JUICEDMOTORSPORTS
Old 08-24-2013, 03:57 PM   #71
rockrau
rockrau's Avatar
Drives: 2010 2ss red LS3
Will it clear a 1LE tire & wheel? That is what I'm using.
rockrau is offline   Reply With Quote
Old 08-26-2013, 11:00 AM   #72
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
I will fit perfectly with your 1LE combination. Please feel free to call, email or PM us anytime with questions.
Kind regards,
Jordan Priestley
888.308.6007
JDP Motorsports is offline   Reply With Quote
Old 08-26-2013, 11:35 AM   #73
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
You know I reread my earlier post. Didn't Rotofab come out with an adapter for the ZL1 ducts and a scoop?
Firefighter is offline   Reply With Quote
Old 08-26-2013, 01:00 PM   #74
Synner
Drives: not stock
They have a weird adjustable diversion flap but the ZL1 ducts don't go where you need them to for max cooling so its kind of a waste.
Old 08-26-2013, 01:18 PM   #75
Firefighter
Where is the best spot? I'm thinking I will eventually end up with T3 ports and figured I would pull from those...
Old 08-26-2013, 01:22 PM   #76
Synner
Drives: not stock
Center of the rotor towards the hub and using the rotor vanes the way they were supposed to. The ZL1 duct doesn't get close enough to the right area.
Old 08-26-2013, 01:46 PM   #77
Firefighter
But in your opinion that would be a good spot to attach the hose if you were to run this JDP kit?
Old 08-26-2013, 01:50 PM   #78
Synner
Drives: not stock
Would need to see how to route the hose from there, its more directly in front of the tire, but air from the front end is good wherever you decide to take it from.
Old 08-26-2013, 02:09 PM   #79
Firefighter
Yeah I didn't consider that it is directly in front of the tire.
Old 09-30-2013, 05:03 PM   #80
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
but is there an adaptor that can connect to the ZL1 ducts?
franknbeans is offline   Reply With Quote
Old 09-30-2013, 06:44 PM   #81
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Not that I am aware of. The ZL1 rectangular duct would require something fabbed out of aluminum to 2.5 or 3 round. I doubt there is enough room to route that.
Old 10-09-2013, 04:04 PM   #82
woodside783
Casey Woodside
woodside783's Avatar
Drives: a very fun car
I like this kit. I have 19's with 305 all around will this kit work for me?
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w
woodside783 is offline   Reply With Quote
Old 11-02-2013, 03:59 PM   #83
Synner
Drives: not stock
Anybody have info on how they routed their 3" tubing to fit?
Halfway there:
Old 11-02-2013, 06:37 PM   #84
td195f
td195f's Avatar
Drives: 2015 Z/28 #786
Take a look at the photos below. I used the Quantum Backing Plates and 3" hose. I routed over the top of the tie rod/rack and pinion unit and over the top of the front suspension mount on the frame then down into the air inlets installed behind the lower grill. There is a splash guard between the suspension mounts that you'll have to remove one of the plastic fasteners on to route the hose between the frame and the splash guard. This routing results in no rubbing on a 1LE. I have done two track days at Watkins Glen with this setup with no issues.
2015 Z/28 #786 - Black
2004 Silverado 3500 Dually - D'Max - Suncoast - Banks - Edge - Custom Tune by D'Max Tuner / Spitzer '32 Bantam Altered Drag Car - Blown Alcohol 380 CI Small Block Chevy
td195f is offline   Reply With Quote
brake, ducts
