sjm autoprod
Old 11-28-2012, 07:57 AM   #127
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 18ZL1 02Z-28
no 1 piece aluminum driveshaft?
STRONG BASELINE #s BTW. How many miles were on the car when you did a baseline? LS engine are famous for loosening up after a few thousand. I'm thinking the electric power steering and the NPP opened up a few HP(compared to 10-12 LS3s).
2018 MBM ZL1 6spd Coupe https://youtu.be/fM9silIzdcI
02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub35K orig miles. https://youtu.be/h6faSdcvNew
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 11-28-2012, 09:08 AM   #128
BlkSlvrdo129
Drives: 2008 Silverado
Are the NPP mufflers normally closed on the inside pipe? And the engine vacuum opens them? Or is it the opposite?
BlkSlvrdo129 is offline   Reply With Quote
Old 11-28-2012, 11:01 AM   #129
Bad@ssCamaro
Rogers' Rocks :-)
Bad@ssCamaro's Avatar
Drives: 2015 1SS/1LE
Originally Posted by SUKXOST View Post
TOMORROW:
Wire in the gauges, finished bolting the intake together, Bolt on the strut bar, put the new springs back in, recharge the AC unit, get the alignment done.... oh and by the way we still have to tune it with the chiller kit and run some dynos and make sure everything is working correctly and no leaks or rattles or CEL codes , etc. Then swap out the new tires for the rear in the winter and everything should be done :-) then drive 132 miles home with a raging CHONER
After it's all said and done, you should be sportin' a full one!
2015 CRT 1SS/1LE RS/Recaro's/NPP/Nav/Rear vision pkg./BA speaker upgrade.
ARH 1 7/8 headers, CAI, BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings, DSS driveshaft ...421 whp...so far.
Old 11-28-2012, 01:43 PM   #130
FL1CK
Switchin' n Twitchin'
FL1CK's Avatar
Drives: 2011 Camaro
Gotta let me know when it's done...
I am not childish, you're just being a poopy head!
FL1CK is offline   Reply With Quote
Old 11-28-2012, 06:14 PM   #131
james347
Drives: 2006 Crownline
:upset: Need updates and photos!!! Thank you and have a nice day.
james347 is offline   Reply With Quote
Old 11-28-2012, 06:29 PM   #132
SUKXOST
Do you even lift, bro?
SUKXOST's Avatar
Drives: 2013 1LE Camaro
Today we ran the overdrive pulley in the back and drop to a 3.6 pulley on the front. We made too much boost at 12 pounds on one full pull. We have way more than enough fuel on the stock 1LE pump so tomorrow we will dial in further.
We are going to put the bigger 3.8 inch pulley back on the front to drop the boost to around 10 pounds and tune with that and more timing.
Heading to dinner but I will post a few pictures from the build today in an hour or two.
SUKXOST is offline   Reply With Quote
Old 11-28-2012, 07:26 PM   #133
Jessika
Drives: Anything Blown
SEG!
sent from my Note2 using Tapatalk
Jessika is offline   Reply With Quote
Old 11-28-2012, 07:36 PM   #134
james347
OK now that you have had plenty of time for dinner...... ....... waiting on .......
Old 11-28-2012, 08:35 PM   #135
Jessika
I have video!
Old 11-28-2012, 08:56 PM   #136
james347
Originally Posted by Jessika@SCC View Post
I have video!
Old 11-28-2012, 09:02 PM   #137
SUKXOST
SUKXOST's Avatar
Uploading pics and waiting on video to upload to youtube: pics momentarily :P
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461
Old 11-28-2012, 09:28 PM   #138
SUKXOST
SUKXOST's Avatar
Lowered on Pfadts 1-1 1/4":
About to recharge AC unit for AI Chiller:
ADM Scoop installed(different view):
Catch can and breather installed:
.....FINALLY(only an INITIAL dyno tune....plenty more tomorrow and #'s will change as these two pulls are on 12lbs.)
(red pull was very first pull and we let off early as numbers didnt look right...subtle changed garnered the blue pull #s)
AGAIN....tomorrow will be 10 or less lbs and retuning for safety but Jeff Creech @ Carolina Auto Masters thinks we will have similar numbers with less boost and more timing....time will tell.
By the way......the 1LE fuel pump is MORE than enough to easily push enough through the FIC 850s. (was at like 50% duty cycle if I remember right)
LONG day and I forgot to get a pic of the boost gauges, sorry. :(
Old 11-28-2012, 10:13 PM   #139
james347
Excellent job! Thank you for the pics and video.
Amazing all the work done in such a short period of time.
Old 11-28-2012, 10:18 PM   #140
VanquisherSS
Hasbin of Stock Bottom HP
Drives: CTS-V Coupe, 04 TT Viper
Nice numbers man, sure didn't waste any time with this one!
VanquisherSS is offline   Reply With Quote
