BORLA
Old 10-05-2012, 12:13 PM   #1
flyjbaker
Drives: none yet
Max HP without going internal?
I am just trying to get a feel for what kind of horsepower can be had without doing heads and/or cam???
It seems that everyone that is going 700+ rwhp has also at least had a cam install. I was wondering if you could just get a bigger blower...2.3...2.9??? and force more air into it??
What is the limitation of forcing more air? Is it a cooling issue(IAT)? Is the issue the hypereutecticticecticectic pistons?...the entire rotating assembly?
Anyway, it just seems to me that if you could slap a bigger blower on there it would be easier and cheaper than doing heads/cam also?
flyjbaker is offline   Reply With Quote
Old 10-05-2012, 12:31 PM   #2
affox83
System Test Engineer
affox83's Avatar
Drives: '12 ZL1 #1011
Massive heat soak. Supercharger cooling is a major issue in warm weather with these cars with the blower that's on them. Also, if you don't care about that, I think there is a question of room under the hood for a bigger blower. Please correct me if I'm wrong here.
affox83 is offline   Reply With Quote
Old 10-05-2012, 02:39 PM   #3
Pgoldston
Drives: 1999 camaro
a TS whipple or TVS design will be more effecient than what is on there right now. That in its self will drop the IAT2 temps at the same boost level. Building a better IC system is not hard.
I know whipple is working on a system for the ZL1 but I dont know what platform it will be though 2.3/2.9?? I think a 2.9 blower is about perfect with the 6.2 and around 13-15 psi. I think that once we find out about the durablilty of the motors, you will start to see guys push the stock blower pretty deep. When the TS' blowers come out you will see them pushed pretty hard.
You can lead a horse to water but you cant force people to look at the data
Pgoldston is offline   Reply With Quote
Old 10-05-2012, 03:02 PM   #4
Nailn it
Drives: 2013 ZL1 Ashen Gray / Manual
The ZL1 engine is the same motor the have been using in the Cadillacs for a couple years. They are proven reliable, pushed far past 700 rwhp. Surprised the don't have blowers already, for the CTS-V. I ported mine as far as it can go, made a huge difference. The superchiller fixes heat soak, no worries. If it fails it defaults to the HE.
Nailn it is offline   Reply With Quote
Old 10-05-2012, 04:05 PM   #5
hognutz
hognutz's Avatar
Drives: 2013 ZL1
well without heads and cam's my guess would be the 650whp range without headers and 670 or so with. all guessing though.
I have not seen a car yet that went that way though. cai, TB, ported snout, ported blower, both pullies, headers. every build that did all that threw in cam at MIN.
my gut says 670hp or so then again you kind of have to choose how much boost you push at aosme point. think you can pullie it up pretty high but I would quit before that.
I know bigger blowers are in the works but that will be $7.5k i am sure. power potential will be to the limits of the safty I am sure.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 10-05-2012, 05:20 PM   #6
Kmax
Kmax's Avatar
Drives: 2012 ZL1 125HP kit , EIBACH springs
I was told 80 to 100 HP could be coaxed from the Z by changing pulleys ,cai and tune without the addition of headers and exhaust mod's.
It all depends on how much money you want to invest in going faster than you already can.
Kmax is offline   Reply With Quote
Old 10-05-2012, 05:33 PM   #7
flyjbaker
Drives: none yet
Thanks for the input fellas. I am familiar with the common strategies and what numbers they are putting down. My main question is how far can you go just by pumping up the boost....which would obviously require a different blower. And if you could go 15psi with a new blower it may just be worth $7.5k.....which is what heads and cam would cost you....easily. Although I would think a different blower would rung in less than that....more in the $5k range although that is a WAG. I would imagine the weak link in the motor would be those funny named pistons!
Thanks again...good discussion. Keep it coming!
Old 10-05-2012, 06:22 PM   #8
Mattzl1
Mattzl1's Avatar
Drives: 2013 ZL1
You dont have to change the stock blower to increase the boost. You can change out the upper and lower pulleys and get 15 psi boost out of the stock blower. Changing to a bigger blower like a whipple is going to more expensive than changing the internals IMO.
2013 ZL1 AGM, ECF, A6, sunroof, black rims
mods complete! 664 RWHP, 645 RWTQ
Ported snout, 2.5 upper, Innovators west balancer with 9.1 lower, New era intake, American Racing long tube headers with hollow cats and X pipe, KDI heat exchanger, ID850's, TS29 cam !
Mattzl1 is offline   Reply With Quote
Old 10-05-2012, 11:53 PM   #9
hognutz
hognutz's Avatar
Drives: 2013 ZL1
This blower will take it all the way to 17psi.
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
Old 10-06-2012, 04:59 AM   #10
tsnow
tsnow's Avatar
Drives: 12' ZL1, AGM 6M
A few vendors (ADM being one, 650+package) have built 600 to the tire cars with all external mods. Takes 13-14psi and 93 octane though. That's close to 700 at the crank with the stock cam!
tsnow is offline   Reply With Quote
Old 10-06-2012, 08:40 AM   #11
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
look at the livernois stage 2 package..........
Old 10-06-2012, 09:46 AM   #12
Andy@Livernois
Andy@Livernois's Avatar
Drives: 1987 Buick Regal Turbo-T
This is correct, our stage 2 package maximizes the safe level of power without getting into the engine.
The reason you see cams/heads/etc done to make more is keeping the boost level low enough to be reliable on pump gas. The pistons are not the issue, as having a forged piston would only provide you with some better insurance in case of detonation. Case in point, our stage 2 package makes 14-15 psi, but so does our stage 3 head/cam set up. The head/cam combo makes easily 100 more rwhp at the same boost.
Boost is just a measure of restriction, we move more air through the engine on our stage 3 with a more aggressive pulley combo, but because of the cam and head work the boost stays the same because there is greater efficiency, allowing for more power on pump gas. Something that changing the style of blower, size of blower, or anything else will not do.
There is a common misconception that larger blowers will make more power. This is false. 14 psi of boost from any manufacturer of supercharger will yield very similar results. Now one may generate more heat then another, which would make the number less repeatable, but with all conditions being the same they will make near identical peak power.
Now a larger blower has the capability to support more power, but the rest of the combination will be the limiting factor on that.
Andy@Livernois is offline   Reply With Quote
Old 10-06-2012, 12:56 PM   #13
flyjbaker
Drives: none yet
Thanks Andy!!! Very well put. I do understand, all things being equal...14psi=14psi.
So what you are saying is that H/C will always be a worthwhile expenditure on this car and that there is no shortcut by just adding more boost(in theory)? I also do understand the heat issues as boost is increased and some blowers are more efficient at generating boost with less heat.
One more question while I have you on the line:
I assume the cams you put into these applications are more suited to a blower than an N/A car? And if I remember correctly, that would be no overlap of intake and exhaust?
Thanks in advance. I have had a fair amount of experience with N/A LSx egines but have been out of the loop for about 7 years. I am getting old and seem to have forgot a lot of shit lately...hahaha. Just trying to get back up to speed by asking these somewhat arcane questions so I can understand. Thanks again!!!!
Old 10-06-2012, 01:19 PM   #14
1st Gen Forever
ZL1 #140
1st Gen Forever's Avatar
Drives: Camaros: 68 SS, 10 2SS/RS, 12 ZL1
Andy put it very clearly. One other thing I would point out from my experience since some of the earlier posts were inquiring about changing the blower but not so much heads or cam...
When I first started on my upgrades, I wanted to stay external on the engine. I planned blower porting, throttle body, CAI, pulleys, exhaust, heat exchanger, all "external stuff". Well once I got that blower off to ship it out for porting, there staring me in the face was a regular old LS engine stripped to the point of making a cam/head swap not much additional work. My project quickly turned into a full 700rwhp build.
My point is if you want to stay external on the engine, don't touch the blower! Most of us gear heads, I imagine, will suffer the same fate as me if you do. It's just too easy to swap a cam and heads!
You'll love the new power though!
1st Gen Forever is offline   Reply With Quote
