sjm autoprod
Old 10-15-2012, 11:54 AM   #1
xcarolina23
xcarolina23's Avatar
Drives: 2011 Camaro SS/RS
Keeping the shine in between bi-annual waxes?
I recently bought my third Camaro, first 5th gen. I got black and my two previous cars were red, white. Living in Florida where it rains non-stop and sprinklers run rampant, paired with the sun hammering down, what can I use in between the twice a year clay, wash, and wax? I take the car to get washed about every other weekend but I am looking for something to wash off the little things here and there between washes.
Does anyone have some good tips.recommendations?
Steve
xcarolina23 is offline   Reply With Quote
Old 10-15-2012, 11:55 AM   #2
FL1CK
Switchin' n Twitchin'
FL1CK's Avatar
Drives: 2011 Camaro
I wax mine more than twice a year... being in the elements it needs it here in VA
I am not childish, you're just being a poopy head!
FL1CK is offline   Reply With Quote
Old 10-15-2012, 12:39 PM   #3
xcarolina23
Thanks Flick, do you use a quick detailer or something in between those waxes?
Old 10-15-2012, 12:53 PM   #4
heRS
Raised by Wolves
heRS's Avatar
Drives: IBM 2010 2LT RS M6
I use a Meguires spray wax inbetween my paste wax applications but I also apply the paste wax more than twice a year, 3 or 4 more like it. I do a lot of highway driving and the road grit just scours wax off the sides.
When I wash the car, I blow-dry the majority of water off, then use spray wax with the drying towel for a spot-free shine.
Tori
Old 10-15-2012, 02:38 PM   #5
Good_Times
Drives: red
If you are concerned about water stains and etching from sprinklers and rainy Fl weather, You would be well off to consider a coating. OC 2.0 , Opti-Guard and the like are getting a lot of attention for a reason. Ease of maintaining a defect free surface is greatly increased and one of many benefits enjoyed with a coating application.
Good_Times is offline   Reply With Quote
Old 10-15-2012, 04:16 PM   #6
xcarolina23
Thanks guys!
Steve
Old 10-16-2012, 06:28 PM   #7
Angelo@Autopia
Angelo@Autopia's Avatar
Drives: 2014 Ford Focus ST
The problem with what we have here in Florida is the hard water, bug's and rain! I always recommend using a sealant for this and still do. If you want to use a wax that's fine but do this after you apply the sealant on the paint. I always use 2-3 coats of sealant and wax it to help in these problems. Don't forget to have a QD with some sealant or wax in them so you can touch up after any of these problems arise.
Old 10-16-2012, 10:40 PM   #8
FL1CK
FL1CK's Avatar
Drives: 2011 Camaro
I usually just wash between the waxing and dry with a detail spray
Old 10-17-2012, 01:00 AM   #9
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
Use a quality sealant like Blackfire Wet Diamond Sealant 4 times a year. That should last you 3 months an application no problem.
Also the sealant goes on very thin, so you might still have that bottle 2 to 3 years later if you just do one car. (it is kind of expensive though at 40 dollars)
Then just use Ultima Waterless Wash + concentrate. It is a rinseless wash and a quick detailer.
One 16 oz bottle ($20) makes 5.5 GALLONS of quick detailer/rinseless wash/clay lube. It is one of my favorite products... ever!
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 10-27-2012, 02:54 PM   #10
xcarolina23
After the wax I went with some Meguiars detail to remove rain spots and debri which is constant down here in Florida. What do you guys think?
Old 10-31-2012, 12:40 AM   #11
CyberBri
BRUCE WAYNES DD
CyberBri's Avatar
Drives: 2010 2SS/RS CGM
I just wax in between waxes to keep her shiney!!!! Lol its not so bad just buy a buffer
JBA 1 7/8 LT`s, High flow mids, and Cat back,Airaid intake, JRE Tune, & alot of flat black....
CyberBri is offline   Reply With Quote
Old 10-31-2012, 09:03 AM   #12
nUcLeArEnVoY
Oldbie that nobody knows
nUcLeArEnVoY's Avatar
Drives: 2011 1SS/RS M6
I put on one coat of sealant.... every month. Overkill.
nUcLeArEnVoY is offline   Reply With Quote
Old 10-31-2012, 10:14 AM   #13
xcarolina23
Nuclear I see you are a FL guy. When it rains and the debri and dusts gets on your car do you wipe it down with something or take it to the wash? i used Meguiar's UQD and it looked amazing, took off all dust and rain spots, no actual dirt on the car. They just make it so hard to pick a product to use so I hope I am using the right one =/
Photo Album:http://www.camaro5.com/forums/album.php?albumid=11844
My Mods: Satin powdercoated wheels, CAI cold air intake with washer fluid tank relocation kit and scoop, Solo cat-back exhaust, jetsream blue G2 caliper paint, blacked out emblems and lights, Gorilla lock lugs, hydro-dipped fuse box cover and strut bar, jetstream blue SS emblems, engine cover, and cold air intake cover, replaced convertible top, and ABL under-dash/dome lights.
Old 10-31-2012, 12:31 PM   #14
ihaveacamaro
I like teeth.
Drives: #198
QD is great a removing light dust and as a drying aid. Meguiar's Ultimate Quick Detailer is pretty good. But it is like 10 dollars for the bottle.
If you get Ultima Waterless Wash, you can get an equally good QD for much cheaper. It's 20 dollars for the concentrate. It makes 5.5 GALLONS of QD. Also, it is a very good waterless wash, clay lube, and rinseless wash
