SDPC
Old 10-11-2012, 04:41 PM   #1
Godsplumber
Godsplumber's Avatar
Drives: 2012 ZL1,Victory Red
Does anyone have or considered having water/meth injection
If so what do you think about it? What system are you running, what do you recommend? If not, why not?. Let me know what you think.
Godsplumber is offline   Reply With Quote
Old 10-11-2012, 07:24 PM   #2
Z69
Z69's Avatar
Drives: ZL1 ,TT 03 cobra,69 camaro
Not recommend the meth eats the coating on the rotors of the super charger
Z69 is offline   Reply With Quote
Old 10-11-2012, 08:35 PM   #3
Godsplumber
What about just water
Old 10-11-2012, 09:02 PM   #4
1MtnGoat
1MtnGoat's Avatar
Drives: '12 SIM ZL1, 1 of 49
Probably will do the same. At rate of speed the rotors spin it would be like pressure washing only the rotors are hitting the water droplets.
1MtnGoat is offline   Reply With Quote
Old 10-11-2012, 09:20 PM   #5
hognutz
hognutz's Avatar
Drives: 2013 ZL1
the rotors are teflon coated I do believe and depending on how the mixture atomizes it can strip the coating off.
Now if you reasearch it you will see not everbody has the same opintion of how important the coating is.
I would call eaton and snow if you really want to run meth. I think I am liking the chiller solutions better for this car.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 10-12-2012, 06:54 AM   #6
Drew P
Drew P's Avatar
Drives: Camaro ZL1
Pros: Large potential power for relatively cheap price (octane/cooling effect)
Cons: If your pump(s) fail, you will probably rebuild your motor.
As to the coating, I have not talked to Eaton directly, but found that the coatings are in fact designed to aid the wear-in process of the rotors. This said, some shops actually completely strip the coatings. I think the real fear is that the coatings will come off while using meth/water and be ingested into the engine.
If anyone has any different/additional thoughts, I too would be interested to hear them.
I have largely held off from this for fear of pump failure. Does anyone know if a two pump (redundancy) system exists?
Drew P is offline   Reply With Quote
Old 10-12-2012, 12:10 PM   #7
Godsplumber
For some reason i feel the consensus would be to not run water/meth. Rebuilding an engine doesnt sound like something i want to do.
Old 10-12-2012, 01:02 PM   #8
bumblebeecamaro
Car Lover By Nature
Drives: Mini Cooper S
there's some comments in this thread that seem to be from uneducated people when it comes to water/meth injection.
first of all, water/meth has been around and has been used for a long time by a lot of people. I have yet to hear anything negative in terms of wearing this so called coating off rotors. if in fact that was the case, then why haven't these stories came about?
second, water/meth injection is completely safe as long as people don't tune the application where it is dependent on the water/meth system. it's one and only sole purpose is to cool the incoming air mixture which in turn helps to prevent or at least slow down detonation. but no tuner in his or her RIGHT MIND should ever tune an application where it's dependent on the benefits of water/meth.
bumblebeecamaro is offline   Reply With Quote
Old 10-12-2012, 05:00 PM   #9
Z69
Z69's Avatar
Trust me I have seen it....the coating will come off and get ingested by the engine. I'll see if I could get some pics. If not do a googel search for your self and you will see the damage to the coating
Old 10-12-2012, 06:14 PM   #10
SC2150
Z69 is correct.
Go with the RX Super Chiller. Install is easy and no $ to spend afterwards....it just does its job.
Old 10-13-2012, 05:02 PM   #11
Godsplumber
I would really like to see more about this
Old 10-13-2012, 05:27 PM   #12
Godsplumber
Originally Posted by SC2150 View Post
Z69 is correct.
What are the comparable benefits of each and what ranks better? What are the differences in benefit, ie.. power, etc? What are the cons of each?
Old 10-13-2012, 05:30 PM   #13
dangjohnny
Drives: 2013 Evolution GSR
Try it. I'd like to see the results!
dangjohnny is offline   Reply With Quote
Old 10-13-2012, 10:06 PM   #14
hognutz
hognutz's Avatar
Drives: 2013 ZL1
If you just tune the car normal and use meth to reduce you temps you will never blow a motor due low fluid or pump or injector failure
As far as eating the coating it will but that is why I would talk to eaton. Not listen to people on the web. That coating be designed to naturally wear overtime for all we know.
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
