Solo Performance
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 10-02-2012, 09:05 PM   #1
camaro2lt
camaro2lt's Avatar
Question Winters on it's way any tips to keep the garage warm?
hey guy's winter will be here before you know it soo i wanted to know if you guys had any ideas on keeping the garage warm? Like puting weather striping on the window's? Any ideas would help thanks guys
Old 10-02-2012, 09:08 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
I would a kerosene space heater whenever I would work in the garage.
Click to view my build thread
Old 10-02-2012, 10:18 PM   #3
buzzy56
buzzy56
buzzy56's Avatar
Drives: 2ss summit white L99
Usually works
Jack Daniels usually works !
OLD SCHOOL / NEW SCHOOL COOL
buzzy56 is offline   Reply With Quote
Old 10-02-2012, 10:36 PM   #4
HP Turbine
Boosted
HP Turbine's Avatar
Drives: 2012 1LT RS... with snails
A combo of the two above.
IPS Twin Turbos, Corsa Exhaust, Ported Throttle Body. 461 rwhp 443 rwtq!! *Cameron Hass.ani*
HP Turbine is offline   Reply With Quote
Old 10-02-2012, 10:45 PM   #5
STL20102SS
STL20102SS's Avatar
Drives: SW 2010 2SS/RS
Propane heater from Lowes. I can usually get my 2 car garage up to 65 degrees pretty quickly.
Dyna-Glo Delux 30K-60K BTU Liquid Propane Forced Air Heater
Item #: 37449 | Model #: RMC-FA60DGD
2010 Summit White 2SS/RS M6: Injen longtube cold air intake, Borla S-Type cat-back exhaust, Tint, White painted rear diffuser, Red powder-coated Brembo calipers, New Era Performance ported throttle body, BMR 1" lowering springs, Hotchkis Chassis Max Strut Tower Brace, Red hash stripes, Vossen Matte Graphite/Machined CV5's
STL20102SS is offline   Reply With Quote
Old 10-02-2012, 10:49 PM   #6
motorhead
Drives: POS MOPAR
Well, I've been in the heating business for a very long time. I would say it all depends on how much money you have to spend as to what kind of system to get. I will say one thing though. you have to watch using fuel burning heaters that get their combustion air from the garage instead of the outside. For an add on (meaning an existing building) a nice sealed combustion gas unit heater does a nice job. I have a 98% condensing gas furnace with air conditioning in mine. It works great.
Old 10-14-2012, 01:17 AM   #7
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
Windows can be insulated pretty cheaply with plastic shrink window covering you can get at Lowes, Walmart, Sears, etc. If your walls aren't insulated I would start there and the windows, and yes, by all means caulk or otherwise fill any gaps. There are countless heaters out there you could choose from. Just make sure it is safe for using in enclosed areas. Compare BTU output to fuel usage for the economic end of things.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 10-14-2012, 01:20 AM   #8
CWI
CWI's Avatar
If you go electric heat make sure your electric system can handle the amperage of the heater. If you need a higher rated circuit breaker, check with an electrician to make sure the wiring can handle the current load. Don't want to burn down your garage, not with a Camaro in it anyway.
