Old 06-03-2009, 10:11 AM   #1
LDGn63
LDGn63's Avatar
Drives: WNABEE
Question oil change question...
This may be a stoopid question but I'd rather ask a stoopid question than make a stoopid mistake!
I've done PLENTY of oil changes… just not on the LS engines.
Is there anything out of the ordinary I should know when changing my oil on the SS?
It takes a huge amount… is there a cooler? I think I remember reading that but now I cant remember if it was a trans cooler!
If there IS a cooler, how do I get all of the oil out, and back into, the cooler without overfilling the engine?
Thanks!
Why oh Why?
Windshield=10" vertical
mirror= 3 7/8" (that's almost 4") vertical
that means that the mirror is 38.75% the size of the vertical windshield...
it sure seems like the ratio could be better... just sayin....
our collective MIRROR patch:
http://www.camaro5.com/forums/showthread.php?t=24612
LDGn63 is offline   Reply With Quote
Old 06-03-2009, 10:49 AM   #2
2SSJIM
2SSJIM's Avatar
Drives: 2012 CRT ZL1 #1400
Have the dealer change your oil and you won't have to worry about it at all! Seriously, the oil cooler... and I can't remember if the SS has one or not either... will not drain when you change the oil anyway. Usually they are mounted in the front of the car in front of the radiator however, I have seen oil pans with a built in oil cooling system... usually just some heat sink type fins on the bottom but I know the Camaro doesn't come with those!
2SSJIM is offline   Reply With Quote
Old 06-03-2009, 12:00 PM   #3
LDGn63
LDGn63's Avatar
Drives: WNABEE
changing my own oil offsets the price of having my own lift!
now that i have a Camaro (with so much synthetic) my lift will pay for itself sooner.
Why oh Why?
Old 06-04-2009, 09:51 AM   #4
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
not an option... anyone with a real answer?
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 06-04-2009, 01:10 PM   #5
A.J.
A.J.'s Avatar
Drives: 2014 Impala
Other than 8 qts., nothing different from most any other oil change. There is a cooler just in front of the filter and I believe it will drain. Be advised that a lot of oil drains when you remove the filter. It caught me by surprise and made quite the mess.
Ordered on 10-14-08 - Silver Ice Metallic/Black Leather 2SS/RS, 6 Spd, Sunroof, Polished Wheels. Build date: 04-17-09, VIN 3978, Delivered 04/29/09! Sold on 04-16-2012 :(
ZL1 Ordered on 10-29-11 - Silver Ice Metallic, 6 Spd, Sunroof, Polished Wheels, Exposed Carbon Fiber Insert. Build date: 05/17/12, VIN 1415. Delivered 05/30/12!!!! Sold 05/28/12
A.J. is offline   Reply With Quote
Old 06-04-2009, 02:57 PM   #6
LDGn63
LDGn63's Avatar
Drives: WNABEE
thanks bro...
sorry about the mess...
ever wonder why they call us Greasers? ;-)
Why oh Why?
Old 06-05-2009, 10:07 PM   #7
Bell040
Bell040's Avatar
did you get 8 qts back out?
... Also, why have you already changed the oil? ... You can't have more than a couple thousand miles on it.... or did I miss something about changing it early the first time.
Ordered: 10-13-08
Recieved: 6-12-09
Old 06-05-2009, 10:43 PM   #8
LDGn63
LDGn63's Avatar
Drives: WNABEE
some folks on here have changed theirs at under 500 to clean 'em out.
i say it cant hurt (anything but the wallet)
Why oh Why?
Old 06-07-2009, 11:33 PM   #9
Parker
Parker's Avatar
Drives: 2010 Camaro SS/RS
If you're gonna be worried about the filter spray get it loose enough to turn by hand and poke a hole in the bottom with a pocket knife. Then turn it a little more till the gasket separates from the engine come back to it in 10 minutes and most of the oil will have drained out.
Also don't forget to put some oil on the new filter's gasket.
Parker is offline   Reply With Quote
Old 06-08-2009, 09:50 AM   #10
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
It's recommended to change a new car's oil at the 500 mark as there are tiny fragments of metal left over from the manufacturing process. By changing the oil at 500 miles you allow the oil to gather the majority of the fragments and flush them out. You then change the oil again when your car has 2,000-3,000 miles to get the remaining fragments out. After this change the oil at the normal intervals.
Old 06-08-2009, 02:40 PM   #11
Bell040
Bell040's Avatar
thanks.... I dont know how I missed this.... considering the amount of reading I have ben doing here.
Ordered: 10-13-08
Recieved: 6-12-09
Old 06-09-2009, 11:21 AM   #12
SicSix6
The Demon Photographer
SicSix6's Avatar
Drives: 2010 1SS IOM Camaro
Thanks!
read the owners manual. it will tell you what you need to know about capacities, and anything else you need to do. Reading really is fundemental.
1SS IOM LS3, GM 4-pack guages, SLP SS Front Emblem, Roto-Fab CAI, Solo Performance Mach X Exhaust, Barton Industries Short Throw Shifter
SicSix6 is offline   Reply With Quote
Old 06-09-2009, 12:52 PM   #13
LDGn63
LDGn63's Avatar
Drives: WNABEE
capacities yes... how to no. (maybe i just missed it)
Why oh Why?
Old 06-09-2009, 12:57 PM   #14
mlee
www.CamaroFans.com
mlee's Avatar
Drives: 2017 A10 ZL1
Just had mine changed... (8 qts exactly just like the manual says) takes a while for the oil to show on the dipstick. I watched the guys put 8.5 in... of course after a wait we had to drain 1/2 qt. Bring your own filter too. I used K&N. Most places don't have listings, but it's the same as the vette.
My lessoned learned is to let it sit a while before checking the dipstick.
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
GM bankruptcy! SSMUFF General Automotive + Other Cars Discussion 101 07-09-2008 12:44 AM
Oil Prices Steady Below $128 a Barrel camaro5 General Automotive + Other Cars Discussion 5 05-28-2008 01:39 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 01:20 PM
