JDP Motorsports
Old 10-10-2012, 12:43 PM   #1
Rockamakis
Drives: 2013 BRM 2SS/RS,
Removing bug juice
Is there good product that easily removes bug juice from the car when washing it?
Rockamakis is offline   Reply With Quote
Old 10-10-2012, 12:51 PM   #2
charlietuna
charlietuna's Avatar
Drives: 2013 ZL1
I saturate the bug guts with Adams waterless wash prior to my wash method. I tend to use a lot of water pressure to knock as much of as possible prior to touching them with a wash mitt.
Laus Deo
charlietuna is offline   Reply With Quote
Old 10-10-2012, 12:55 PM   #3
Mr. iNCREDIBLE
Mr. iNCREDIBLE's Avatar
Drives: 2012 2SS/RS Convertible
wd-40 works..
I've used wd-40 and an old set of the wifes panty hose in the past, the panty hose works like a bristle brush but doesn't scratch the paint, of course you will need to wax/polish after you get the guts off.
also panty hose work great as an emergency belt if you break one out in BFE.. had that happen in a truck coming back from Vegas once.. my GF at the time was not happy with me....
Mr. iNCREDIBLE is offline   Reply With Quote
Old 10-10-2012, 01:12 PM   #4
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
I would try Turtle Wax Bug and Tar Remover. Cheap, readily available, and works extremely well. Unlike waterless washes or quick detailers, this product is specifically formulated to take bug guts off your car.
Originally Posted by Mr. iNCREDIBLE View Post
wd-40 works..
OP, WD-40 works, but it should be a last resort.
And I would certainly recommend AGAINST using any fabrics that are designed to be worn, not rubbed against paint. Maybe it doesn't scratch, but I would never do it to my car.
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 10-10-2012, 01:24 PM   #5
Mr. iNCREDIBLE
did it on my black 300c with no issues.. no scratches, no problems, of course the hose were wet and it is a very light touch, not man handling it and scraping the crap outta the car..
I'm to old and too disabled to deal with it now, just pay a detailer to do it, but as I said, never had an issue, never saw any scratches in black paint...
Old 10-10-2012, 01:26 PM   #6
ihaveacamaro
I like teeth.
Drives: #198
Yup, I believe you when you say it didn't scratch. Just saying I personally would never do it
Still, WD-40 is in my opinion, a way too aggressive of a starting point. Always start with the least aggressive method, ie bug and tar remover or a waterless wash or normal soap and water
My method is
1) If soap and water didn't work then go to number 2
2) If bug and tar remover didn't work then go to number 3
3) If WD-40 doesn't work, you might be dealing with permanent etches. Go to number 4
4) Compounding and polishing. If this didn't work, you need a repaint.
5) Repaint.
On my car, I've never had to go past category 2, but I have of course seen cars that will no doubt need a repaint, as they are not salvageable.
Old 10-10-2012, 01:26 PM   #7
Mr. iNCREDIBLE
gottca..
Old 10-11-2012, 05:06 PM   #8
Rockamakis
Thank you for the input. I appreciate it.
Old 10-11-2012, 06:01 PM   #9
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
This.... they come right out....tip, if you have Adams quick sealant you can apply that after you're done drying the car...it doesn't prevent bugs, but they come off alot easier next wash
Lil' Nasty is offline   Reply With Quote
Old 10-11-2012, 07:13 PM   #10
charlietuna
Drives: 2013 ZL1
Laus Deo
Old 10-11-2012, 09:13 PM   #11
Beer Thirty
5:30 somewhere
Drives: 2015 Mustang GT
A great product by surf city called road trip grime destroyer. Works great for removing bugs. Only product I know that works.
Beer Thirty is offline   Reply With Quote
