HeadlightArmor
Old 10-16-2012, 05:37 PM   #1
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Pfadt Camaro Coilovers: Back and better than ever!
It's been a really long summer at Pfadt Race Engineering! We've been busy not only with completely moving our entire operation to a much larger facility in Salt Lake City, but supporting a handful of race teams in World Challenge, GrandAM, and European endurance racing. During this time we have had folks patiently waiting for the redesign of one of our favorite Camaro products. Just as promised, after a brief hiatus we have brought back one of our most respected and important Camaro products... our Single Adjustable Camaro Coilovers!
Quite simply put, these are the best Camaro coilovers that we have ever built.
We were very focused on what we wanted to accomplish with these coilovers. They are now being built completely in house by our engineering staff in Salt Lake City. From filling the shocks with oil and nitrogen, to building sub assemblies, to final assembly including mounts and springs these coilovers are a unique Pfadt Race Engineering design. Being an engineering firm we are able to tailor all of our products to each specific application and you won't find as much Camaro specific engineering in any other product on the market. Making your Camaro lighter, stronger and faster is what our parts are all about, and these coilovers are the latest hardware designed to exceed your performance expectations. Key features of our new Camaro Coilovers include:
  • Full ride height control, easily adjusted.
  • Adjustable Dampers. 24 clicks front, 48 clicks rear.
  • Camaro Specific Valving
  • Inverted Shock Design
  • BOA and CIRC Systems included
  • Spring Rates selected for improved street and track performance
  • SIGNIFICANTLY Lighter than OEM design
  • Stronger than OEM design
  • Proven durability through torture testing
  • Complete Compatibility with all 10-12 Camaro models. Including ZL1.
Simple Ride Height Control - Ride height is set through one easy to use spring perch. You can achieve anything from a stock ride height, to about 2" lower than stock and anything in between. This will let you easily dial in the exact stance you're looking for. The revised front mounts also feature more clearance for aggressive wheel and tire combinations!
Adjustable Dampers - 24 Front Clicks and 48 Rear clicks of damping adjustment ensures that you will find a setting that is both comfortable on the street, and still delivers with amazing performance. The adjustment knob is placed conveniently at the bottom of the shock and effects both Rebound and Compression damping. Absolutely no drilling or adapters are required to reach the adjuster knobs in either the front or rear.
Custom Valving Specific to the Camaro - Each of our Camaro units is valved and built in house by our own engineers with valving that we developed on our ZL1. You won't find our Camaro specific valving on any other coilover or product on the market. Our valving is designed to improve response and really make the car feel like it's glued to the road when you want it, while still giving you the ability to tune the car softly for fantastic street manners. We do include starting points for the dampers for drag racing, street driving, and autox/road racing to make tuning really simple!
Inverted Shock Design - Placing the majority of the weight on the sprung side of the chassis allows the control arms and outboard components to react quicker and easier without the additional weight of the coilover itself. The result is a suspension system that responds faster to changes in the road whether its highway, local roads, or track surfaces. The less weight that is on that outboard suspension, the better your car will behave - you'll have a better connection between your Camaro chassis and the ground.
BOA and CIRC System Included - Proven durable technology taken directly from our Corvette Coilovers has been included in the Camaro Coilovers as well. Our BOA (Ball on Axis) upper mount allows a really wide articulation range and low friction upper mount needed to keep the rear shocks functioning perfectly over the long term. The CIRC System (Concentric Integrated Remote Canister) substantially increases the gas volume within the shock for more consistent performance over a wide range of temperatures. The CIRC System offers all of the benefits of an external canister shock without the hassle or added weight of mounting an external canister. Both the BOA and CIRC systems are quiet, durable and 100% maintenance free!
Specially Chosen Spring Rates - All of our coilover products use a standard motorsports style spring. The spring rates that are shipped with the coilovers are an excellent choice for both great daily drivability and significantly improved handling. However, if you find yourself drag racing or Road Racing/Autocrossing quite heavily we can customize a spring package to help you get the most out of your coilovers!
Significantly Lighter - We have moved away from a steel housing and moved to lightweight aircraft-grade aluminum housings. You will remove an amazing 10lbs of weight per front coilover compared to stock, and an equally amazing 7lbs per shock in the rear. That's a total weight savings of 34lbs just by a suspension change alone! Not only are the entire assemblies significantly lighter, but because of the inverted shock design it places more of that weight on the sprung side of the vehicle for even greater performance. No other Camaro coilover is lighter.
Stronger - Because of the precision machining, aircraft-grade aluminum construction and hard anodizing of the front and rear coilover housings they are significantly stronger than both factory shocks and our previous generation coilovers. We've done both computer analysis and real world durability testing on the factory housings and found that our new Pfadt housings are significantly stiffer than the factory parts. This large increase in stiffness is just one more way that we improve suspension precision under hard cornering! No other coilover has this combination of strength and rigidity.
Compatibility - We know that not everyone wants to keep their cars completely stock. This goes for the owners of every model Camaro from V6, to SS, and even ZL1 and the eventual 1LE... folks are going to want to get more out of their cars than how they came from the factory. That's why we developed our Camaro Coilovers on our own Pfadt Race Engineering ZL1. By disabling the Magnetic Ride Control System and installing a true performance coilover package everyone with a Camaro, including ZL1 owners, can see the huge performance improvements that a well engineered Coilover package will provide!
Proven Durability - Durability and Quality Control are incredibly important when building a world class suspension package. Use of a shock dyno is absolutely critical to properly dialing in the exact damping rates we are tuning into each coilover. Naturally, before each production coilover is completely assembled it is verified on our shock dyno, so you can be assured that our coilovers are going to perform exactly how we designed them to. The video below are two quick clips taken from our failure testing cycle... We are putting forces into each of these housings that would ONLY ever be seen in a completely catastrophic collision. However, the data we collect with testing like this verifies that what we design on the computer translates into real life design improvements!
Finally we have an example of how our entire coilover package puts it all together during our durability testing on our Damper Destroyer! This is a tool that allows us to simulate thousands of road miles in a very short time frame to verify that our coilovers are going to work great for years to come. In the video is an example of a rear Camaro coilover passing over 500,000 thousand continuous cycles. You can also see how the BOA upper mount is crucial in keeping the entire coilover bind free even with big changes in articulation. Pfadt Coilovers are the only coilovers available with this bind free operation.
There are a lot of reasons to take a look at our Pfadt Race Engineering FeatherLight Camaro Coilovers. Ride height control, performance, durability, and knowing that there is a company with our real world engineering expertise to back our products up. We absolutely love our Camaro coilovers and we know that everyone who ends up with a set will too!
As always you can reach us at either info@pfadtracing.com, via PM here on Camaro5, or on the phone at 1-888-972-2464.
Old 10-16-2012, 06:02 PM   #2
kobSS
kobSS's Avatar
Drives: 2010 2SS/RS
Awesome write up!
Glad to see the coilovers back and all the testing you have put them through. Its always nice to have a beautifully functioning and looking piece.
Mine are being installed right now at the shop - cant wait!
2010 CGM 2SS/RS:
Pfadt'ed Out Level 4, Pfadt Featherlight Coilovers, Pfadt ZL1 Sways, Pedders Radius Rod Inserts, CTS-V Brakes, Borla S-Type, Quad Tips, Forgestar 22" F14's (Show), CAI Intake w/ scoop, Rx Catch-Can, AAC Lighting, Showstopper Sidemarkers
"Information is the oxygen of the modern age"
Build Thread
kobSS is offline   Reply With Quote
Old 10-16-2012, 06:38 PM   #3
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
AWESOME write up and congrats on designing such an outstanding product!! I can tell everyone first hand that these things ROCK!!!! We've been running them now for close to 6 months and have won multiple events in our daily driven 2011 Camaro SS!! I've been nothing but impressed and these are hands down the nicest coilovers in this price range or in a higher price range for that matter!!!
Lap Battle Win 09/15/2012 Miller Motorsports Park East Track
Lap Battle Win 10/06/2012 Miller Motorsports Park West Track
First Production Coilover Install with ZL Spec Sways
The car is composed and with the addition of the ZL Spec sways it is a completely different animal!! After 2 years of testing and trying to find a great combination we finally have and we'll be running for the Championship next year in NASA TT!!!
We've shipped all of our backorders and have more ready to go!!! Please feel free to call, email or PM us anytime with questions! We have the hands on experience to help you choose the right set up for your specific needs!!!
Kind regards,
Jordan Priestley
888.308.6007
JDP Motorsports is offline   Reply With Quote
Old 10-16-2012, 09:44 PM   #4
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
New goodies! Love them. Can't wait to start playing with them.
Old 10-16-2012, 09:56 PM   #5
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
Cant wait to order these!
Whipped416 is offline   Reply With Quote
Old 10-16-2012, 10:18 PM   #6
JDP Motorsports
They completely change the car!! You'll be stoked!!
Kind regards,
Jordan Priestley
888.308.6007
Old 10-16-2012, 10:55 PM   #7
FitterMike
FitterMike's Avatar
Drives: Camaro
Can someone PM me a price on these I am very interested
2012 Camaro 2SS Black
Mods:
Accuair with Airlift Struts, Pfadt Sway bars
Avante Garde F241 20x10 Front 20x11 Rear
Pioneer Stage 4 Sub x2, Pioneer Stage 4 3Way Components, Pioneer PRS 2 Channel ICE Amps x5
Magnuson TVS2300, Pfadt Tri-Y Headers, Roto-Fab Intake
Follow me on Instagram @flawlessdetailsinc
Tuned and Built by Davenport Motorsports.
FitterMike is offline   Reply With Quote
Old 10-16-2012, 11:02 PM   #8
JMAC2011
MONGOOSE
JMAC2011's Avatar
Drives: 2011 SS Camaro M6
Good for your guys. Now I just want the new ones instead of the one's I bought a year ago... Free trade up?
_________________________________
MODS: 470 RWHP / 447 RWTQ
Lethal Racing Night Fury 231/242 113-111, C5R chain, dbl springs, Comp pushrods.
ARH 1-7/8" Headers and complete exhaust - NO cats!
Varraram CAI - Vmax throttle body, ATI 10% underdrive pulley
RPS Street Twin - MGW Shifter
3.91 gears + DSS 1000hp axles
PFADT - Stage 4 Camaro Road Racing Kit - 8" springs 325# and 600# - ZL Spec Sway bars - Strut Tower Brace - Camber plates.
CTSV front calipers - Hawk DTC 30 pads
Street: Forgestar F14 20x9 and 20x11, 275/315 Nitto Invo's, Track: TOYO R888 285/35/20 on 4 corners
JMAC2011 is offline   Reply With Quote
Old 10-17-2012, 06:52 AM   #9
Apex Motorsports
Sent
Old 10-17-2012, 07:05 AM   #10
5thGenCamaroKid
No fat chix, car scrapes.
Drives: 2014 GMC Sierra 1500
Group buy?
5thGenCamaroKid is offline   Reply With Quote
Old 10-17-2012, 09:11 AM   #11
JDP Motorsports
PM sent!
I'm sure you'd be able to sell the units you already have! They are great as well!
Originally Posted by 5thGenCamaroKid View Post
Group buy?
Nice try!
Kind regards,
Jordan Priestley
888.308.6007
Old 10-17-2012, 09:56 AM   #12
5thGenCamaroKid
Originally Posted by JDP Motorsports View Post
PM sent!
Nice try!
Kind regards,
Jordan Priestley
888.308.6007
Oh come on! It's practically your duty, Jordan! PM me a price please.
Old 10-17-2012, 11:14 AM   #13
toehead93
Drives: 2014 2SS/1LE
PM with price please.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 10-17-2012, 12:17 PM   #14
shook sez
Drives: 2015 Ford Fiesta ST hatch
PM with price please. me too.
shook sez is offline   Reply With Quote
coilover, lower, pfadt, racing, suspension
