HeadlightArmor
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Exterior Parts & Accessories
Old 10-10-2012, 10:19 PM   #1
ACS Composite
ACS Composite's Avatar
Drives: 2010 Camaro
**NEW PRODUCT** ACS TL1 Insert to be installed on any SS LT LS Hood ( ZL1 Replica )
Hi Guys,
Thank you for the feedback and suggestions from the ZL1 Hood insert thread. Zl1 inserts are now available and in stock. While doing this we have been listening and can proudly say we have completed the design and function for a Zl1 style insert for SS LT LS Hoods.
Currently completing our tooling our TL1 Hood insert to be installed on any SS LT LS Hood.
http://acscomposite.com/collections/...lt-hood-insert
Introducing the TL1 Hood Insert self-install kit, the coolest way to upgrade your STOCK Hood. That's right, modify your Aluminum Hood and save on re-paint and the hassles with replacement hoods. The ACS TL1 Hood Insert self install kit pays homage to the Zl1 while matching the lines of the existent stock hood of your Camaro.
Other than its lightness the original Camaro Hood does not offer any performance advantages, until now that is. Install the Tl1 Hood Insert to extract the engines hot air, and reduce body lift at high speed by relieving under hood pressure. Trim your hood following our guide and templates, rest assured every trimmed edge will be covered (Margin of error, +/- 1/8'' outer). Hood insert kit includes a water management system draining the water towards the front radiator support away from critical engine electronics. For extreme events like racing, you can easily remove the deflector for an optimum suction effect.
Insert is made in ACS's proprietary RTM process and is shipped in a primer finish ready for prep and paint. Unlike conventional fiberglass ACS's RTM process has been tested to withstand heat and distortion. Stock hood will need to be trimmed and 6 mounting holes will need to be drilled. Includes the Insert, rain water deflector, mounting hardware, octagonal grill mesh kit powder coated black and templates.
Reduce body lift and engine heat by upgrading your Camaro Hood while saving on repainting or heavy cost associated with replacement hoods.
Includes
1. 1 – ACS ZL1 Hood Insert for SS LT LS Hood
2. 1 - ACS Water Deflector
3. 1 - Front Passenger Side Hood Grill, Octagonal Mesh
4. 1 - Rear Passenger Side Hood Grill, Octagonal Mesh
5. 1 - Front Driver Side Hood Grill, Octagonal Mesh
6. 1 - Rear Driver Side Hood Grill, Octagonal Mesh
7. 6 - M6 Nut with Mounted Washer
8. 1 - Templates
9. 1 - Adhesive Cartridge
ACS Composite is offline   Reply With Quote
Old 10-10-2012, 10:58 PM   #2
01pewterz28
Camaro Junkie
01pewterz28's Avatar
Keeping my eye on this I might be ordering this
**FIFTY HBM 2SS VERT**
Old 10-10-2012, 11:02 PM   #3
LIM3
it's mind bottling..
LIM3's Avatar
Drives: SGM
saved.
Old 10-15-2012, 08:25 AM   #4
mgaspari
mgaspari's Avatar
Drives: Camaro rs 2lt IBM
have mine pre orderd .. just curious, will you have pictures of this on a hood? Just to see how it looks?
mgaspari is offline   Reply With Quote
Old 10-15-2012, 08:49 AM   #5
01pewterz28
Camaro Junkie
Yep waiting to see what this looks like on an OEM hood before I order
Old 10-16-2012, 04:51 PM   #6
CyberBri
BRUCE WAYNES DD
CyberBri's Avatar
Drives: 2010 2SS/RS CGM
dont wanna cut my hood up...
JBA 1 7/8 LT`s, High flow mids, and Cat back,Airaid intake, JRE Tune, & alot of flat black....
CyberBri is offline   Reply With Quote
Old 10-16-2012, 04:54 PM   #7
mgaspari
mgaspari's Avatar
http://www.camaro5.com/forums/showthread.php?t=246271
than dont.. they have two options.
Old 10-16-2012, 07:44 PM   #8
01pewterz28
Camaro Junkie
see if you can find another hood same color as yours 4-sale in your area
Old 10-17-2012, 02:58 AM   #9
11 Camaro IBM
Drives: Camaro IBM
I'm sold already can't wait to order
11 Camaro IBM is offline   Reply With Quote
Old 10-17-2012, 10:03 AM   #10
overhaulengines
overhaulengines's Avatar
Drives: Red 2SS/RS M6
i can vouch for ACS, i have installed many of their products, I'm currently installing T3 ports, lights pods for the ports, and hood vents on a customer car. ACS products are top notch, quality is top of the line, built to outlast the car.
lupe
overhaulengines is offline   Reply With Quote
Old 10-17-2012, 11:43 AM   #11
bmbbl be
bmbbl be's Avatar
Drives: 2010 CAMARO SS
i have a maggie blower ,,,will this interfere with the CAI tube??
bmbbl be is offline   Reply With Quote
Old 10-18-2012, 01:38 AM   #12
BronxxBombers213
BronxxBombers213's Avatar
Drives: 2010 Camaro 2SS RS
this would be really cool hydrodipped
BronxxBombers213 is offline   Reply With Quote
Old 10-19-2012, 01:51 AM   #13
walhan_qtr
..[ Z06-QTR ]..
walhan_qtr's Avatar
Drives: '10 Camaro 2SS RS M6/ 07 C6 Z06
Send a message via MSN to walhan_qtr Send a message via Yahoo to walhan_qtr Send a message via Skype™ to walhan_qtr
I am interested to see the final product. I think it will turn out good. if the price is right I bet you will sell a LOT of these!
- 07 Silver C6 Z06, Darton sleeved LS7, 441ci, H/C/I, Duel Stage Nitrous, RPS BC3, TR6060, E85. (615whp/582wtq N/A)
- 09 Blk Z06, 427ci LSX, F2 Procharger, Brodix, Holley, ZR1 TR6060, ... (1204whp/1045wtq @ 24psi)
- 06 Blk C6, Darton Sleeved LS2, 427ci, H/C/I, F1X, RPM Trans/Diff, RPS BC3. (New #s soon)
- 10 Black Camaro LS3, 2SS/RS, H/C/I, bolt-ons, Spec. (470whp/450wtq).
- 07 Black Corvette C6(SOLD).
- 98 White/Red Corvette C5(SOLD).
walhan_qtr is offline   Reply With Quote
Old 10-19-2012, 01:52 AM   #14
PonyKiller74
PonyKiller74's Avatar
Drives: 2012 Triple Black ZL1 M6
Send a message via AIM to PonyKiller74 Send a message via Yahoo to PonyKiller74
bookmarked
CenterForce DYAD Dual Disc Clutch, JDP stage 2 Clutch Reservoir, Rotofab CF CAI with Big Gulp and WW Reservoir Relocate, Stainess Works LT Headers and Retro Cat-Back with Cat Delete, MGW ST Shifter with custom Knob, CF Tail light Bezels, more to come...
Build Thread for my Z is in the works.....
PonyKiller74 is offline   Reply With Quote
acs, acs composite, ss hood ports, tl1, zl1 hood insert
