Old 10-08-2012, 05:59 PM   #1
petetcs
Drives: 2013 ZL1 victory red
help on a hurst shifter
i have a 2013 zl1 6 speed order a hurst shifter part # 3916030 for phastek performance called phastek to make sure shifter will work on 2013 zl1the teck has put one in and no problems i also called hurst and info was will not work anyone have info
petetcs is offline   Reply With Quote
Old 10-08-2012, 08:28 PM   #2
oldtoad
oldtoad's Avatar
Drives: Victory Red ZL1
Did It
I just installed one yesterday, it works great. I love it:-}
oldtoad is offline   Reply With Quote
Old 10-08-2012, 08:31 PM   #3
knitetrain05
Drives: 2012 Camaro SS 45th Anniversary Edi
How about just leaving well enough alone.
knitetrain05 is offline   Reply With Quote
Old 10-08-2012, 08:40 PM   #4
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
Same questions I asked, but oldtoad seems to have answered it for us!! You Rock oldtoad
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 10-08-2012, 08:47 PM   #5
petetcs
ok will see on wednesday
just like the look of the hurst shifter
Old 10-08-2012, 09:01 PM   #6
oldtoad
oldtoad's Avatar
Shifter
It does have that nostalgic look, I chose the black knob. It is so short and crisp! I think you will like it.
Old 10-08-2012, 09:18 PM   #7
petetcs
what was the time to put the shifter in
Old 10-08-2012, 09:45 PM   #8
oldtoad
oldtoad's Avatar
I'm not avery good example. I do these projects and really take my time. I have a lift in my garage was very useful for this project. The only difficult parts were getting the stock knob off because I di not see the set screw and it was not in the directions or the video, and then getting the dust boot back on after connecting everything underneath. not much room to worka nd thats why you need to lower the trans.
Good luck.
Mr Toad.
Old 10-08-2012, 09:53 PM   #9
petetcs
thanks mr toad dont like having to drop the trans
Old 10-09-2012, 12:18 AM   #10
oldtoad
oldtoad's Avatar
Don't have to take it out just loosen the rear cross member bolts to lower the tail shaft.
Old 10-09-2012, 01:06 AM   #11
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
I have the same shifter on my 2011 SS. Total install time for me was about 45 mins. I had my car on a lift though. It would've taken me longer if I was working on the ground with jack stands.
Loosening the transmission crossmember bolts is very necessary.....unless you have very small hands. Honestly, the most difficult steps for me was ensuring the rubber dust boot is properly seated and getting the black plastic loops around the shifter stick.
Read everything ahead of time in the instructions:
http://www.hurst-shifters.com/wp-con...ds/3916030.pdf
It's all worth it. I like the looks and short throw shifting.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
LimaCharlie is offline   Reply With Quote
Old 10-09-2012, 02:41 PM   #12
Joebot8484
ZL1 # 1307
Joebot8484's Avatar
Drives: 2012 Camaro ZL1, 2008 Hummzilla H3
I ordered mine last week and it should be here in the next couple of days. I wanted to install a red hurst ball that I had in my 4th gen camaro but didn't want to thread the stock stick so I went with the hurst. I'll put the old one in a box and save it. I got the suede package and after 6k the knob is already looking matted.
Click on my signature for my build thread
Joebot8484 is offline   Reply With Quote
Old 12-03-2012, 09:18 AM   #13
bwolf11
bwolf11's Avatar
Drives: 2012 Camaro ZL1/2018 ZL1 1LE
oldtoad...was thinking of dong the same to my ZL1. I had one of my 2SS and loved it but my concern is the hight of the Hurst shifter as the stock one is nice and small and sits low. Does the Hurst sit up much higher? Do you have an interior photo of it you can share?
bwolf11 is offline   Reply With Quote
