Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Transmission / Driveline
Old 10-09-2012, 08:58 AM   #1
Matt @ RX
Guest
Posts: n/a
** Mantic Street ER2 & Street Twin Series Clutches On Sale
The Mantic Clutches have been performing quite well for the last few years that I have used them. The feel is quite close to stock and even lighter than certain stock pedal feel. The Street Single ER2 clutch is good for 600-650rwhp vehicles and the 9000 Series Twin is good for 900+ rwhp! The Street Single ER2 includes the pressure plate, clutch disc, flywheel, and throwout bearing. We can add a Slave Cylinder if necessary.
The big advantage for the Mantic clutches is that every clutch is tested on their in-house dynamometer. You will find numerous clutch manufacturers on this site and others that sell clutches without even testing their own manufactured parts unlike Mantic.
Here is a quick description of the single clutch ER2 technology: (Good for 781 ft. lbs of torque)
Cover Assemblies with the ER2 Groove Design feature have a unique groove pattern CNC machined on the friction face of the Pressure Plate. The groove has been specifically designed to increase the Mean Effective Radius of the pressure plate and assist in heat removal. The increase in the Mean Effective Radius of the Cover Assembly gives an increase in Torque Capacity by up to 8%. Mean Effective Radius is directly proportional to Torque capacity. By adding the groove to the Pressure Plate, the inside radius of the friction face has effectively been increased. The first 5/16 inches of the pressure plate has all but been removed and added to this, there is progressively less material removed as the radius increases.
Mantic 9000 series clutches are twin disc, 9” (225mm) diameter modular clutches that are designed for high performance cars or track use. Mass is critical for a high performance clutch to produce the expected level of performance, and Mantic offers two levels of low mass clutches to allow you to optimize your vehicle performance to your personal driving style. They offer up to 1010ft lbs (1365nm) of torque drive capability.
Mantic 9000 series are low MOI (Moment of Inertia) twin disc clutches that offer a level of performance not only superior to a single disc unit, but also allow you to select options that best suit you.All 9000 SERIES are made with premium quality materials designed to perform and last the distance.
The key to the 9000 SERIES is the street drivability of the Sprung Street Cerametallic discs. These suit high performance engines and enthusiastic driving styles, while allowing excellent drivability when needed. Low pedal effort is another bonus from the 9000 SERIES.
I have been personally tuning for 12+ years now, and have run across pretty much every clutch that has been offered for these LSx cars. I am quite happy with the comfort, feel, and power handling of the Mantic line of clutches.
Mantic Single ER2 Series Clutch w/ Steel Billet Flywheel $775 Shipped
Mantic Twin 9000 Series Clutch w/ Steel Billet Flywheel $1660 Shipped
"Mantic clutch = best clutch I've ever owned! 6.0vette" (Mantic Single Street Series)
"Drives like a stock ls7 clutch, holds A hell of a lot more power." (Mantic Single Street Series)
You can find numerous testimonials on here and a few other forums.
You can call to order your clutch OR buy it on our ONLINE STORE.
Thanks
Matt
941-721-1826
