Old 10-03-2012, 08:38 PM   #1
hsoj10
hsoj10's Avatar
Drives: 2010 Camaro 2SS/RS SIM
Paint specks!
I recently noticed my car has several specs of dust or something in the paint under the clear coat. After I saw one I started looking and found several more. It literaly looks like a small piece of sand with clear coat over it. I am worried about taking it to the dealer to be fixed for fear the repairs may be more obvious. Has anyone else had this problem and had it repaired? what was the result?
hsoj10 is offline   Reply With Quote
Old 10-04-2012, 09:07 AM   #2
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
You're absolutely certain its "under the clear"?
Have you tried claying and/or polishing to make sure its not a surface imperfection?
Old 10-04-2012, 02:58 PM   #3
Angelo@Autopia
Angelo@Autopia's Avatar
Drives: 2014 Ford Focus ST
I agreed with Dylan with this, you might want to try claying with a fine or medium clay bar to see you can safely remove them. Now is this in one area or the whole car?
Old 10-05-2012, 09:58 PM   #4
hsoj10
hsoj10's Avatar
I am absolutely positive that it is under the clear. i can see the clear coat over it and also feel it. It is pretty obvious that its in the paint under the clear and there is more then one of them.
Old 10-06-2012, 12:20 AM   #5
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
How can you "feel" it if it's under the clear? Not doubting you, just curious
Also, pictures would be super helpful!
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 10-06-2012, 01:10 AM   #6
BronxxBombers213
BronxxBombers213's Avatar
Drives: 2010 Camaro 2SS RS
i have one of these too but doesnt bother me too much
BronxxBombers213 is offline   Reply With Quote
Old 10-06-2012, 01:33 AM   #7
hsoj10
hsoj10's Avatar
Because it is a raised spec. looks like the paint has a pimple lol. Whatever it is its big enough if you run your finger over it its raised. Hard to see otherwise though. Just annoying now that i have found them.
Posted from Camaro5.com App for Android
Old 10-06-2012, 11:59 AM   #8
ihaveacamaro
I like teeth.
Drives: #198
Gotcha. Still some pictures would be mighty helpful
Old 10-06-2012, 05:29 PM   #9
WiSSDiver
WiSSDiver's Avatar
Drives: 1968 Coupe, 2010 2SS, 2011 2SS/RS
I've got one or two myself. The most noticeable is on the rear fender just off the trunk lid. Same type of thing: looks like a pimple
WiSSDiver is offline   Reply With Quote
Old 10-06-2012, 06:55 PM   #10
ihaveacamaro
I like teeth.
Drives: #198
Did you go over it with your DA?
Old 10-08-2012, 08:39 AM   #11
Todd@Autopia
Todd@Autopia's Avatar
Drives: 2010 Mazdaspeed 3
There have been some reports of Camaro's having (what is commonly called) dust nibs in the paint. If it is under the clear or in the clear, then the only way to fix is by wet sanding. The problem, of course, is that if it is completely buried under the clear you will end up sanding through the clear coat to remove it. How bad does it bother you?
Old 10-08-2012, 10:41 AM   #12
WiSSDiver
WiSSDiver's Avatar
I have and it's less noticiable. I only really see it when I clean it. To answer Todd, it really doesn't bother me, but I only have like one or two spots on my whole car like this.
I sounds like there are more on the OP's
