Cold Air Inductions
Old 10-12-2012, 08:53 AM   #1
10BlkSS
10BlkSS's Avatar
Drives: 2010 Camaro SS
bumper indentation
So out if nowhere there's a 2" long vertical indentation around where the plat would be (don't have or want) it appears something like another cars plate cover pressed up against it and u can see the line at most angles when looking for it. No paint issue. What could I do short of replacing it repainting to repair this? Its one of those things where I'm torn between cost/benefit...ideas?
Maxima SE (Traded)
Camaro SS
Hummer H3
10BlkSS is offline   Reply With Quote
Old 10-12-2012, 08:56 AM   #2
PIPE
Hating prius's since 1997
PIPE's Avatar
Drives: 2010 Camaro 2SS/RS (JENNA)
The bumpers are plastic. Take it to a good Bodyshop and they can heat it and pop it right out or try it yourself. Just takes a lil heat to get it plyable.
PIPE
PIPE is offline   Reply With Quote
Old 10-12-2012, 10:01 AM   #3
10BlkSS
10BlkSS's Avatar
You think heating it would get t vaback to normal by itself? I was thinking of it but don't want to make it worse...its right under the bowtie so I can't get behind it...u think just hitting it with a hairdryer and pressing on the front would help? Its not going to pop, its like indented slightly.
Maxima SE (Traded)
Camaro SS
Hummer H3
Old 10-12-2012, 10:55 AM   #4
DangerZL1
Drives: Accord
I've got a place on the front of my bumper where I indented it by hand removing a rock nick. I took it to the dealer and their bodyshop guy tried to remove it with a heat gun held some distance back and pushing from behind the dent, but it didn't work. I was suprised that I damaged the bumper that easily. I've removed or reduced indentations by using heat before on my Honda. A hair dryer isn't going to hurt the paint and is certainly worth a try.
DangerZL1 is offline   Reply With Quote
Old 10-12-2012, 11:34 AM   #5
10BlkSS
10BlkSS's Avatar
Ok...and if.i botch.it somehow, hello front liscence plate =(
Maxima SE (Traded)
Camaro SS
Hummer H3
