Old 11-01-2012, 09:20 AM   #15
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I wish I could watch the video from this damn phone but I'm sure it's bad@$$
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 11-01-2012, 09:51 AM   #16
sammyv
sammyv's Avatar
Drives: 2013 red Lingenfelter ZL1
Impressive!
sammyv is offline   Reply With Quote
Old 11-01-2012, 08:18 PM   #17
NASTY99Z28
Drives: 99z28 with bolt-ons and a mwc fab 9
Are you still having any issues with it pulling timing while on the road course with the added boost?
I like my woman like my milk shakes, THICK!!!!
NASTY99Z28 is offline   Reply With Quote
Old 11-01-2012, 08:46 PM   #18
Erik@Torq
Erik@Torq's Avatar
Drives: '10 SS + '04 Z16 Z06 S/C
Send a message via MSN to Erik@Torq
Oh no, not at all. That was was when we still had the stock cooling system, H/E, no IC reservoir and a few other stock bits we have then replaced.
We have been to the track several times since testing our different levels of power paks and cooling paks with great success. Just this past weekend I got over 3h of track time with the current setup and blew all previous lap times away, including the ones set with my previous SS with every suspension mod in the book. That video will be coming soon!
/Erik
Erik@Torq is offline   Reply With Quote
Old 11-01-2012, 11:27 PM   #19
thebeast916
Drives: Blown G8 GT
Sounds nice
thebeast916 is offline   Reply With Quote
Old 11-02-2012, 04:04 AM   #20
NASTY99Z28
/Erik
That's good to know now my next question is how does the car (mostly the brakes) do with all the extra speed when diving off into a turn? Can't wait to see some track videos and watch all the you tubers get bent....
Old 11-02-2012, 08:29 AM   #21
Erik@Torq
Erik@Torq's Avatar
Originally Posted by thebeast916 View Post
Sounds nice
She sure does, sounds nasty IRL. She runs pretty good too, 11.2 @ 126mph on stock tires, stock suspension with the old mild cam with a very novice drag racer Now we are making 40whp more with the new cam and I have some more seat time so I am shooting for 10's on stock tires.
Surprisingly well to be honest. I am running a slightly more aggressive pad in the front and up until this weekend when I ran them down to about 20%, I have had zero brake issues at all. The stock calipers work very well, the stock brake cooling is good (has room for improvement though) and the car is very balanced. I am still out braking much lighter cars lap after lap in 30 min sessions with no brake fade at all.
A good pad combo that is balanced front and rear (even temps to make it biased and balanced properly) and proper brake fluid and brakes will be the least of your issues.
I am also running Toyo R888's so I am REALLY using my brakes going very fast and very deep into the turns, add on some trail braking and that is usually a recipe for toasted brakes!
This car is a real hoot to drive at the track, despite the weight! 840hp gets her up and going and allows for some nice controlled exit oversteer even at higher speeds
/Erik
Old 11-02-2012, 08:36 AM   #22
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
/Erik
Awesome job Erik
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 11-03-2012, 07:15 AM   #23
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
Is this on the stock injectors and pump?
Nitroman28 is offline   Reply With Quote
Old 11-03-2012, 07:46 AM   #24
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
Not a chance
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 11-03-2012, 08:52 AM   #25
Erik@Torq
Erik@Torq's Avatar
Originally Posted by MANNYS2SS/RS View Post
Awesome job Erik
Thanks Manny!
No, this is with larger injectors and a dual pump set-up. We have run it with an MSD boost-a-pump as well with the stock pump, but it's right on the limit for that setup. The dual pump set-up is the way to go.
/Erik
Old 11-03-2012, 09:17 AM   #26
alssiri
alssiri's Avatar
Drives: 2012 ZL1 A6
Wow great numbers
Ahmad
2012 ZL1 A6
Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Corsa Sport Catback, ADM 102mm Snout, CAI, NW 102mm TB, ID850, AGP Dual Fuel Pump, MSD Wire's, Moroso CC.
Alky Control, FIICHILLER.
2015 Rear Fascia Conversion, Z/28 Side Skirts, Flares, Spoiler & Diffuser , ACS Quarter Ports, ShowStopper's Side Marker's, LightWurkz Halo's.
Sosche With KenWood, SLP pod with PLX guage, DashLogic .
alssiri is offline   Reply With Quote
Old 11-09-2012, 11:04 AM   #27
morgnstern
Drives: 2013 ZL1
Please PM me the cost to dot his to mine.
Originally Posted by Meister@Torq View Post
We just finished tuning our aggressor cam package in our shop car and wanted to share the gains. Keep in mind these numbers are on a Mustang Dyno and we have seen approx 50-60rwhp more at this power level on other dyno's. We are about advertising the true gains of the car as well as the final number because each car is a bit different. This is achieved at 13.5psi, which is 1.2psi less than our MILD camshaft and 40rwhp more 25rwtq with a broader power band and did not lose anything at lower RPM's.
We picked up 230HP and 170RWTQ with this setup. With similar boost levels to our upper only setup we are making approx 140rwhp more.
Modifications:
Airaid Cold Air
NW 102mm TB
Torq 102mm Snout
Kooks 1 7/8" Headers w. GREEN EPA Emissions Cats
Stock Catback
Stock Blower
Stock Heads
93 Octane Pump Gas
Idle clip of this camshaft:
ZL1 Cam Upgrade Video - Torq
How much for this setup?
morgnstern is offline   Reply With Quote
Old 11-10-2012, 02:31 PM   #28
justindewoody
Drives: 2013 Camaro ZL1
Price?
2013 Camaro ZL1 Silver Ice #3187 TPW 10/22
1100 Preliminary Order Accepted 9/26/2012
1102 Preliminary Order Added Thru Web 9/26/2012
2000 Accepted by GM 10/01/2012
2500 Preferenced 10/02/2012
3000 Accepted by Production Control 10/02/2012
3100 Available to Sequence 10/11/2012
3300 Scheduled for Production 10/11/2012
3400 Broadcast 10/18/2012
3800 Produced 10/22/2012
4000 Available to Ship 10/23/2012
4150 Original Invoice 10/23/2012
4B00 Bayed 10/23/2012
4200 Shipped 10/26/2012
4800 Rail Ramp Unload 11/02/2012
5000/6000 Delivered 11/05/2012
justindewoody is offline   Reply With Quote
