BORLA
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 10-08-2012, 03:38 PM   #1
SixCyl
SixCyl's Avatar
Drives: 2010 Camaro CGM V6
OEM floor jack
Hey so I am about to purchase the Pedders street 1 package but don't feel like paying a shop 400-500 dollars to install. I plan on buying two or four jack stands, I haven't decided which ones to buy yet, and lifting my car. My question for the floor jack though is will the one that comes in the trunk with the spare tire work fine? I've never done this before so I'm open to any suggestions and recommendations for getting under my car.
El gato. Mods: Eagle eye headlights, 18" Axis Sport graphite, Roto-Fab cold air intake, Vmax ported TB, 3/8" Vmax Black-Ice, RX single valve catch can, RX breather, Pedders inserts, Trifecta tune, BBK LTH 304 SS.
art/ärt/Noun. Definition: 5th generation Camaro.
SixCyl is offline   Reply With Quote
Old 10-08-2012, 07:09 PM   #2
SixCyl
SixCyl's Avatar
Never mind, I am just going to buy a floor jack from Walmart and four 3-ton jack stands.
Old 10-08-2012, 08:02 PM   #3
Ebbsnflows
Drives: 2010 Camaro SS/RS
Be aware that once you lower the car with the Pedders kit, a standard floor jack will no longer fit under the rocker panels of the car. This will essentially make your new jack useless. If you're going to spend money on an el-cheapo jack from Walmart, I would recommend spending a little extra on a higher quality low-profile jack that can be used after the suspension install.
I have 3 jacks that I use regularly. 2 are aluminum light-weight low profile race jacks and another is a heavy (115 lb) standard profile ez-pump jack. The standard profile comes no where close to fitting under the SS (I use it mostly on my 4Runner or as additional bracing once the SS is already lifted by the low-pro jacks)
2010 Camaro SS: TSP 231/236 cam, Kooks LTs, Magnaflow 16580 catback, Airaid CAI, U/D pulley, Pfadt-Stage 3, MTI shifter, MPD1 spoiler, S-S Splitter, 22" Nurburgrings
Ebbsnflows is offline   Reply With Quote
Old 10-08-2012, 08:15 PM   #4
SixCyl
SixCyl's Avatar
Oh no, I'm not lowering my car. Just adding bushings. But that is a good consideration.
Old 10-10-2012, 03:37 PM   #5
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: CGM w/Black stripes
this works great and my car is lowered.
http://www.harborfreight.com/2-ton-l...ump-68051.html
BMR Suspension, SLPTVS2300, GFORCE Driveshaft & HalfShafts, Kooks with cutouts and other fun things.
Old 10-10-2012, 08:28 PM   #6
Ebbsnflows
Yeah, you can get these on sale (and use the 20% coupons) to pick them up for around $90-100 on occasion. They're not bad for the $$.
Old 10-11-2012, 11:32 AM   #7
Imback
Drives: 1980 Yugo
Can't use the 20% coupon on Jacks. Its printed right on the coupon.
Imback is offline   Reply With Quote
Old 10-11-2012, 12:41 PM   #8
MBK
MBK's Avatar
Drives: 2011 SIM 2SS/RS
so the harbor freight ones work well w/ the stock SS? that's good because i think i can go pick it up locally -- i need to swap in my winter wheels and don't want to be scratching the car up -- do you all put anything more on top of the pad for protection or is that pad good enough?
Here I come
MBK is offline   Reply With Quote
Old 10-14-2012, 01:34 PM   #9
Hercules
Drives: 13 ZL1 1091, 04 Ram 2500, 12 CX9
Have you used the coupon on the jack? I was just looking at it last night, and also read the fine print on the coupon. 20% Off is great considering the price of other low profile floor jacks.
Also how much clearance do you have with your car? The ZL1 I measured at 3 1/2 inches.
Hercules is offline   Reply With Quote
Old 10-14-2012, 08:53 PM   #10
Ebbsnflows
You are correct...I misspoke....I used one of the Harbor Freight "super coupons" that are in the back of Car/Driver and Motortrend. They are Jack-specific coupons (actually showing the specific model on the coupon face). The Standard 20% off are not valid as stated.
You can get this one right now for $129 with the coupon in last months M/T: http://www.harborfreight.com/2-ton-l...ump-68051.html
Although, FYI...I bought it for $99 on Black Friday a couple of years ago (they might offer it again this year?)
With Pfadt lowering-coils installed, I have about 5" clearance on the side rocker panels and about 4.5" from the front (I have the Street-Scene front splitter installed). With only 3.5" of clearance on your ZL1, I doubt any of the HF jacks would work....that's pretty low. I'd recommend picking up a 36" length of 2x10 lumber, then cut it into two 18" lengths. Then drive the front/rear wheels up onto them (acting as mini-ramps)...that will give you extra clearance and permit the use of a wider variety of jacks
how to lift car, where to place jack stands
