Old 10-09-2012, 11:26 PM   #1
Scourage
Syntax Error
Scourage's Avatar
Drives: 2010 Camaro 2SS/RS
ZR1 MAP tuning issue
I installed the ZR1 MAP sensor when I installed the Whipple and went to get it tuned today, I passed on the info for the changes to the tune, Linear: 312.50 and Offset: -11.25.
Once he adds that to the tune, the car will not start. He is using EFI Live and it shows 36 kPa on the scan, if he removes that change to linear and offset, it is at 11 kPa and it starts fine.
With the amount of cars with this I'm not finding a similar issue, anybody have an idea what we are doing wrong?
Scourage is offline   Reply With Quote
Old 10-10-2012, 07:56 AM   #2
Matt @ RX
Guest
Posts: n/a
That should be the correct calibration data, HOWEVER, the best way to know if your calibration is correct is to just key on and turn on scanner. You should read atmosphere with the key on, engine off. If you do not, scaling is off.
You are sure that its a ZR map correct?
Old 10-10-2012, 08:42 AM   #3
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Is the Sensor Red?
If not it is not a ZR-1 Map sensor.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 10-10-2012, 05:09 PM   #4
Scourage
Syntax Error
Scourage's Avatar
Red sensor P/N 12592525. I'll let him know to check scaling if he hasn't figured it already.
Thanks guys!
Old 10-24-2012, 11:16 PM   #5
Scourage
Syntax Error
Scourage's Avatar
Spent some time playing around with HP Tuners demo. Now I see there is a spot to change the MAP offset and linear in both the MAP and SCIAP. Not sure if EFI has both, I assume so, so I'm curious if he made the change to the correct one.
