Old 07-25-2013, 05:50 PM   #57
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
Originally Posted by JDP Motorsports View Post
The set up we're offering currently utilizes 3" ducts. Please feel free to call, email or PM me anytime with questions.
Kind regards,
Jordan Priestley
888.308.6007
Jordon, how are you running the 3" ducts to clear the wheels on full lockout? I'm using 2.5" ducts with 10" (offset 35) wheels up front and I barely clear. The ZL1/1LE guys fronts stick out slightly more than mine, but I'm still thinking it's close.
bannonm is offline   Reply With Quote
Old 07-25-2013, 06:06 PM   #58
SPCBA
Drives: pleather and Chiclets
my ducts will be using the bottem useless light on the zl1 front end.. will post pics and modifications done to car to make it work. excited to be able to use the scoop for intake again.
SPCBA is offline   Reply With Quote
Old 07-29-2013, 11:16 PM   #59
BC 2010
BC 2010
Drives: 2010 Camaro SIM 2SS/RS M6 GFX SR
Front Brake Cooling Ducts
Finally had some time to install air inlet ducts at lower grille. Followed intake ducts instruction from bannonm post.
Quantum brake cooling ducts from JDP Motorsports
CTS-V Stage II brake upgrade from JDP Motorsports
Slotted and dimple rotors from Granatelli Motorsports
BC 2010 is offline   Reply With Quote
Old 07-30-2013, 03:15 PM   #60
Synner
Drives: not stock
Pics of the front end back together?
Old 07-31-2013, 12:53 PM   #61
BC 2010
BC 2010
Not sure what you mean.Pictures of front end on camaro with pics of intake
ducts at lower grille mounted at air dam.
Old 07-31-2013, 01:47 PM   #62
Synner
Drives: not stock
Yeah how obvious is it that you have them. I plan on doing a stealth install so they are as invisible as possible. Maybe an up close through the grill and one a bit further back standing at normal height? Thanks.
Old 07-31-2013, 05:18 PM   #63
BC 2010
BC 2010
Look at Post #28 page 2, my are are like that, but my ducting is not that visible because
of color
Old 08-08-2013, 02:03 AM   #64
Rornls3
Drives: 2010 RJTC 2SS RS/SS LS3
Love this thread.....
Rornls3 is offline   Reply With Quote
Old 08-08-2013, 02:36 AM   #65
SummoneR
Paul
SummoneR's Avatar
Very nice!
Old 08-08-2013, 06:51 PM   #66
Mgizzle
Mgizzle's Avatar
Drives: 2013 Camaro 1LE 1SS
3" ducts, driven on street for a few months and had one track day on them. Drove same track in April/May without them on the same pads and tires and brakes held up a lot better this time. Drove one full session full out without any fade or issues (stock pads, rotors....stock car actually plus ducts).
These ducts are a direct run to the rotor hat from the fascia, so the velocity of the air is as good as I can get it. I actually took a leaf blower and had my wife hold it in front of the fascia. The duct was blowing pretty hard, felt like there was no loss in velocity inlet to outlet.
Finally, by not using a inlet mounted to knuckle I dont' have to worry about all the other articulation issues due to steering but the air still hits the hat pretty well.
Full lock:
Full Lock
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
Mgizzle is offline   Reply With Quote
Old 08-09-2013, 07:12 PM   #67
bannonm
bannonm's Avatar
The fact your duct has few bends, I would bet this works just as well as those that use a bracket on the knuckle and have to twist the duct around. I plan on redoing mine and increasing to a 3 inch duct. I like this setup.
Old 08-11-2013, 12:11 PM   #68
plumber84
Duke
plumber84's Avatar
Drives: 2011 2SS RS M6
Brake Duct Kit
We've been running the Quantum set up for sometime now and I think it is a very well engineered solution. The piece it lacks however is the attachment point to the grille area...
Heat Shield for the Tie Rods
This is the best solution I've found but we're working on the termination point at the lower grille as well as adapters for the ZL1 ducts. Please feel free to call, email or PM us anytime with questions.
Kind regards,
Jordan Priestley
888.308.6007
Can you pm me with a price for this brake duct kit please. I assume gen5 forum members get a discount. And, did you come up with a kit for the bumper scoops yet?
Thanks,
John
Vararam CAI, BFE 1 7/8" headers, 3" X pipe w/cats, Pfadt phase 5 suspension, BMR tunnel brace & subframe connector, Hurst Shifter, SRP racing pedals, AP Racing RadiCal Big Brake Kit front, Cobalt Friction Brake Pads XR2 (F) XR3 (R), Goodridge SS Brake Lines, StopTech STR-660 Race Brake Fluid, Quantum Brake Cooling Ducts, ZL1 Rims 20"x10" (F) 20"x11" (R). Toyo R888 285-35-20/315-30-20, RX oil catch can, Dynomax Ultra Flo SS Axle-Back Exhaust, ECS dyno tune 422.3rwhp/422.9tq stock engine. ZL1 Aerodynamics. GM Dovetail Rear Spoiler. Z/28 Wicker Bill Z/28 Axels
plumber84 is offline   Reply With Quote
Old 08-11-2013, 01:15 PM   #69
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
I assume that you want to take air from the lower grill. After installing my intake scoop I wonder if an adapter to the scoop can be made. At the very least you have to consider the fact that a great number of us use those scoops.
There also could be something to adapt to the ACS T3 ducts...
Just a few thoughts/ideas...
Firefighter is offline   Reply With Quote
Old 08-23-2013, 11:20 PM   #70
plumber84
Duke
plumber84's Avatar
Kind regards,
Jordan Priestley
888.308.6007
Do you have pictures of how you routed the ducts for the quantum system?
brake, ducts
