of a mild thumping while turning as they are trying to grab. You can tell it is coming from the rear. A grinding noise sounds like something else.
2010 SIM SS/RS see garage for mods
68vert is offline   Reply With Quote
Old 10-03-2012, 09:06 AM   #12
whitetiger2474
Drives: 2012 Inferno Orange ZL1
Thumping Noise
I've noticed mine only tends to do this on colder days.
whitetiger2474 is offline   Reply With Quote
Old 10-03-2012, 09:21 AM   #13
STINGER BEE
2010RS/SS RUMBLEBEE
STINGER BEE's Avatar
Drives: Drives a 2010 2SS/RS Camaro
I had a similar problem,when turning out of a driveway etc.,I thought it was the brakes grinding at first. the dealer acknowledge the problem and installed a GM additive( I think there was a TSB out on it.) and I haven't heard it since.Not sure how long it will last or is this some sort of a yearly maintenance thing to replace rear axle fluid.
2010RS/SS RUMBLEBEE
STINGER BEE is offline   Reply With Quote
Old 10-03-2012, 09:37 AM   #14
htron50
htron50's Avatar
Drives: 2017 ZL1 Status "Thank You!"
What are "those in the know" thoughts about using Royal Purple 75W-90 WITH FRICTION ADDITIVE upc Code 01300 in these differentials?
htron50 is offline   Reply With Quote
