HeadlightArmor
Old 12-20-2013, 10:08 PM   #99
Synner
Drives: 2011 2SS/RS M6
2" would be a complete waste if you ask me. Airflow goes down drastically as you lower pipe size. Do at least 2.5"
Both your options would add weight to the suspension itself but if its aluminum it would be minimal. I think getting under the car and looking at how much room you have for various options is your next step. Drive it up on ramps so you see how everything looks at ride height. Both would work decent but not as much total airflow as from the front. Personally if I were to do one I'd do the scoop mounted on the arm, the other method is tougher to get the air going exactly where you want..
Old 12-22-2013, 07:55 AM   #100
toehead93
Drives: 2014 2SS/1LE
The scoops look like an easy and cheap alternative but as a daily driver the scoops protrude too low for me. I would not feel safe on the street with them and since true ducts can be done fro $125 it isn't too much more than the cost of the scoops to make me feel more comfortable on the road.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 12-31-2013, 10:27 AM   #101
SSSoon
SSSoon's Avatar
Drives: RY 2011 2SS A6
Well, I bought a set of T4 bumper ports from Advanced Composites. More air flow into those than into the OEM fog light openings, and smoother air flow because of the curvature of the T4 opening. I think the front openings on the T4's are about 8" by 8", quite a bit bigger than the air ducts that others have been putting in behind the grilles. Plus, I think they look kinda cool. Pic below is from T4 install guide so you can see the difference in opening size.
If I can't get it to work for some reason, backup plan will be to use the spots on the lower grille like everyone else has, but that creates other headaches for me as I would have to move my CAI scoop somehow. I also don't like the idea of sucking air away from the front as I have a remote oil cooler down there and want to keep as much air as possible up there so it stays cool.
Dry sump LS7, cage, JPSS suspension, Wilwood brakes, fire suppression, ARH 3" headers/exhaust, Z/28 DSSV coilovers, Kirkey seats, TeamTech 6-point harnesses, 19" Forgeline GA3R, 325/30R19 Re11 tires, oil cooler, monster JPSS splitter/wickerbill, CAI, brake ducts.
SSSoon is offline   Reply With Quote
Old 12-31-2013, 03:02 PM   #102
toehead93
Let us know how it turns out. What brake setup you running for the track?
2010 2SS A6 - sold.
Old 12-31-2013, 03:38 PM   #103
SSSoon
SSSoon's Avatar
Will do!
Right now I am running Racing Brake slotted rotors up front, OEM out back, and Cobalt Friction XR4/2 pads. Long and sorry story of smoked pads and warped rotors at http://www.camaro5.com/forums/showth...294470&page=14 if you're interested in reading what ended me up with this setup, which I really like.
Old 12-31-2013, 09:52 PM   #104
toehead93
Yes i remember reading about that. I am torn between the same setup you hve or going with the CTS-V upgrade.
2010 2SS A6 - sold.
Old 12-31-2013, 10:16 PM   #105
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
I'm liking what I see at the top of post #15... http://www.camaro5.com/forums/showthread.php?t=334716
Firefighter is offline   Reply With Quote
Old 01-01-2014, 09:33 AM   #106
ssmike
Missing Big Red
ssmike's Avatar
Drives: 2006 Corvette DSOM, '13 Equinox CRT
That does look cool! Just wondering how much air will actually be introduced into the ducts being underneath the splitter like that!
Not a Camaro but it works for now!
Old 01-01-2014, 09:42 AM   #107
toehead93
I was thinking the same thing, I feel a lot better with the front grill local especially given that a GM engineer recommended over the fog light location. I believe the air would be moving very fast under the splitter but 90 degrees to the opening whicj does not seem optimal. However I know nothing about fluid dynamIcs so who knows. I will stick with what works.
2010 2SS A6 - sold.
Old 01-02-2014, 09:20 PM   #108
SSSoon
SSSoon's Avatar
Started
Quantum kit arrived today, so I got that part installed. Once you have the calipers and rotors off it's like 5 minutes to install per side. Dead simple.
T4 brake ducts and misc parts to arrive next week, so looks like it'll be a few weekends till the rest is done.
Old 01-08-2014, 09:46 PM   #109
SSSoon
SSSoon's Avatar
Parts are in
Got all the hose, clamps, etc. and the ACS T4 ducts. Yellow part fits in front, unpainted/black part sandwiches the bumper from the back. Also got two small black general purpose air ducts from Racer Parts Wholesale. Will have to butcher the small ducts to get them to fit on the back of the T4 plenum, but it will work. Will give me a nice mounting point for the hose, and channel air towards it, pointing back and down at a 45 degree angle. Going to start building the back assembly and getting the light bars installed, then hoping for warmer weather so I can do the cutting and gluing in the bumper (fumes means I need to do it outdoors, and can't do it when it's too cold).
Old 01-17-2014, 07:24 PM   #110
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
I am looking at my ZL1 cooling intake. I'll have to see if it was a waste of money for those or If I can modify them to work.
franknbeans is offline   Reply With Quote
Old 01-17-2014, 07:30 PM   #111
JusticePete
5th Gen Master Builder
JusticePete's Avatar
Drives: Camaro Justice
Step by step DIY to follow.
Old 01-17-2014, 08:02 PM   #112
franknbeans
Whipped
Drives: 2010 CAMARO
really Pete? That's great news. You using the Quantum kit also?
brake, ducts
