Jason 98 TA
Old 10-12-2012, 11:02 PM   #1
epkmvuoq
Drives: 2ss red m6
Decrease in performance
Approx. how many miles should a ls3 have before performance starts to decrease ?
epkmvuoq is offline   Reply With Quote
Old 10-12-2012, 11:13 PM   #2
L99CAMA2011
L99CAMA2011's Avatar
Good question. I heard across the board though that GM pushrod motors are very reliable.
Old 10-13-2012, 12:28 AM   #3
epkmvuoq
Drives: 2ss red m6
What I'm asking is if your running 12.9 at 15,000 miles how well would it run with 50,000 miles ? Will the performance decrease with the added mileage ? Approx when will it be noticeable ?
Old 10-13-2012, 12:39 AM   #4
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
With proper maintenance and all that stuff, no reason it couldn't go well beyond 100K before any meaningful drop-off.
"Proven V-8 power with better efficiency than a turbo V-6"
"The car is the closest thing we will ever create to something that is alive."eds.
fielderLS3 is offline   Reply With Quote
Old 10-13-2012, 12:51 AM   #5
epkmvuoq
Drives: 2ss red m6
Wow ,,,,,,, I thought it would have been much sooner
Old 10-13-2012, 01:06 AM   #6
fielderLS3
fielderLS3's Avatar
I think what matters is what overall condition the engine is in, not simply the miles. I did a couple 1/4 mile runs with my Oldsmobile back when it had around 75K on it. The acceleration numbers to 70 mph were identical to the Motor Trend results when they tested one new, and the 1/4 mile time/trap speed of mine was actually marginally better (though perhaps I had a slight tailwind).
Old 10-13-2012, 01:35 AM   #7
james347
Drives: 2006 Crownline
Totally agree. Well maintained and you should see a long life out of these motors.
james347 is offline   Reply With Quote
Old 10-13-2012, 08:42 AM   #8
epkmvuoq
Drives: 2ss red m6
Thanks,,,,,, I'm surprised,,,,, had no idea !!!!
Old 10-15-2012, 09:05 AM   #9
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
If well matained it will run FASTER with 30-75k miles on it... after a 100k it may fall off a bit, but not much. Trans condition and rear end condition will play a big role in this also! If you dont take care of them, it will effect the performance more then any power lost at the crank.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 10-15-2012, 10:49 AM   #10
SC2150
The rings should be seated properly in the first 500 or so miles if driven hard enough, but most drive easy and the M1 full synthetic is so protective that many dont get seated properly and thus the oil consumption issues. As for power, the V8's are still port injected so the intake valves will remain clean and fairly deposit free if using top tier fuels so as long as you change oil regularly, clean air filters, etc. expect 200-300K plus miles w/no issue. We tear the LS motors down with tons of miles on showing little to no wear so these will go as long as you care to .
Old 10-15-2012, 05:02 PM   #11
epkmvuoq
Drives: 2ss red m6
I think I broke it in right. After 15 to 20 passes and 3200 miles it uses less than a half quart in the 3200 miles. I think the rings are fine with that being said.
I had no idea,,,, I would have guessed power would fall off at 75k. Thanks so much,,,,
