sjm autoprod
Old 11-19-2012, 10:20 AM   #29
Matt @ RX
Guest
Posts: n/a
Originally Posted by ayousef View Post
isnt that a dual pump set-up? That is also asking for trouble, one pump fails and kaboom goes the motor.
I think most people are having problems due to poorly designed kits/wiring and not having the pump speed controller which is a must with an A1000 or bigger on the street.
I have EVERYTHING that is required (And then some in my opinion), including 10 gauge wiring, direct relay to battery, A1000 regulator, etc.
Old 11-19-2012, 10:54 AM   #30
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
I have been running ADM's twin pump setup for almost 3 years and 45k miles with no issues. I'm pushing just over 700 rwhp.
I've heard of a lot of issues with the Aeromotive pumps lately. I have built or been involved with a lot of Camaro high horsepower builds and I either use the ADM twin or the ZL1 with ADM's fuel pump controler, depending on the horsepower level.
Check with ADM, Andy's fuel systems just work, You never hear of an unhappy customer with ADM products or builds.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
Old 11-19-2012, 10:57 AM   #31
TCAT
TCAT's Avatar
Drives: Has Wheels
I agree with the above post. I have the ADM twin fuel pump set-up and its been fantastic. Two thumbs up to all the ADM crew for making a depending set-up.
TCAT is offline   Reply With Quote
Old 11-19-2012, 12:09 PM   #32
Matt @ RX
Guest
Posts: n/a
Unfortunately I have spoken to ADM and LPE about using their respective systems on my car, I'll just be out of the power range that would hold. Damn!
- Matt
Old 11-19-2012, 12:22 PM   #33
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
- Matt
I hear ya! I have the LPE twin pump now. My car is down getting the new motor installed as well as the full return style Aeromotive fuel system with Stealth eliminator pump, speed controller etc, etc. I am pinging about this system going in correctly. Aeromotive assures me it will work fine! Guess we will see!
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 11-19-2012, 01:52 PM   #34
realsquash
realsquash's Avatar
Drives: Four Door Camaro
- Matt
Our setup flows twice as much as those, and the A1000 setup.... All is not lost!
Andy
Squash Performance LLC
2010+ Camaro 800 LPH fuel systems
realsquash is offline   Reply With Quote
Old 12-05-2012, 12:02 AM   #35
gmg69
gmg69's Avatar
Drives: 2010 Twin Turbo SS, Summit White
thread update reply...
I stumbled on this thread and couldn't help but keep reading, as I have the internal A1000 as well. In fact, I'm on my 3rd one.
1st pump: siphon tube failure (same as shown in pics posted here)
2nd pump: failed to pump consistantly in hot weather. Apparently the return fuel was vapor locking (getting HOT!)
3rd pump: So far so good. Now I have a FPCM hooked up to reduce pump noise and prolong the life.
My 2 cents on these: The A1000 pump is a powerhouse unit that will support the 1000hp motor no problem. BUT... you have to have it plumbed and wired perfectly for it to not cause issues. With my dilemmas on these pumps, Jared at Aeromotive has very supportive in trying to make things right and get me going on the reliabililty track. He also recommends an inline fuel cooler on the RETURN SIDE. I haven't done that yet. If I can't get the reliability from this 3rd pump and controller...I'm moving on to other options.
Time will tell.
gmg69 is offline   Reply With Quote
Old 12-05-2012, 03:07 AM   #36
incon3037r
GMHIC
incon3037r's Avatar
Drives: 2013 Camaro ZL1/2008 Pontiac G8 GT
Time will tell.
I've had all of these problems as well. Aeromotive directions to wire the FPCM were wrong and when my mechanic contacted them to find the correct way, it took several days and being told several different wrong ways to wire it before the correct information was given. Then we were given the run around on which MSD tach adapter that was needed to find a signal for the FPCM. MSD would say to contact Aeromotive and vice versa.
Currently everything is working fine with the addition of the FPCM and MSD tach box. I was not advised on installing a cooler on the returne side but will do so. The fuel pump appears to be nicely made, but the trouble and all of the additional parts needed to install makes it a head ache. If this new unit doesn't hold up, I'll move onto the Squash setup.
It also sucks when you have to pay labor to remove and install a new pump because it was damaged from the manufacturer.
Pontiac G8 GT- ProCharger F-1D, Treadstone TR1235 FMIC, Kooks 1 7/8" LTH,Corsa catback, New Era (228/240) cam, Yella Terra 1.7 Rockers, GMPP LS3 CNC heads, Aeromotive A1000, FAST fuel rails, FIC 1000cc injectors - 762 RWHP/646 LBFT tuned @ 9psi on E85 9psi using HP Tuners
Camaro ZL1- Stainless Works 2" LTH, Corsa catback, RSC PDx cam, ID 1050x injectors, DSX fuel kit, New Era 4.5" intake, BTR springs/pushrods, AFCO heat exchanger, New Era expansion tank, Innovators West balancer, Metco 9.55" lower - 609 RWHP/591 LBFT tuned @ 8psi on 91 octane using HP Tuners
incon3037r is offline   Reply With Quote
Old 12-05-2012, 08:31 AM   #37
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
Thats why I installed an access door under the seat. It takes me 15 min.
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 12-06-2012, 09:26 AM   #38
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
Any high HP cars running the internal A1000 without issues?
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 12-06-2012, 05:06 PM   #39
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Drives: The Neighbor Hater
Any pics? I talked to Jesse at Aeromotive and that's what he recommended.
One thing I'm jealous of on the mustang lol
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims
pyr0b0y is offline   Reply With Quote
Old 12-06-2012, 07:23 PM   #40
MANNYS2SS/RS
There's several pic's posted on this thread. http://www.camaro5.com/forums/showthread.php?t=256182.
Old 12-06-2012, 09:39 PM   #41
stangkilr
stangkilr's Avatar
Drives: 2017 Camaro ZL1
Never had good luck with aeromotive pumps. Squash perf. For me
2017 ZL1
2014 Corvette
2002 Camaro
stangkilr is offline   Reply With Quote
Old 12-07-2012, 06:50 AM   #42
incon3037r
GMHIC
incon3037r's Avatar
I requested this be done and it wasn't. I was also waiting on an access door cover that Squash mentioned making on the G8 forums.
