Old 10-09-2012, 10:38 AM   #1
Bosse'sBoss
Bosse'sBoss's Avatar
Drives: '14 Corvette Stingray Z51 A6 transm
Letter to GM, requesting changes on 1LE & their answer
Guys, Here I share you the information that I received from GM, this might clear some questions. -------------------------------------------------------------------------- Very interested on the new Camaro 1LE. But I don't like the Vinyl hood cover neither the black rear spoiler. Is there any way that I could delete those on the order or better yet to upgrade to the high wing spoiler and transformer style stripes?. Also I consider a disadvantage that the wide of the wheels is not the same on front and back and will not be able to rotate the tires that are same sizes. Comments like this you will find them from many interested future owners. -------------------------------------------------------------------------- Thank you for contacting Chevrolet and for your interest in the 2013 Camaro! We appreciate the time you have taken to write us and are delighted to assist you with your inquiry. We are so thrilled to hear you are in the market for a new vehicle. General Motors produces vehicles with preset options; therefore, the changes you are requesting cannot be altered by the manufacturer. Additionally, the Transformers Package is no longer available to order on the Camaro. We suggest speaking with your dealer for aftermarket options. If you are not currently working with a Chevrolet dealership in your area and you would like to locate one, an easy way to do so is by using the Locate a Dealer web tool on http://www.findchevydealer.com. We appreciate your comments on the Camaro wheels and not having the option to rotate them. The comments you have made will help us provide the quality products you expect. We value your business and will forward your comments to the appropriate department.
Bosse'sBoss is offline   Reply With Quote
Old 10-09-2012, 10:54 AM   #2
Indy Bumble Bee
Indy Bumble Bee's Avatar
Drives: Beest
Good questions and the answer I expected. I am sure a good dealership will work around your requests. Just be glad your not buying one in SC
Indy Bumble Bee is offline   Reply With Quote
Old 10-09-2012, 11:17 AM   #3
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Drives: 16 Encore, 07 G6, 99 Astro, 16 VW
Those issues would easily be handled aftermarket wise. Since the hood is a Vinyl wrap it should be easy to remove when the car is new because the adhesive has not fully cured then order the transformers stripes. The spoiler I would see if another member with no spoiler would like to swap deck lids since the spoiler holes will not line up with the high wing mounts. Try to order a color that was available on the 10 or 11 LS or LT.
The Bird is the word!
Old 10-09-2012, 11:22 AM   #4
dcplus14
dcplus14's Avatar
Drives: '12 Camaro 2SS/RS/Hurst
I thought the 1LE wheels had the same width.
2012 Camaro 2SS/RS: Black on Black, Hurst
[AAC DRL LED's, AAC LED's for trunk, cabin, license plate, CAI Intake, RX Catch Can, Skip shift eliminator, Pedders Sub-Frame Inserts, Pedders Radius Rod Inserts, Pedders Rack & Pinion Bushing, 1LE front and rear sway bars]
dcplus14 is offline   Reply With Quote
Old 10-09-2012, 11:24 AM   #5
mrvenicess
mrvenicess's Avatar
Drives: 2013 CRT ZL1 auto
Wheels are different sizes, tires are the same as I recall.
mrvenicess is offline   Reply With Quote
Old 10-09-2012, 11:34 AM   #6
Angrybird 12
I just checked and you are correct 20X10 front 20X11 in the rear but the tires are the same size.
Old 10-09-2012, 11:36 AM   #7
DanSS24
DanSS24's Avatar
Drives: Dream Cars in my head
you are correct...it was discussed many times. rear 11", front 10", and tires 285/30/20 all fours.
Wishful thinking...but I sure can dream big.
DanSS24 is offline   Reply With Quote
Old 10-09-2012, 11:40 AM   #8
motorhead
motorhead's Avatar
They must have a computer trained to key on certain words and then try and write a reply.
I can't believe that a human came up with that response.
Old 10-09-2012, 11:44 AM   #9
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
IM pretty sure all of those request can be done by youre dealer.
christianmotox is offline   Reply With Quote
Old 10-09-2012, 03:53 PM   #10
Bosse'sBoss
Thanks Guys!!, I will follow your advice.
Old 10-09-2012, 04:33 PM   #11
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
I'm sure the wheels F/R have different offsets. So you can't use the fronts on the back. The wheels are the ones used on the ZL1 most likely to save cost. Therefore you will not see 20X10's all around.
2cnd chance is offline   Reply With Quote
Old 10-09-2012, 05:24 PM   #12
vetehead
vetehead's Avatar
Drives: 2011 SIM 2LT/RS
So this should mean you can rotate,just a little extra work!!
vetehead is offline   Reply With Quote
Old 10-09-2012, 07:26 PM   #13
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
And again, No, the wheels cannot be rotated. They are different sizes AND the offsets are different.
Perm-a-grin in place.....
JimE is offline   Reply With Quote
Old 10-09-2012, 07:39 PM   #14
SUKXOST
Do you even lift, bro?
SUKXOST's Avatar
Drives: 2013 1LE Camaro
GM gave you the finger.....but so nicely :P
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461
SUKXOST is offline   Reply With Quote
