Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 10-07-2012, 12:27 PM   #1
2010_camaro's Avatar
Drives: 2014 Camaro SS
1/4 mph question
ok so I got to looking at my track times and one slip I ran a 14.2 at 99mph and another slip said 15.5 at 98mph. How is that right? The track I went to does not factor in reaction times.
MODS 6.0 forged iron block, Texas Speed Stage3 cam, custom twin turbo, Tripple 450 pumps, DW2200cc injectors, BMR Springs, sways, endlinks, bushings, tailing arm, toe links, DSS aluminum driveshaft, G-Force 1000hp axles, Brake master drilled rotors, ACT twin disk (1550ftlb), MGW shifter, Race Star wheels 17x4.5 with MT front runners 15x10 with Hoosiers, AEM gauges, G-Force II boost controller
2010_camaro is offline   Reply With Quote
Old 10-07-2012, 01:25 PM   #2
BrokenNut's Avatar
Drives: GM of course
MPH@ 1/4 is taken at the finish line with speed trap beams. Nothing uncommon here.
Compare your time tickets, should see the car didnt run the same over the course of the run. Bad 60' etc??
"Lessons in life are expensive for beginners"
BrokenNut is offline   Reply With Quote
Old 10-07-2012, 06:43 PM   #3
Three of Swords
Three of Swords's Avatar
Drives: 2011 IBM 1SS/RS L99
Without seeing your 60' times, I would hazard to guess you spun a lot more on the launch of the 15.5s slip. The speeds are similar because once you got traction, the track wasn't much shorter than the time you got traction right away. So you sped up to almost the same speed.
For the record, your ET (Elapsed Time) never counts RT (Reaction Time). RT only matters in head-to-racing, not when seeing how fast your car is (ET).
Three of Swords is offline   Reply With Quote
