HeadlightArmor
Old 10-02-2012, 11:16 AM   #1
SixCyl
SixCyl's Avatar
Drives: 2010 Camaro CGM V6
Suspension Q & A
So I was going to just a start a post about a couple questions that I have concerning suspension mods but I feel that instead of having a bunch of threads to look for, maybe we can have a mini wiki thread dedicated to answering general questions about suspension mods for non technical people such as myself.
Rules to the thread:
Ask questions, get your answers.
Anyway, first questions.
I was surprised by how relatively cheap sway bars are and was looking into the hotchkins F/R bars. However, I noticed they don't come with end links and I see a lot of posts saying that as long as you're replacing the bars may as well do the end links too. I don't race, my car is my daily. I would maybe one day like to take my car to a drag strip but there aren't any nearby. I am also considering just getting a rear bar only as I have seen that rear only vs RF is a better/best situation.
My question then is, what do the end links provide that the oem ones do not? And, for daily do I really need to do R/F or will I feel a big enough difference with just rear?
El gato. Mods: Eagle eye headlights, 18" Axis Sport graphite, Roto-Fab cold air intake, Vmax ported TB, 3/8" Vmax Black-Ice, RX single valve catch can, RX breather, Pedders inserts, Trifecta tune, BBK LTH 304 SS.
art/ärt/Noun. Definition: 5th generation Camaro.
SixCyl is offline   Reply With Quote
Old 10-02-2012, 11:46 AM   #2
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
The major problem with the OEM end links on the 2010-11 cars is that they are only designed to handle the stock bars. They just aren't very robust. Many people early on with daily drivers have bent an OEM link hitting bumps on the road with bigger bars.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 10-02-2012, 11:49 AM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
The rear makes the biggest difference, but it doesn't hurt to do the front as well. That and it's cheaper to buy them both then buy them separately.
The OEM end links are pretty shoddy. A number of people have found that using the OEM end links with an aftermarket (stiffer) away bar causes the end link to tear out of the bracket.
Click to view my build thread
Old 10-02-2012, 11:52 AM   #4
SixCyl
SixCyl's Avatar
Well...that answers my questions. Sway bars and end links for Christmas!
Old 10-02-2012, 12:30 PM   #5
SixCyl
SixCyl's Avatar
How do I request for this to become a sticky thread?
Old 10-02-2012, 12:36 PM   #6
JusticePete
5th Gen Master Builder
JusticePete's Avatar
Drives: Camaro Justice
If your thread is going to become a sticky more people will have to contribute a lot more information. A great deal of what you're looking for is already available on C5, but lost in the thousands of technical threads. We have a book about the 5th Gen here on C5. This is the index. I hope you find it useful.
Pedders 2010 Chevrolet Camaro Suspension Evaluation
Foundational 5th Gen Required Upgrades
Lowering Coils and Coilovers
Trouble Free, OEM Quiet V6 Lowering
Sway Bars
Suspension Bushes
ZL1 / CTS-V Brake Upgrade for the SS
Wheels and Tires
Bush Timing, Alignment and Torque Specs
Pedders USA Camaro 2.0
Lingenfelter L/28 Tech
5th Gen Wheel Hop and Drag Race Setup
Thermal Management
Running Changes Made to the 5th Gen by Chevrolet
Public Track Test #1
Public Track Test #2 Camaro vs. Mustang Supercar Shootout
Old 10-02-2012, 01:20 PM   #7
SixCyl
SixCyl's Avatar
Right, that's why I'm hoping this thread catches on and can become a general Q&A for suspension. We'll see how it goes. Thanks for the book!
Old 10-02-2012, 04:35 PM   #8
SixCyl
SixCyl's Avatar
So after reading a bit of the book from above I feel like I learned some stuff, I also have more questions now lol.
Before I start with sway bars should I start at the foundation with bushings? If so which bushings should I go with? It seems that there are a dozen or so different bushings and hundreds of different places to tweak the suspension and while all would be beneficial I'm sure, which are the recommended ones for just a more responsive, better handling daily driver? Also, living in FL I do not want to sacrifice anything that would affect grip (i.e. I wouldn't set my front sway bar to softest and my rear to hardest because of the rain).
Old 10-02-2012, 05:06 PM   #9
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Since your a v6, I'd look into the Pedders Street 1 Package. That's for the subframe bushing inserts. You shouldn't need to do very many other bushings in a daily. It's for the v8 big power guys that other bushing replacements will make sense
Old 10-02-2012, 06:28 PM   #10
SixCyl
SixCyl's Avatar
Ok, I checked out the pedders street 1 kit and am leaning to it. But to leave doubts aside, is there any reason to choose the street 1 kit over the BMR street kit (BK20)? They both have the same inserts for the rear, the BMR has differential bushings for wheel hop but not front end inserts like pedders, while pedders has no dif bushings. Pros and cons people? i hope one day I know enough to help someone else out in this, lol.
Old 10-02-2012, 06:35 PM   #11
The Stig
The Stig's Avatar
Differential bushings won't really help with wheel hop, they are more to prevent the diff from moving around while under heavy load. It's the same concept as replacing your OEM engine mounts with solid ones.
Old 10-02-2012, 06:50 PM   #12
SixCyl
SixCyl's Avatar
My mistake, that's just what I've been reading around some threads. Ok, and minimizing the movement will allow for consistent transfer of power to the wheels but will also increase cabin noise?
Old 10-02-2012, 06:59 PM   #13
The Stig
The Stig's Avatar
I didn't really notice any increased noise after I had mine installed
Old 10-02-2012, 07:14 PM   #14
SixCyl
SixCyl's Avatar
Alright, cool. Looks like going with the BMR BK020 package seems pretty comparable to the pedders street 1 package at a lower price. Are there any advantages over having dif bushings compared to the radius bushings or vice versa?
faq, link ends, suspension, sway bars
