HURST
Old 10-01-2012, 06:59 PM   #1
sting808
Drives: 2010 SS RS
Tuning radiator coolant fan
I'd like some clarification on tuning Gen5 Camaro fans. I remember an old thread about fan control saying only Vettes used PWM. It was cited that Gen5 Camaro is either on or off. Fan operations was determined by a % threshold for on/off states. My fan does not turn on at 192*. I have a DeWitt radiator with the stock stat and can see peaks above 215 in traffic and wait times between Solo heats. I know the lowest temp to turn on the fan is 192 for OE systems. Would be great to have the fan work at the lower temps.
Is the Camaro PWM or on/off? (regardless of % tuning settings in HPT/SCT)
sting808 is offline   Reply With Quote
Old 10-01-2012, 08:12 PM   #2
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
I don't have the wiring diagrams in front of me but I can tell you the stock tune is set to discrete, not PWM.
I suspect the relay logic is the same as my turbo LNF Cobalt was. Off, 2 fans low in series, 2 fans high in parallel. The fan output table shows 3 states. I have mine set to 91% by 203 degrees to run both fans high.
Iam Broke is offline   Reply With Quote
Old 10-01-2012, 10:45 PM   #3
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
To turn the fans on at lower temps you can either run an upgraded OS from hptuners or put a manual switch on the fan circuit.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000, Built & Tuned by Seth at FEDERAL PERFORMANCE
realcanuk is offline   Reply With Quote
Old 10-01-2012, 11:53 PM   #4
sting808
Drives: 2010 SS RS
If the fans are on/off, it seems having the fans come on in the mid/upper 190s would help. I believe 192 is the lowest per OE OS. I do not want the fans on all the time and burn out due to high duty cycle, too. Is there a compromise operation range with the larger radiator?
When cruising, temps are typically 189-192. Water pump at idle may be another factor.
I have a larger radiator, but still seeing higher temps after passes and in traffic.
I hate the fact that my KB reservoir boils over and drips dexcool in the engine bay. I know I need to either go chiller. Or, Torq HE with fans and larger reservoir. I'm trying to avoid the chiller since I need to pull the blower and modify the AC system. IATs of 145-155 needs to be addressed.
I digress...
Is keeping the temps in the mid/high 190s during idling and between heats reasonable? Will it put high wear on the fans?
Mainly street commuting with bi-monthly auto-x use.
*item list is growing*
6-point harness and bar
bigger HE w/fans
bigger reservoir
ID850s
axles
driveshaft
slotted rotors
race wheels/tires
food
medical coverage
Old 10-02-2012, 05:56 AM   #5
Iam Broke
PHAT B33
Iam Broke's Avatar
I know it's debated to no end on the forums, but I would put in a 160* stat and set the fans to be full on by 203*f. The 160* stat in my old LS1 ran 174* in 100* ambient at cruise.
192 24%
196 26%
199 51%
203 91%
It needs to transition through these values to set the fan control modes on rise and fall IMO.
