Old 10-16-2012, 10:06 AM   #1
Camarowguy
Camarowguy's Avatar
Drives: 2011 imperial blue SS, black 92 RS
What if......
Lets get something straight first: I'm not trying to start another zl1 vs gt 500 argument thread. I was just thinking about this and discussing this with a coworker. We all know the gt500 has more power and less weight than the zl1, but I'm interested to see what would happen if the playing field was leveled....or basically made more fair. So you get both cars and dyno them, and you add a pulley and tune to the zl1 to try to match the power to the gt500. Then drag race them and track race them. Maybe even go as far as matching the weights of both cars. I wonder what would happen?
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires.
2000 1500 silverado extra cab
Camarowguy is offline   Reply With Quote
Old 10-16-2012, 10:28 AM   #2
arabiannight975
arabiannight975's Avatar
Drives: '10 Jeep Srt8, '12 Camry,'10 Accord
Post similar times ? Lol
arabiannight975 is offline   Reply With Quote
Old 10-16-2012, 10:32 AM   #3
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1 #182, 85 AMC Jeep CJ7
Based on current comparisons I think the Zl1 would then blow the GT500 away. It wouldn't even be a contest.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 10-16-2012, 10:32 AM   #4
Camarowguy
Camarowguy's Avatar
I was thinking the same at the drag strip but maybe the zl1 would really shine on a road course?
Old 10-16-2012, 10:36 AM   #5
Betiwin
Drives: CTS-V Coupe and GT500
ZL1 and CTSV are prone to massive heat soak with more boost. So roadcoarse might not end up as a win for a Z. Think we have seen this in real life also.
Betiwin is offline   Reply With Quote
Old 10-16-2012, 10:39 AM   #6
69NMYSS
69NMYSS's Avatar
Drives: '69 Camaro SS and '12 ZL1
It already does on a roadcourse. It has matched or beaten the GT500 on every track comparison. Given it weighs 250 pounds more with an 80hp deficit, if you made the playing field level, the ZL1 would theoretically annihilate the GT500. Although the flip side to that is, the ZL1 was not engineered to handle 80 more hp on a chassis that weighs 250 pounds less, so may not handle as well as it does stock
69NMYSS is offline   Reply With Quote
Old 10-16-2012, 10:45 AM   #7
Betiwin
This is very possible. I think cooling and possible even some suspension tuning maybe needed. GM designed the car very balanced, if you change one part of the equation you have a different outcome as an end result. Maybe better maybe worse.
Old 10-16-2012, 10:46 AM   #8
alyssasdad
Go VOLS!!!!!
alyssasdad's Avatar
Drives: ZL1 #1344 VR, M6
Almost the same results as you would get now since the weather has cooled off: It all depends on the driver!!"
1.GOD
2.Family
3.Camaro........& the TENNESSEE VOLS!!!
alyssasdad is offline   Reply With Quote
Old 10-16-2012, 10:53 AM   #9
Betiwin
I will say from personal Experiance my 500 is a lot easier to maintain power due to heat soak than the LSA in the V. Have 665 RWHP in the ford and don't run anywhere near the timing retard in that than the V does even stock. V is now modded and getting ready to do LPE 650 but with lots of extra $$$ for cooling (SuperChiller, resiviour, TSTAT) so it doesn't lose 75RWHP on a hot day. Also seems as the LSA defiantly needs a catch can as these things love to throw oil out off the blower valley all over intercooler.
Old 10-16-2012, 11:37 AM   #10
Limited02
Banned
Drives: 2004 LT1TT Camaro
There are too many variables to even make the upgrades fair.
Ex:
-Up the power in the ZL1, then you need to address the cooling issues, which is a mod not needed on the GT500.
-You need to either add smaller tires to the ZL1 or larger tires to the GT500.
-Obiviously, the ZL1 will have to be a manual.
-Etc.
A better comparison would be to take two similar priced cars and then see which car can be the better performer for X amount of dollars.
Edit: There would need to be a reasonable cap to how much you can spend on mods, say $3,000.
All things being equal, I would expect the same as well
Limited02 is offline   Reply With Quote
Old 10-16-2012, 12:19 PM   #11
hognutz
hognutz's Avatar
Drives: 2013 ZL1
people over look the gearing difference on these cars. in the 1/4 the 3.73's are going to make up for the 300lbs.
if you really look at the quarter mile times you will see once they ZL1 is throwing down 600whp-620whp. I saw a 10.80 with dr and low 600hp out of the KDI car. no 2013GT500 is going that.
the times are almost identical given equal power. on tire though I think the ZL1 will run better becasue the 3.31's in the GT500 are not going to like a dead hook as much.
now if you flip that coin though and you throw 3.73's in the GT500 then on tire it is going to start smashing the ZL1 based on being lighter and having the same mechanical advantage.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 10-16-2012, 01:03 PM   #12
Camarowguy
Camarowguy's Avatar
The more power you have, the less gear you need. Also the gt500 transfer may be geared differently than the zl1 trans and may not need that much gear.
Case in point; I work with a guy who had a 5.0 with a supercharger along with other things. The car ran 10.40's and it went faster with 3.31 vs 3.73 gears. Which is why I believe the notion of more gear in the gt500 will make it faster is mere hogwash. I guess for my mind to be changed is to see the same car with a gear swap and same height tires go faster. I will admit if you put a taller sticky tire on it and gear it to compensate it will likely be faster.
Old 10-16-2012, 01:11 PM   #13
Betiwin
ZL1 GT500
2.66 2.66
1.78 1.82
1.30 1.30
1.00 1.00
0.80 0.77
0.63 0.50
3.73 3.31
Old 10-16-2012, 01:45 PM   #14
Camarowguy
Camarowguy's Avatar
Originally Posted by Betiwin View Post
ZL1 GT500
2.66 2.66
1.78 1.82
1.30 1.30
1.00 1.00
0.80 0.77
0.63 0.50
3.73 3.31
You got me
