Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Technical Camaro Topics > Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection
Old 10-12-2012, 08:44 AM   #1
Todd@Autopia's Avatar
Drives: 2010 Mazdaspeed 3
Nanoskin AutoScrub Video
Fast & Quick Paint Cleaning with Nanoskin AutoScrub! - YouTube
The AutoScrub Foam Pads are available in both a fine grade and medium grade.
Works with a DA polisher to reduce claying time significantly
Lasts up to 4 times longer than clay bars
Washable and reusable, you can even drop it on the ground
Nanoskin AutoScrub 6” Foam Pads turns your Random Orbital DA Polisher into a gentle paint cleaning tool! Spend less time and effort getting the showroom finish you deserve! The Nanoskin AutoScrub 6” Pads use the latest advanced rubber polymer technology to replicate the paint cleaning action of a clay bar while taking advantage of time saving ability of a machine polisher. The result is perfectly clean paint, ready for polishing or waxing, without breaking a sweat!
Shortly after leaving the factory, your vehicle is bombarded with airborne pollutants and contaminants that ruin the smooth feel of paint, limit its shine, and prevent waxes and paint sealants from bonding properly. In the old days, body shops and detailers would use aggressive compounds and a wool pad to clean the paint. Next, natural and synthetic clay bars where developed to clean contamination and overspray. Detailing clay is still the tool of choice, and for good reason. You can clean your paint without damaging it, unlike the compounds of yesterday.
Nanoskin AutoScrub 6” Foam Pads are the next generation in gentle paint cleaning. They work much like detailing clay, but with several advantages. They attach to your Random Orbital DA Polisher the same way a polishing pad does. The rubber polymer side acts in the same manner as detailing clay, safely removing mild contamination and pollutants. A Nanoskin AutoScrub 6” Foam Pad can last up to four times longer than traditional detailing clay and rinses clean in water. Drop it on the ground? No problem, rinse off and keep working!
Wash and dry your car completely. Attach a Nanoskin AutoScrub 6” Foam Pad to your Random Orbital DA Polisher. Work a section at a time on low speed (1-2) and use light pressure. Mist diluted Nanoskin Glide (or your favorite clay lubricant) on the section and work in overlapping passes until the paint is smooth. Wipe away residue with a soft, clean microfiber towel before moving to the next section.
Old 10-12-2012, 10:23 AM   #2
Drives: 2010 Camaro 1SS
How much is this?
2010 Camaro 1SS Inferno Orange Magnusson Supercharger Installed and Tuned by ADM Performance, Roto Fab CAI IOM painted, MBRP Cat Back Exhaust, Barton Industries Short Shifter, Clear Image Headers, Pedders coilovers, BMR Front/Rear sway bars Trailing Arms and End Links, VMax ported TB
Coop is offline   Reply With Quote
