Solo Performance
Old 10-12-2012, 10:00 AM   #1
agent5
Drives: 2013 Camaro SS (+RS) + Hurst+ DME
New car, parked under a tree that piled tree sap on my car..
Hi Everyone,
The other day I did a mistake of parking under a tree that created a mist of tree sap on my car, it was everywhere as if someone sprayed it on. When I noticed it I tried to wipe it down as much as I could at home with a moist rag, I probably got 80% off but it was night time so it was hard to see. The following day I washed the car down as well as I could but there are still some annoying drops here and there.
Anyone have a suggestion how to safely get rid of it? The car is just 3 weeks old so this is super annoying.
Thanks in advance!
agent5 is offline   Reply With Quote
Old 10-12-2012, 10:13 AM   #2
matthook
matthook's Avatar
Drives: 2012 IBM Camaro 1LT RS
This happened to me when i had my grand prix... except i did nothing to it all fall/winter and finally tried to get the sap off in the spring... bad decision...
Whatever you do, dont use a clay bar to try to get it off, some people may suggest that. I tried to use a variety of things, including the clay bar, but when i got the sap off with the bar, the paint ripped right off with it too... but this could be because it was so caked-on for so long. Not sure what you could try dude; but im sure theres some kind of wash or spray that would work well
-Xbox Live: MattCaptainH00K (0s are zeros)-
Team LFX Thread Link: http://www.camaro5.com/forums/showthread.php?t=187109
Team LFX Group: http://www.camaro5.com/forums/group.php?groupid=306
matthook is offline   Reply With Quote
Old 10-12-2012, 10:16 AM   #3
AdamZ
Drives: Eve - 2011 Camaro 2SS/RS
Dawn soap. Scrub with Dawn + warm water...let it sit for a little bit...then rinse...should come right off.
AdamZ is offline   Reply With Quote
Old 10-12-2012, 10:17 AM   #4
dkp2LT
dkp2LT's Avatar
Drives: '10 2LT/RS, '13 GT/CS, '10 Flex
^^ if you use dawn then I would recommend polish w/ a PC & wax.
dkp2LT is offline   Reply With Quote
Old 10-12-2012, 10:20 AM   #5
AdamZ
This
Old 10-12-2012, 10:25 AM   #6
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Yes, Dawn will work but will strip any wax that's presently on the car.
Try Comrando's suggestion.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 10-12-2012, 10:52 AM   #7
agent5
Thanks so much for all the replies. I'll try the Turtle wax tar/bug remover and let you know. The good news is I got probably 90% off just by catching it on time before it dried or had a chance to "bake" in the sun.. That's the disadvantage with black, I guess, you see EVERYTHING.
Old 10-12-2012, 10:54 AM   #8
IrocJack
IrocJack's Avatar
Drives: 2010 2LT/RS RJT
WD 40 and some elbow grease.
IrocJack is offline   Reply With Quote
Old 10-12-2012, 10:56 AM   #9
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: Roxanne (COTW 11/26/12)
Sounds like the tree got excited. These cars are pretty hot...
soloknight6 is offline   Reply With Quote
Old 10-12-2012, 11:12 AM   #10
agent5
Indeed, she is beautiful. I finally got a photo from when I picked it up :-)
Old 10-12-2012, 11:14 AM   #11
dorfmac
www.macsautodetail.com
dorfmac's Avatar
Drives: 2010 2LT/RS
try using plain, alcohol based sanitizer. i use a small drop to get rid of any blemishes i have trouble with.
dorfmac is offline   Reply With Quote
Old 10-12-2012, 11:21 AM   #12
Jim968
Jim968's Avatar
Drives: 2013 2SS RS
When everything else fails that usually works. Just make sure to re-wax afterward.
Jim968 is offline   Reply With Quote
Old 10-12-2012, 11:22 AM   #13
bhall82
Drives: 2011 SS/RS
Brillo pads work well
bhall82 is offline   Reply With Quote
Old 10-12-2012, 11:24 AM   #14
Hitman84
Hitman84's Avatar
Drives: 2013 IOM 2LT
isn't goo gone advertised to remove tree sap? And it's known to be safe for cars.
Hitman84 is offline   Reply With Quote
