ADM PERFORMANCE
Old 10-01-2012, 01:53 PM   #1
stt816
Drives: 2012 Black 2SS/RS M6
Angry Scratches on my ZL1 Bumper
I woke up in the morning to my car with all white across the bumper. I don't know what happened.... It came off, but what was behind it was not good. It had little scratches, I tried to get it out with rubbing compound but i think i rubbed TOO hard and think i made it worse. Can a body shop fix this without spraying the whole thing over again? Or is there anything I can do myself to get rid of the marks or make it less noticeable? I put some touch up paint on the chips but doesn't look to great.... Thanks
Pfadt Race Engineering 1.25" Lowering Springs| Pfadt Spec Performance Street Alignment|ZL1 Front Bumper Conversion|Factory Reproductions Type 41 Satin 20x9 Rims|Pirelli P Zero All Season Plus 275/40R20Y Square Setup|3M 1080 Matte Black Vinyl Wrapped Hood|Footwell Lighting|G2 Gold Painted Brake Calipers
Stainless Power Long Tube Headers|Cold Air Inductions Cold Air Intake|VMAX CNC Spiral Ported Throttle Body|Stainless Works Retro Chambered Catback
--Jannetty Racing Enterprises Dyno Tuned|408 RWHP
stt816 is offline   Reply With Quote
Old 10-01-2012, 01:56 PM   #2
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Is that missing paint? If so, no, it need to be painted. The scratches can be buffed out.
Next time post here FIRST. Clay instead of compound probably would've saved you what's going to be a $500 repair.
[B]
Old 10-01-2012, 02:08 PM   #3
01pewterz28
Camaro Junkie
01pewterz28's Avatar
The ones on the face of the bumper should come out they will need to be wet sanded it looks like paint missing on the edges if so re-paint figure $250-$350
**FIFTY HBM 2SS VERT**
Old 10-01-2012, 02:17 PM   #4
stt816
not worried about the chips in the paint as they are not AS noticeable as the scratch marks on the face of the bumper. Should I do anything to get those out or should I bring it to someone?
Old 10-01-2012, 03:12 PM   #5
L99
L99's Avatar
Drives: B On B L99/SS2 Ground effects
You can buff it out but I would try using McGuire's swirl remover if the scratches are not too deep
2010 L99 Black on Black W/Ground effects
Mods: Kenne Bell, LS3 Conversion, LS9 cam,
BMR Stage 2
L99 is offline   Reply With Quote
Old 10-01-2012, 04:36 PM   #6
jimmy5
jimmy5's Avatar
Drives: 2012 ZL1 #450
It's missing paint on the edge line. You can buff the scratches out, but you will not be able to fix the marred paint.
jimmy5 is offline   Reply With Quote
Old 10-01-2012, 04:53 PM   #7
01pewterz28
Camaro Junkie
the only way to get the scratches is with a buffer if you have one some Adams you can knock that out.
Old 10-01-2012, 05:02 PM   #8
WiSSDiver
WiSSDiver's Avatar
Drives: 1968 Coupe, 2010 2SS, 2011 2SS/RS
If you have machine (PC or Flex) you might be able to get most of that out. If you don't have one or are uncomfortable using one, you might be spending some time at a local bodyshop having them do it.
WiSSDiver is offline   Reply With Quote
Old 10-01-2012, 05:13 PM   #9
LIM3
it's mind bottling..
LIM3's Avatar
Drives: SGM
A compound ? Dude...
Old 10-01-2012, 07:29 PM   #10
jameslk55
jameslk55's Avatar
Drives: 2012 2LT/RS, 2005 SLK55 AMG
This thread makes me think of this other thread:
micro scratches in clear coat
www.camaro5.com/forums/showthread.php?t=251673
I always try to use a clay bar first. Most body shops will probably say that the whole thing needs to be repainted.
jameslk55 is offline   Reply With Quote
Old 10-01-2012, 08:30 PM   #11
CyberBri
BRUCE WAYNES DD
CyberBri's Avatar
Drives: 2010 2SS/RS CGM
looks like some one backed into u...
JBA 1 7/8 LT`s, High flow mids, and Cat back,Airaid intake, JRE Tune, & alot of flat black....
CyberBri is offline   Reply With Quote
Old 10-01-2012, 08:53 PM   #12
Kiss My SS
Drives: 2012 Camaro 1SS/RS
Damn dude looks like you used sandpaper on your front bumper, WTF?
Kiss My SS is offline   Reply With Quote
