BeckyD @ James Martin Chevy
Old 10-02-2012, 11:23 PM   #1
caverman
caverman's Avatar
Drives: '69 SS Convertible
1LE suspension part numbers
I'm looking into what it would cost to upgrade my 2010 SS to the 1LE Lower Control Arms, Sway Bars, and End Links. I found these part numbers for these parts so far but I haven't found the control arm part numbers yet.
1LE Front Sway Bar - 22812946
1LE Front Sway End Link (passenger side) - 22842515
1LE Front Sway End Link (drivers side) - 22842516
1LE Rear Sway Bar - 22786260 (same as ZL1, comes with brackets and bushings)
1LE Rear Sway Bar Endlink (2) - 22761221
1LE Rear Sway Bar Bracket Bolt (4) - 11518623
Has anyone doe this uprgade yet? If so, was it a fairly easy install and did you feel like it make an improvement?
Anyone upgrade the LCA bushings while you're at it or should that just be left alone?
Any suggestions on the best place to get these from?
Build Journal
Old 10-03-2012, 07:21 AM   #2
toehead93
Drives: 2014 2SS/1LE
I believe the LCAs are the same as the 2012 SS, if so i have the part numbers somewhere.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 10-04-2012, 01:15 AM   #3
ZooDad
ZooDad's Avatar
Drives: 2010 Camaro SS/RS
Rear Lower Control Arm(2) 20942237
ZooDad
ZooDad is offline   Reply With Quote
Old 10-04-2012, 10:14 PM   #4
PartsTaxi.com
PartsTaxi.com's Avatar
Drives: Parts Taxi
We would be happy to help you with these parts. Shoot me an email and I can put pricing together for you (normally would do now and post here, but can log into pc at dealership tonight for some reason).
Thanks
Kevin
www.PartsTaxi.com
kevin@partstaxi.com
PartsTaxi.com is offline   Reply With Quote
