Old 10-11-2012, 07:03 PM   #1
Chrisco22
Chrisco22's Avatar
Drives: 2011 Chevy Camaro LS
E 85?
Was wondering if anyone has gone with the E85 tune from trifecta as of yet. Im people have, but was looking for input on it. I am seriously considering it now that its not my daily driver anymore. The few questions/concerns i have are as follows..
1) Gas mileage?
2) Noticeable power increase?
3) Smells good?
Any/all input welcome.
Thanks
2011 Camaro LS: [Rally Yellow] [22" Status Rims] [BBK Long Tube Headers w/ High Flow Cats] [Trifecta Tune] [K&N CAI] [Blacked out Bow Ties and Tail Lights] [15% Tint] [MAC Mufflers] [Rear Cat Delete] [Vmax Black Ice]
Chrisco22 is offline   Reply With Quote
Old 10-11-2012, 08:07 PM   #2
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Running E47 and seeing 80% Injector Duty Cycle at WOT. Doubt there is enough stock injector to pull it off. I also see fuel rail pressure dropping to ~50psi from 58 on the 1:1 mix of 93 & E85.
I don't believe in running over 80% IDC. Running PE of .84 lambda and Stoich of 11.97.
K&N Intake, Solo HF Cats, MBRP 3" X-pipe exhaust & tune.
The E47 is ~99 octane and performs well. Since it's not my DD I don't mind blending it. 27* advance at 6k and no knock retard.
E85 takes ~30% more fuel than pumpgas so your mileage will suffer. I see 18-19mpg on E47.
Vince is a great guy, I helped him work on the E85 tune for the 4 cyl turbo LNF in Cobalts. It has fueling issues stock with E85 as well. I never could get the LNF over ~70% E but it was a DI engine. He might be able to tweak the fuel pump up, IDK.
Iam Broke is offline   Reply With Quote
Old 10-11-2012, 08:17 PM   #3
Chrisco22
Chrisco22's Avatar
I already get 16.2 average mpg these days. But since i bought a bike, ive saved over 1k miles this month on the car. looking for more power. and i like the smell. figured why not give it a shot.
Old 10-11-2012, 08:22 PM   #4
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
1) Gas mileage?
3) Smells good?
Thanks
1) E85 has about 28% lower energy content than gas, so you can expect that much of a fall in per gallon economy.
2) Probably not much more than a normal tune unless you have other mods that require/can make use of the extra octane.
3) Vapors coming from the tank when you will up will smell like sugar.
Also, over the long run, the E85 may prove corrosive to anything it touches since these cars aren't engineered and made out of alloys designed for high ethanol content.
"Proven V-8 power with better efficiency than a turbo V-6"
"The car is the closest thing we will ever create to something that is alive."eds.
fielderLS3 is offline   Reply With Quote
Old 10-12-2012, 03:08 PM   #5
hapisok
crazier than a coconut
hapisok's Avatar
Drives: 2010 2SS/RS LS3
there is some good info if you do a search for E85 in the LLT section.
http://www.camaro5.com/forums/showth...&highlight=E85
good luck!
hapisok is offline   Reply With Quote
Old 10-14-2012, 09:40 PM   #6
'11CamaroLS
'11CamaroLS's Avatar
Drives: 2011 Camaro LS
ive been running E85 for about the past month now,
1.) my mileage is barely effected. My average mileage is 17 mpg at an average of 25mph. where as on the regular trifecta tune i was maybe more like 18. no where near a 28% loss in mpgs.
2.) For sure a nice power increase. when tuning for the first time to the reg. trifecta tune i could feel the diffrerence, and going from the reg tune to E85 i can for sure feel a difference. It is dyno proven to make more hp then the reg trifecta tune.
3.) honestly i dont really notice the difference in smell much. it is a sweeter smell
'11CamaroLS is offline   Reply With Quote
Old 10-14-2012, 10:37 PM   #7
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
I had an e85 race tune I ran after the cam. Plenty of injector, but out of pump past 6k rpm. A zl1 drop in pump would be the cure. Stock injectors on the ss are 42lb/hr. The same used in the ls7. I have taken those injectors past 600 rwhp naturally aspiriated on 93 octane. They will support low to mid 500's on a full e85 mix.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 10-17-2012, 11:14 AM   #8
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
No way your getting about the same mpg. Also your not going to gain much power on a stock car tuning for e85....
JLE58 is offline   Reply With Quote
Old 10-17-2012, 12:27 PM   #9
swiftkart
swiftkart's Avatar
Drives: 2010 SS/RS LS3 M6
Who says you can't gain hp, E85 is 33% oxygen and does make more power tuning on a stock engine, I haven't tune my LS3 M6 yet, but I have my ZX14 Motorcycle and gained 8rwhp with it, 175rwhp to 183rwhp.
swiftkart is offline   Reply With Quote
Old 10-18-2012, 08:33 PM   #10
JLE58
I clearly said your not going to gain MUCH tuning for it on a stock car. If I'm going to pay 500 dollars for tuning a stock car It wouldnt be to gain 10 hp from e85.
