BORLA
Old 10-09-2012, 08:46 PM   #15
Rhyder
Drives: 2012 45 Anniversary Vert
The wheels would be rotated accross correct? thats all you would need for even wear assuming your alignment and balance were correct
Rhyder is offline   Reply With Quote
Old 10-09-2012, 08:49 PM   #16
toehead93
Drives: 2014 2SS/1LE
Unless the tires are unidirectional.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 10-09-2012, 08:51 PM   #17
Rhyder
hmmm...interesting point...
also wanted to add, you see how smoothly they did the transition.....
We can do none of the things you stated you wanted in a car, but heres a link to the nearest dealer who can sell you that car we could not change to your taste anyways.......
Old 10-09-2012, 08:55 PM   #18
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Drives: 16 Encore, 07 G6, 99 Astro, 16 VW
Originally Posted by SUKXOST View Post
GM gave you the finger.....but so nicely :P
How did they give him the finger? They just told him the truth, same with any manufacturer. It's not the 60's any more where you could just about order a car any way you could imagine.
The Bird is the word!
Old 10-10-2012, 07:43 AM   #19
Zorns
Zorns's Avatar
Drives: ?
Aren't the tires dirrectional?
Zorns is offline   Reply With Quote
Old 10-10-2012, 01:11 PM   #20
boxmonkeyracing
juggernaut
boxmonkeyracing's Avatar
Drives: VRSCF, 2011 SS vert
Send a message via AIM to boxmonkeyracing Send a message via Yahoo to boxmonkeyracing
yes they are.
We do not want to use the Z28 moniker on a car that does not deserve this hallowed name.
boxmonkeyracing is offline   Reply With Quote
Old 10-10-2012, 03:08 PM   #21
MikeSVX
The magic smoke genie....
MikeSVX's Avatar
Drives: Jewels (2010 RJT 1SS)
Here's an idea for the wheels. Find out if the rear rims will fit on the front. If they do trade with another 1LE owner. One of you get the front and one of you get the rears. The person who gets the rears will be able to get wider tires all the way around when they need replacing. Win, win.
MikeSVX is offline   Reply With Quote
Old 10-10-2012, 03:13 PM   #22
MikeSVX
MikeSVX's Avatar
You can rotate the tires. They have to be taken off the rims and remounted and balanced. The rims stay were they are but the tires move to different locations.
Old 10-10-2012, 03:16 PM   #23
Bosse'sBoss
Bosse'sBoss's Avatar
Drives: '14 Corvette Stingray Z51 A6 transm
Thumbs up
Sounds good. Also wider=better handling, and the narrower one for better looks, from what We can see on the actual tires.
Bosse'sBoss is offline   Reply With Quote
Old 10-10-2012, 04:17 PM   #24
vetehead
vetehead's Avatar
Drives: 2011 SIM 2LT/RS
Originally Posted by JimE View Post
And again, No, the wheels cannot be rotated. They are different sizes AND the offsets are different.
So again,yes you can rotate them....I would have figured op would have know what i meant by"a little extra work"I.E break down tires off rims!!
Think before you rudely post!!
vetehead is offline   Reply With Quote
Old 10-10-2012, 04:21 PM   #25
vetehead
vetehead's Avatar
Exactly
Old 10-10-2012, 08:35 PM   #26
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
I said WHEELS!
Yes, you can rotate the tires. No, you can NOT rotate the wheels.
Grow up.
Perm-a-grin in place.....
JimE is offline   Reply With Quote
Old 10-10-2012, 09:04 PM   #27
b4z
Drives: '06 Pontiac GTO M6, '09 V8 SRX RWD
As one who owned 2 IROCZs that had different offsets front to rear, it is really not a big deal to pull the tires off and remount for rotating.
But I quit rotating them because I was buying 180 tread wear tires that only lasted 20k miles so there was no reason to rotate.
And secondly, I have owned 3cadillac SRXs that had 235s up front and 255s on the rear.
Obviously they can't be rotated. They wore fine.
I know have a GTO with 8.5" rims front and 9.5" on the rear. They can't be rotated.
They are wearing perfectly.
These are performance cars, the tires aren't going to last 60k Miles. Why bother at all with rotating?
b4z is offline   Reply With Quote
Old 10-11-2012, 07:45 AM   #28
Zorns
Zorns's Avatar
Drives: ?
I thought that if the tires were dirrectional they can't be swapped side to side?
