SDPC
Old 10-09-2012, 12:28 AM   #1
jbrown13
jbrown13's Avatar
Drives: 2011 Camaro SS L99
Strip Burnout w/ L99 on drag radials
Sorry if this is redundant, but I searched and couldn't find what I was looking for.
What rear end problems will be created doing a strip burnout with an L99 on drag radials using the brakes to hold the front tires? Is a line lock mandatory for doing a burnout without creating issues in the rear drive train?
Thanks.
jbrown13 is offline   Reply With Quote
Old 10-09-2012, 02:36 AM   #2
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
Line lock is not mandatory, But it will save your brakes. I've done over 30 burn outs at the track with no problems. Like I said just burns the brakes up, Installed a line lock so don't have that problem anymore..
This is the one I used easy to install, Their website is slow but the cheapest price I could find..
http://www.performancepeddlerwholesa..._ID=HUR5671518
You can use the Jegs site for a better description, Peddler has a cheesy site but good prices.
http://www.jegs.com/i/Hurst/530/567-1518/10002/-1
Nitroman28 is offline   Reply With Quote
Old 10-09-2012, 11:55 AM   #3
AngelSpeedFreak
Most hated in NM....
AngelSpeedFreak's Avatar
Drives: Sold the 6POINT2, went to a 50THZ06
I think the linelock is the best thing I ever spent $140 on
You can do your burnout without one, but for the price it is much cheaper than changing our your brake pads....
AngelSpeedFreak is offline   Reply With Quote
Old 10-09-2012, 12:56 PM   #4
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1951 Mercury
I don't have a line lock, no problems here. I might have bout 50 passes on my car since I bought it back in April.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Pro Stock John is online now   Reply With Quote
Old 10-09-2012, 07:28 PM   #5
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
As everyone else has said. No problems doing it except some premature wear of the brake pads. Did it for over a year before the line-lock was installed.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 10-09-2012, 07:34 PM   #6
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2016 Silverado
Keep an eye out for the one tire burnout also. Once you start increasing HP the posi mod is needed to keep both tires spinning.
Old 10-10-2012, 10:58 AM   #7
Pro Stock John
Writer
On that, since I have street tires up front, I go around the water box. I then back up in the groove into the very front section of the water box. I then do my burnout and roll out of it a little. My car has been very consistent, I have about (6) 1.86-1-88 passes, and (20) 1.92-1.95 passes on stock tires.
My first burnout on drag radials is always my longest, and the ones that follow are usually half as long.
PROJECT HEAVY CHEVY
Old 10-10-2012, 11:13 AM   #8
AngelSpeedFreak
Tell me about it I usually look at the guy controlling the lights and he shakes his head at me about half the time when I am doing my 1 wheel burnout.... Guess I really need to get that fixed this winter.
Old 10-10-2012, 11:48 AM   #9
Pro Stock John
Writer
Make sure you are in the water. Now that I think about it I used to adjust my mirrors with the 4th gens so I could see both tires... I need to start doing that again for this Camaro.
PROJECT HEAVY CHEVY
Old 10-10-2012, 03:57 PM   #10
blufin
blufin's Avatar
Drives: Fire Engine
The starter here will usually guide the driver back into the water and pull them out slightly for the burnout. If not, I usually will look over at the other lane's water box to judge how far back I need to go to reach the water
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile
11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires.
Sold
blufin is offline   Reply With Quote
Old 10-16-2012, 12:01 PM   #11
Deke736
COTW 12/3/12
Deke736's Avatar
Drives: 2012 Ashen Gray ZL1
Can this be used on Auto cars as well? In a lot of the info I see reference to manual cars, but none to autos. How easy is the install and where are the switches mounted inside?
Deke736 is offline   Reply With Quote
Old 10-19-2012, 04:19 PM   #12
Awesome_SS
Jeff
Awesome_SS's Avatar
Drives: 2010 Camaro SS/RS
Been thinking doing this also. Here is the info and there is a pdf on the instructions/files tab at this link.
http://marylandspeed.com/hurst-roll-...18-p-3902.html
2010 Camaro SS - Currently: 585 HP, 485 RWHP, 430 Max. TQ. Stock: 400 HP, 339 RWHP, 349 Max. TQ. 2R Max Cam,SW LT Headers & Corsa Exh.ADM CAI & Livernois Tuned, PI 2600 TQ Converter, LPE 3.70 Gears, Eaton True Trac, Ported Heads, TB & Intake. 2012 Camaro ZL1 - Currently: All Stock
Awesome_SS is offline   Reply With Quote
Old 06-15-2014, 04:48 PM   #13
lincoln361
lincoln361's Avatar
Drives: 2011 Camaro SS/RS
Got my questions answered. Gonna give this a shot
SLP TVS 2300- 1 7/8 LG Headers- RDS NX Plate- 75 Shot- No Cats- SLP Loudmouth 2- VMAX Throttle Body- 3.8 Pulley- OD Cog drive-12lbs boost-FIC 80# injectors-ZL1 Fuel Pump- RotoFab CAI- Apex CAI Scoop- Pat G Tune- Nitto 555R 305/45/18- BMR Trailing Arms- BMR 1'' Drop Springs- BMR Toe Rods- BMR Rear Cradle Bushings- BMR Upper Control Arm Bushings- BMR Extreme Anti- Rollbar- Hotchkis Subframe Brace- Prosport Evo Boost & F/A Ratio
lincoln361 is offline   Reply With Quote
Old 06-15-2014, 10:42 PM   #14
Rcfiddy1
Rcfiddy1's Avatar
Drives: 2010 Rally Yellow 2SS/RS #37115
One wheel burn outs is common. I got it but swapped out rear to a manual one and had a Jannetty posi mod and caps done at same time.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust.
Rcfiddy1 is offline   Reply With Quote
