BeckyD@RodgersChevrolet
Old 10-14-2012, 05:15 AM   #1
Lio Martinez
SoCal HT5!!!!
Lio Martinez's Avatar
Drives: 2013 Camaro 2SS RS 1LE IMO Turbo
1LE strut brace or Hochkiss max stru bar??
Since the 2013 Camaro 1LE already cones with the GM strut brace also used on the convertible Camaro.:.. any idea regarding if switching it for the Hotchkiss max strut bar will increase handling... Or is it just better as it is ? ?
Also anyone side switching the stock springs to performance lowering springs...? Since the ones that come in the 1LE are the same as the SS .
Lio Martinez is offline   Reply With Quote
Old 10-14-2012, 06:31 AM   #2
SUKXOST
Do you even lift, bro?
SUKXOST's Avatar
Drives: 2013 1LE Camaro
I already have Pfadt's springs sitting in my garage :P
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461
SUKXOST is offline   Reply With Quote
Old 10-14-2012, 11:25 AM   #3
Doglife1LE
Drives: 2013 1LE, 2004 Silverado
Sweet! We are going to need some before and after photos plus a quick review on the differences between the two.
Doglife1LE is offline   Reply With Quote
Old 10-14-2012, 12:34 PM   #4
Lio Martinez
SoCal HT5!!!!
How much do those lower the car ?
Old 10-14-2012, 04:31 PM   #5
Lumino1LE
Rally Yellow 2SS/RS/SR
Lumino1LE's Avatar
Drives: Born 11/12 2012 Camaro 2SS RS 1LE
Higher cost/Famous brand strut bars don't improve performance. Remember that the main purpose of the strut bar is to reduce chassis flex. The one that comes from GM/Chevy will do the job.
Don't waste your money.
Lumino1LE is offline   Reply With Quote
Old 10-14-2012, 08:30 PM   #6
caverman
caverman's Avatar
Drives: '69 SS Convertible
Not only that but Justice Pete recommends not running one at all.
Build Journal
Old 10-15-2012, 04:18 PM   #7
toehead93
Drives: 2014 2SS/1LE
Yes, but this car is balanced and designed with one, the regular SS is not and adding a struct bar could upset the balance.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 10-15-2012, 08:49 PM   #8
Lumino1LE
Lumino1LE's Avatar
No offense, but no. A strut bar is going to add rigidity to the front of the car to give you better control. If you're only street driving, it won't matter. If you're tracking the car, it makes a huge difference.
Old 10-15-2012, 08:52 PM   #9
Lio Martinez
SoCal HT5!!!!
I also think the strut bar makes a huge difference in handling.... And it probably be good to keep it like it is but in a regular SS without one I bet the Hotchkiss will be great.. I'm talking cause i had the sane one on my v6 and it fits v8 also.. but sold it this weekend already so I'm keeping tge stock one
Old 10-15-2012, 08:59 PM   #10
z28racer
z28racer's Avatar
Drives: 12 SIM 2SS/ RS Sinergy M6,GMC2500HD
z28racer is offline   Reply With Quote
Old 10-15-2012, 09:03 PM   #11
Lio Martinez
SoCal HT5!!!!
Originally Posted by z28racer View Post
Well Thanks so much for those helpful faces
Old 10-15-2012, 09:25 PM   #12
Synner
Drives: not stock
Save the money on the brace and get a performance alignment, you'd get far more benefit. Would there be a marginal difference in stiffness between OEM and tubular steel? Yes. Would you achieve much of a difference? Nope.
Or save up for a down payment for coilovers. Best track day purchase ever. Springs will always be a compromise to stock valving if you're serious about going fast and flogging it at track days.
Synner is online now   Reply With Quote
Old 10-15-2012, 09:33 PM   #13
toehead93
I know this, but i was agreeing with caverman that pete said for an SS they do not recommend the strut bar because it makes the front too stiff. The 1LE is a different story as it is designed and balanced with a bar.
2010 2SS A6 - sold.
Old 10-15-2012, 10:43 PM   #14
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
I added the GM strut brace and it works fine. Not stiff and you do notice a subtle difference in the front, slightly quicker turn in and the front is more solid over bumps and more composed.In ther auto x I didnt notice anything much as the car understeers way to much still in stock form. As far as to stiff, the 1le has the same springs and bigger bars so cant see how it hurts. Bigger bars going on it anyway.
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Pedders Supercar coilovers and Pedders 27mm/32mm sway bars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/430 RW HP/TQ
VR Baron is offline   Reply With Quote
