JDP Motorsports
Old 10-12-2012, 09:38 PM   #1
Lisa/Jeff
Drives: 2012 Rally Yellow 2ss
Question A/C Off Due to High Engine Temp
Just returned from the dealer for second time for the A/C off due to high temp message. The first time they replaced a sencor and this time could not find anything causing message. They contacted GM and GM suggested to check wiring but still no know cause. I asked about reflashing and they advised no new updates for for car so no reason to reflash. The first time it occured I took the battery cables off for several hours but the message came back. The car is stock, all fluids are good. Any suggestions??
Lisa/Jeff is offline   Reply With Quote
Old 10-14-2012, 04:32 PM   #2
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
hey i had the same issue. I replaced the temp sensor and notices the conector was a flawed design and it was not a tight fit. I changed the pig tail and put a little ele. grease and all is well.
MODS 6.0 forged iron block, Texas Speed Stage3 cam, custom twin turbo, Tripple 450 pumps, DW2200cc injectors, BMR Springs, sways, endlinks, bushings, tailing arm, toe links, DSS aluminum driveshaft, G-Force 1000hp axles, Brake master drilled rotors, ACT twin disk (1550ftlb), MGW shifter, Race Star wheels 17x4.5 with MT front runners 15x10 with Hoosiers, AEM gauges, G-Force II boost controller
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 10-14-2012, 04:55 PM   #3
Lisa/Jeff
Thanks, I will look at the sensor.
Old 10-14-2012, 05:02 PM   #4
tadams72
When is enough ever...
tadams72's Avatar
Drives: 2006 Silverado 2500HD CC/SB LBZ
Location: Residence: Chula Vista, CA Home: Billings, MT
The quick way to reset the sensor is to shut the car down and disconnect the ECM Harness by the fuse box under the hood (front engine compartment, passenger side). I still don't know the cause of this but have had it several times myself.
The Project: 2011 Camaro 2SS/RS (ERL 427 Superdeck NA Monster)
"Just like farmer engineering. Find the weak link and fix it, then find the next one." Salt Cat Racing
tadams72 is offline   Reply With Quote
Old 10-15-2012, 01:34 PM   #5
Chevrolet Customer Svc
Drives: GM Vehicles
If you would like for us to research this further for you, please provide us with your first and last name, address, phone number,VIN, mileage and involved dealership. We would be happy to see if there are any options available to you!
Brandon
Chevrolet Customer Service
Chevrolet Customer Svc is online now   Reply With Quote
Old 10-16-2012, 09:00 PM   #6
Lisa/Jeff
Brandon,
I'm not sure how to provide you the requested information without posting all of it on the site.
Old 10-17-2012, 08:58 AM   #7
Drives: GM Vehicles
Brandon,
You can click my username and then click send private message.
Brandon
Old 10-19-2012, 11:45 AM   #8
SteveRS
SteveRS's Avatar
Drives: 2010 SIM Cobalt SS
Send a message via AIM to SteveRS
My 2011 LT/RS was the first case to have this issue.. i still have the pictures from it.. they will most likely change out the PCM and that will fix it.. changing the Thermo will most likely not fix it cause it didnt fix mine..
2011 Imperial Blue 1.5SS
2010 Silver Ice Cobalt SS
SteveRS is offline   Reply With Quote
Old 10-19-2012, 07:07 PM   #9
Lisa/Jeff
When we had it at the deal, they could not find what was causing the message
and spent several minutes on the phone with GM and still no fix. GM has called and left me message but I haven't been able to speak to anyone yet.
Old 12-05-2012, 11:30 AM   #10
DeMaro
Drives: 2017 Camaro ZL1 Coupe
I have the same problem also still not resolved. Never had an issue on my 2010 coupe but my 2012 Vert has had it since 500 miles or so.
DC
2017 ZL1 Vert M6, 2015 R8 Vert 4.2 M6, 2017 RS7 Perf, 2018 S5 Coupe, 2014 Jeep JK Rubi X unlimited 3" lift Procomps-Nitto 35's, 6.4 Hemi w 6 spd man 238 Getrag trans, 2016 Denali XL
Expired -Y2K SS Vert, 427 Darton w/D1SC 720 rw, 620 tq
"When parts exceed the whole.....you have mod fever!"
DeMaro is offline   Reply With Quote
Old 12-05-2012, 07:48 PM   #11
Lisa/Jeff
A/C Off due to high temp
After about 6 months we think we have our problem fixed. We were near a dealership when the message came on and according to the code it was a bad thermostat sensor. They replaced the thermostate Kit (01246-PCKT) The code was PO128. Plus for some reason when I picked the vehicle up, they had put 6 miles on it, not sure if that was necessary. I hope this took care of the problem!
Old 12-06-2012, 08:52 AM   #12
Drives: GM Vehicles
DC
DeMaro,
We apologize for any frustrations that you may be experiencing. I can research the concern you are having further by setting up a case with GM customer service. Please PM me any details you may have along with your first and last name, address, phone number, VIN, mileage, and involved dealership name.
I await your response via PM.
Brandon
Old 12-06-2012, 06:04 PM   #13
DeMaro
Thanks Brandon
I am going to try a few more things and will take you up on that I am sure.
DC
Old 12-07-2012, 08:32 PM   #14
danielblack60
danielblack60's Avatar
Drives: 2016 Camaro 1SS A8, 1998 K1500 5spd
It is untelling how many times I've had this customer concern. Every time I scanned one, the code was p0128. Engine coolant temp below threshold. Replaced thermostat and it was like it never happened
Not saying you all are having different troubles, but 98.3456 times out of 100 a thermostat will fix your problem.
PS: winter months are usually when you see thermostats start to fail, just food for thought.
*2016 1SS A8-12.100 @115 Bone Stock.
11.54 @116 with cat delete, converter and dr's
Previous Rides
2010 Camaro 1SS M6-12.14 @114 Bolt Ons
2014 GMC Sierra SLT 5.3/6L80
danielblack60 is offline   Reply With Quote
