HeadlightArmor
Old 10-02-2012, 06:11 PM   #1
KodyJoe
KodyJoe's Avatar
Drives: 2010 White Camaro SS
Nitrous Help Please!
So, I just recently installed a nitrous kit I picked up. Before I start spraying, I have 50,75,100,125, and 150 jets for fuel and nitrous side. I don't wanna go big yet because I have a tune from a dyno shop and they added timing. I have CAI, LT headers and cat back, the basics.. SO to the questions. 1. what could I safely spray while having timing added 2. what plugs should I put in for a 50, 75 etc. 3. Since it'll be awhile before I go heads and cam should I just buy a hand held programer or hp tuners? The amateur that tuned my car didn't take off the govenor or tune the tranny and he won't get back with me... Any help is great! Thankyou - Kody (it's a l99 car by the way.. yes i bought an auto haha)
L99 with CAI, LT Headers, Full Exhaust, and Dyno Tune 374.73 rwhp and 397.18 ft-lbs.
KodyJoe is offline   Reply With Quote
Old 10-02-2012, 06:37 PM   #2
BlackM6RS/SS
BlackM6RS/SS's Avatar
Drives: 2010 Black M6 RS/2SS
Post this in the Forced Induction section, you will get plenty info there
10 Blk/Blk RS/2SS w/CGM Stripes
ADM H/C/I M6 480rwhp 435rwtq
FE4 LCAs w/Pfadt ZL swaybars Diff bushings Trailing arms Drop springs
BlackM6RS/SS is offline   Reply With Quote
Old 10-02-2012, 06:43 PM   #3
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
Get with a professional tuner that knows what they are doing before you spray it. If not your going to be very sorry you didn't.
Sent from my HTC One X using Tapatalk 2
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 10-02-2012, 07:21 PM   #4
MBS
MBS's Avatar
Drives: 2010 rs 2lt
Camaro Now Mag has a pretty good read on one in the new issue ,you might want to check it out
MBS is offline   Reply With Quote
Old 10-02-2012, 07:21 PM   #5
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
scrming is offline   Reply With Quote
Old 10-02-2012, 07:54 PM   #6
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
Read this, has some good info, And you need the Lingenfelter LNC002 adjustable timing retard box.
http://www.gmhightechperformance.com...et_n20_system/
Nitroman28 is offline   Reply With Quote
Old 10-02-2012, 08:12 PM   #7
caliguy
Don't ask to pop my hood!
caliguy's Avatar
Drives: it's loud.......
SPRAY BIG OR GO HOME!!! just kidding, get hooked up with the right turner guy before you gernade.
Limo tint rears, 35% sides | B&G lowering springs | BowTies Blacked out | Red Footwells|Dome Light|Kicker 500Watts-Amp-Kicker 12" Ported Sub=BOOM| Stillin Splitter |Pssst 100 shot| 13.36 @102.7 @LVMS |
2010.
caliguy is offline   Reply With Quote
Old 10-03-2012, 08:30 AM   #8
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: '15STI,'10Expy,'10 2SS/RS M6,'47KB1
Just saying. educate yourself before you spray and go to a quality shop if you want a turn key system. You pull about 2 degrees for every 50 hp shot never add timing. Do u have a window switch? Colder plugs installed? Non projected plugs? Afr meter ? Factory or after market cats? List goes on.
Nitrous Outlet Plate (progressive, fuel hose upgrade, remote opener, heater, filter, console switches), LNC2000, ARH 1 7/8" LTs/gutted cats/X pipe/mufflers, Jet Hot coated LTs, JRE SCT Tune, CAI, Scoop, Rx Catch Can, Gates heater hose relocation, Remote clutch & auto brake res, Metco loop, Momentum Tunnel Brace, TSW Nurb 18" 555 & 555R, Pfadt trailing arms & toe rods, Autometer wideband, Fesler Pillar Pod, LED strips (int), Lloyds floor & trunk mats, LED DRL/front turn & license plate, DRL harness, VLEDs tail lights, Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17 @ 112.6 stock
Badbubba is offline   Reply With Quote
Old 10-03-2012, 01:17 PM   #9
KodyJoe
KodyJoe's Avatar
I appreciate all the help! I've been doing alot of research that's why I haven't sprayed yet! I know I need to pull timing but I thought It was 2 degrees for every 25 shot? And no, no window switch I have I have a arm switch and a little hand held remote for the fire. I'm not sure what plugs I'll need yet and I have a catless exhaust. So everyone says tune first? Don't just get a hand held to pull timing?
Old 10-03-2012, 02:06 PM   #10
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
i runnin br7ef , and they r non projected tip, 2 stepps colder then factory. 2* for every 50 to be safe, but i ran a 50 shot with my cammed bolton ls3 and didnt pull non , it did fine but i had the plugs and good gas .
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 10-03-2012, 02:23 PM   #11
KodyJoe
KodyJoe's Avatar
So for the time being I'd be alright to spray a 50 shot with colder plugs and 91 octane? Because I'm in Oklahoma and theres no 93 octane around.
Old 10-03-2012, 02:50 PM   #12
scrming
scrming's Avatar
if you were running stock tune with stock timing, then you would be fine... but guessing your running more than stock timing with your tune...
Old 10-03-2012, 02:54 PM   #13
KodyJoe
KodyJoe's Avatar
Yes scrming I am... I'll make the smart play. It's better to be safe then sorry and that's an expensive ass paper weight if it blows up haha.
Old 10-03-2012, 04:48 PM   #14
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
with 91 i wouldnt , i had the plugs in 2 step colder plugs and i put a jet on the fuel side up a lil higher then it should have been and had 93 oc (4 or so gallons) and 110 oc about a gallon and a half mixed. it was a bit risky , but i took that chance. 9/10 it would be ok but it only takes 1 time. and if it happens just hope it blowes the air filter off and not the manifold and hood. lol. how much timing u running atm n/a
l99, nitrous, questions, tuning
