sjm autoprod
Old 10-04-2012, 06:27 PM   #1
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28, Challenger
Performance mods
Is there a post of mods that up the HP on stock ZL1s?
Something like a list and what you gain in HP. Thanks
Skylane765 is offline   Reply With Quote
Old 10-04-2012, 06:42 PM   #2
hognutz
hognutz's Avatar
Drives: 2013 ZL1
there are some threads about different vendors builds and what they got out of them. below seem like some of the ~numbers I have seen.
~20-30hp cai and tune
~80hp upper pulley cai tune
ported snout ~15-20hp I think (usually done with other mods)
ported tb 10-15hp I think. (usually done with other mods)
headers ~30hp (I have read you can loose a lb of boost so you are not going to net that without replacing the lost boost.)
cam ~30+hp
heads ~30+hp
then lower pullie can be thrown int he mix as well. 15-16lbs seems to be the most i see people run "safely" according to the larger tuners.
If any body see's any error's in my number feel free to point them out as I did not stay in a holiday in express last night.
the most I have seen people throwing around I think on stock bottom ends is like ~700-750whp range.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 10-04-2012, 06:50 PM   #3
firecross91
firecross91's Avatar
Drives: ZL1 #1691 Black on black.
Many posts like this. Hog is about right.
firecross91 is offline   Reply With Quote
Old 10-04-2012, 07:01 PM   #4
ModBargains.com
ModBargains.com's Avatar
Drives: Widebody 2013 Mustang GT
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
I'd agree, seems to be right on par
ModBargains.com is offline   Reply With Quote
Old 10-04-2012, 09:24 PM   #5
Skylane765
Skylane765's Avatar
Thank you,
What may help me is a company I can be directed to, or a catalog?
I would like to see parts I can buy, I have worked for Chevy many years back in the 70 s
Old 10-04-2012, 09:37 PM   #6
OldScoolCamaro
Heres the thread...
http://www.camaro5.com/forums/forumdisplay.php?f=145
Those doing mod's post the results. Many reputable sources are doing so here.
Old 10-04-2012, 09:41 PM   #7
KKreme15
KKreme15's Avatar
Drives: C6 Z06
cam ~30+hp
heads ~30+hp
If you lose boost with headers, you don't need to up the boost to net the gain. You're just getting that power without having to spin the blower as fast and needing extra cooling... I think
KKreme15 is offline   Reply With Quote
Old 10-04-2012, 10:43 PM   #8
hognutz
hognutz's Avatar
Drives: 2013 ZL1
Boost = HP you lose a pound you are not making as much power as you would have. Headers alone might only get 15-20hp because of the boost you lost. $1500 is an expensive 15-20hp.
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
Old 10-04-2012, 10:47 PM   #9
Godsplumber
Godsplumber's Avatar
Drives: 2012 ZL1,Victory Red
Here is mine and what my mods got me. Different from what's being said here, a little.
http://www.camaro5.com/forums/showth...8&goto=newpost
Godsplumber is offline   Reply With Quote
Old 10-04-2012, 10:50 PM   #10
hognutz
hognutz's Avatar
Drives: 2013 ZL1
Originally Posted by Skylane765 View Post
Thank you,
Lots of vendors use lingenfelter pullies. There are tons of intake manufacures. kdi and adm come to mind on porting work.
In my mind I am leaning towards ported snout(has to come off for upper pulley), ported or new tb, cai, tune. Injectors if the max out.
I was going to do headers but then you need lower pulley most likely which requires balancer as well.
600-625whp is where I will quit. Otherwise my wife will star acting like a vag1na about the car being to scary to drive.
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
Old 10-04-2012, 11:41 PM   #11
Skylane765
Skylane765's Avatar
Thank you guys
Old 10-05-2012, 08:21 AM   #12
sammyv
sammyv's Avatar
Drives: 2013 red Lingenfelter ZL1
Check Lingenfelters website!
sammyv is offline   Reply With Quote
Old 10-05-2012, 08:39 AM   #13
Nailn it
Drives: 2013 ZL1 Ashen Gray / Manual
cam ~30+hp
heads ~30+hp
I did all the above, delete the heads and add a full Supercharger port, brings you to 700. Motor seems to easily handle it. I wouldn't go anymore, though. Your tires wouldn't last a month!
Nailn it is offline   Reply With Quote
Old 10-05-2012, 08:44 AM   #14
Nailn it
My wife drove mine the other day, she did fine. It's all in the throttle control. Engine doesn't boost unless you throttle it hard. She keeps I't in the vacum, drives stock. When I drive it I can't keep the rear end in line with the front!
