Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 10-15-2012, 01:08 AM   #1
ZL1 Spoked
ZL1 Spoked's Avatar
Drives: Camaro ZL1
Help reading different DYNOSHEET for ZL1
Can someone go over the Ratio TCF and Gain statistics at the bottom? Any particular reason the gain shows 0.1 and then 0? Sorry if its a noob question just different from previous dynos. Thanks guys
-2013 Camaro ZL1-Black Stripe Package-Ambient Light Kit-Subwoofer Package-Sunroof-Suede Package-NAV MYLINK-MANUAL BABY-Dual Vented Fenders-Exposed Carbon Fiber Insert
-Black 10 Spoke Wheels
604 RWHP 602 LBS/TQ
ZL1 Spoked is offline   Reply With Quote
Old 10-15-2012, 09:41 AM   #2
Drives: none yet
A guess but the gain is likely an adjustment on the dyno as it relates to sensitivity....and not about gains in performance? You know how sometimes you see a dyno sheet with a very squiggly line? That is likely because the gain is turned up too high. Or a squirrely RPM signal.
And after a bit of research, TCF stands for "Transmission correction factor". If the operator knew exactly what the drivetrain loss was then by adjusting this he could get an estimate of power at the engine. ie....if there is a 15% drivetrain loss then he could set the TCF to 1.15 and it would basically increase the numbers by 15% and you would get an idea of power at the engine. I would assume almost everyone sets TCF to 1.00 to get a reading at the wheels.
flyjbaker is offline   Reply With Quote
