Old 02-20-2013, 10:34 PM   #29
evonschu
evonschu's Avatar
Drives: Camaro ZL1
Dealer has had my ride for 3 days. Came back and said there was a faulty O2 sensor. The first one before the cat. Probably explains why I've been backfiring a bit more often than most ZL1s I've heard on youtube and had bad gas mileage, even for this car.
evonschu is offline   Reply With Quote
Old 02-21-2013, 04:39 AM   #30
mlee
www.CamaroFans.com
mlee's Avatar
Drives: 2017 A10 ZL1
Originally Posted by jasonpope2003 View Post
Just thinking.. can we force the butterflies completely closed somehow? for like creeping through neighborhoods so they dont open automatically based on RPM?
A couple shops have done this, but it requires some re-wiring. Not a simple DIY process, but works great for taming cars with headers.
If you want to go Wireless for 20 bucks... I have this version programmed to my Homelink buttons.
http://www.camaro5.com/forums/showthread.php?t=249118
Old 02-25-2013, 10:20 PM   #31
Th3Beast
Th3Beast's Avatar
Drives: 2017 SS 1LE
For the wireless setup, does it require taking up two of the Homelink buttons (one for on and one for off)?
Th3Beast is offline   Reply With Quote
Old 02-26-2013, 12:59 AM   #32
RiCorvette
RiCorvette's Avatar
Drives: 2017 Corvette Grand Sport 3LT
Originally Posted by Camaro Fred View Post
An alternative approach is to buy a wireless 12 V 10A switch from Amazon for $5.00, an inline fuze cable for $3.00 from Radio Shack and hook it up to the fuze box in the trunk. Use a factory installed Home link remote button near the rear view mirror instead of the remote that came with the wireless switch. No manual switch required, no wires to run, no Mild to Wild switch cost, total job was $8.00. It works great.
Could you oblige us with a detailed write-up? I love this wireless option.
RiCorvette is offline   Reply With Quote
Old 03-16-2013, 09:10 PM   #33
RiCorvette
RiCorvette's Avatar
* BUMP *
no one?
Old 03-16-2013, 09:35 PM   #34
mlee
www.CamaroFans.com
mlee's Avatar
Yes... but it also comes with two key fobs so you don't really have to use homelink at all.
I already did... in the link above. http://www.camaro5.com/forums/showthread.php?t=249118
The homelink setup is in your owners manual.
Old 03-17-2013, 11:46 AM   #35
RiCorvette
RiCorvette's Avatar
I are chagrined - I totally missed that.
Thanks!!
Old 03-17-2013, 08:12 PM   #36
mlee
www.CamaroFans.com
mlee's Avatar
Thanks!!
LOL...
Old 03-20-2013, 09:13 AM   #37
Th3Beast
Th3Beast's Avatar
Drives: 2017 SS 1LE
Is there a way to get the exhaust flaps to be closed at idle, but retain how the rest of the system works? With the headers and high flow cats on my car having the flaps open on startup makes a cold start just straight obnoxiously loud.
Old 03-20-2013, 09:44 AM   #38
One-Bad-ZL1
So easy to love Camaros
One-Bad-ZL1's Avatar
Drives: 2013 ZL1 VR #3457
Send a message via Yahoo to One-Bad-ZL1
You're gonna need the Helms manual for the wiring diagram too see if there is a relay controlling the 0-1000rpm range that tells the vacuum pump to operate and open the valves. Hopefully it's not on an integrated circuit.
One-Bad-ZL1 is offline   Reply With Quote
Old 03-20-2013, 09:52 AM   #39
DuskSS
Bayou City Muscle Cars
DuskSS's Avatar
Drives: 2013 2SS Dusk Edition
I want a keep it closed function myself for creeping though neighborhoods or late at night.
There has to be a way to force them closed
Sent from my SPH-L900 using Tapatalk 2
Lethal Racing Stage V
PER 418ci Forged LS3
530/520 SAE
DuskSS is offline   Reply With Quote
Old 03-20-2013, 10:05 AM   #40
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
There are adjusters on the butterflies, you could adjust them to stay shut I guess.
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 03-20-2013, 10:07 AM   #41
DuskSS
DuskSS's Avatar
Um that sounds like too much work I want to basically turn them into electric cut outs.
With a toggle loud or quiet.
530/520 SAE
Old 03-20-2013, 10:16 AM   #42
Th3Beast
Th3Beast's Avatar
Drives: 2017 SS 1LE
That sounds like they would always be closed then. I like the functionality of them opening at higher RPM... it's just the cold start that kills me.
Does anyone have a wiring diagram and location of the control module for the flaps?
