SDTW Custom Wheels & Tires
Old 10-10-2012, 11:50 PM   #1
BowenSS1
BowenSS1's Avatar
Drives: She totaled it!
GLOWING RED HEADERS AT IDLE
Just as the title states....I noticed tonight while hood was up car idleing for less than 5mins....the 5,6,7,8 are glowing red I never noticed that before...could there be a problem...Thanks
BowenSS1 is offline   Reply With Quote
Old 10-10-2012, 11:52 PM   #2
BowenSS1
BowenSS1's Avatar
Mods are bolt ons with Maggie cam stall
Old 10-11-2012, 05:48 AM   #3
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Tampa Orlando Dyno Tuning Camaro Corvette CTS-v GTO GM Trucks performance tuning
was it just after some very hard driving?
what type of headers, CATs, and how much boost are you running.
Phil
Tampa Tuning is offline   Reply With Quote
Old 10-11-2012, 05:49 AM   #4
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Headers get dang hot and add allot of under hood heat. Common for them to glow. You just notice more in the dark if the hood is up.
Scott@Bjorn3D is offline   Reply With Quote
Old 10-11-2012, 06:15 AM   #5
hapisok
crazier than a coconut
hapisok's Avatar
Drives: 2010 2SS/RS LS3
do you monitor your AFR? the rear cylinders generally run leaner than the fronts, just wondering if too lean can cause this condition and therefore your headers are running hotter.
hapisok is offline   Reply With Quote
Old 10-11-2012, 07:31 AM   #6
BowenSS1
BowenSS1's Avatar
There was no hard driving before hand.. it hadn't even been turned on all day....
Im running big flow exhaust 1 7/8 headers,no cats ,9LBS boost.
I do not have a/f gauge or boost gauge
I just thought it was strange to get that hot in less than 5 mins ...
Hell it melted the plastic protector over the Maggie water line on passenger side.
Old 10-11-2012, 11:52 AM   #7
CyberPredator
50 Shades of Prey
Drives: TT/SS
maybe some sort of blockage although I don't know what it could be since there are no cats. Pretty odd for them to glow without being ran hard
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
Old 10-11-2012, 11:58 AM   #8
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Cam dumping lots of raw fuel in the exhaust at idle, burning off in the headers? Do your eyes burn from the exhaust?
Iam Broke is offline   Reply With Quote
Old 10-11-2012, 12:21 PM   #9
MR 45TH
Drives: 2016 2SS
Originally Posted by BowenSS1 View Post
9LBS boost, I do not have a/f gauge or boost gauge
Gauges would deff be my next mod
ProCharger P1-X
542hp 528tq on 6PSI
MR 45TH is offline   Reply With Quote
Old 10-11-2012, 12:39 PM   #10
MA2010SS
Drives: 2010 Camaro SS
What causes that is (1) a lean fuel mixture, (2) timing retarded too far at idle or a combo of both. Usually I have seen one side or the other glowing red, but never 2 cylinders on one side and 2 on the other side. Basically what's happening is there is not enough fuel in the chamber to cool it when it's lean or the timing is too far retarded and then combustion is happening too late and raw fuel gets pumped out the exhaust. Let us know what you find
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 10-11-2012, 07:13 PM   #11
BowenSS1
BowenSS1's Avatar
Called tuner they said drive car around then park and pop hood and check
If they are red.... well I did.....car runs great when i get home i leave car running pop hood
And headers are fine....but once it starts lopeing they turn red again....
so i will let them know Fri. See what they say...??
Old 10-11-2012, 08:46 PM   #12
MA2010SS
Another thing to check is to use an IR meter, one that goes up to 1000 deg F. I am running a whipple and across the board my header temps at idle are between 425 and 470deg on all eight cylinders, check the temp at all pipes
Old 10-12-2012, 02:03 PM   #13
CamaroRBT
Who's Laughing Now?
CamaroRBT's Avatar
Drives: 2011 Camaro 1SS RS LS3 Summit White
Lean
CamaroRBT is offline   Reply With Quote
Old 10-12-2012, 03:13 PM   #14
Russell James
Russell James's Avatar
Drives: Camaros
I think every aftermarket supercharged car needs an AFR gage on a wideband O2. Without being able to monitor that AFR everybody is just guessing. I'd get it back to the tuner, work on the tuning, and install an AFR gage.
Russell James is online now   Reply With Quote
