Caryle Racing
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Forced Induction
Old 10-16-2012, 07:08 PM   #1
audiomikej
audiomikej's Avatar
Drives: the wife crazy talking Camaros
FS 2012 ZL1 Camaro LSA Supercharger, with Heat Exchanger
SOLD!
New 2012 ZL1 Camaro LSA Supercharger,
Includes
Supercharger with Intercooler
Engine beauty cover and mounting studs
Heat Exchanger
Heat Exchanger mounting brackets
Front Intercooler double hose assembly
Supercharger gasket, insulator, and bolts, including supercharger to head bolts
Fuel rail
EVAP solenoid
3 Bar ZR1 MAP sensor
IAT sensor
Barometric pressure sensor
Bypass valve and bypass hoses
Heater hose relocation kit. Including heat shrink to cover hoses for an OE look. (not pictured)
I will double box the Supercharger in instapak foam so everything will arrive safely.
audiomikej is offline   Reply With Quote
Old 10-16-2012, 07:31 PM   #2
BigRed
BigRed's Avatar
Drives: SS RS SIM
Do you have any idea what else is needed for install on a ls3.
BigRed is offline   Reply With Quote
Old 10-16-2012, 08:06 PM   #3
audiomikej
audiomikej's Avatar
Yes I have a detailed list, Budget $2k, plus fuel pump upgrade either BAP or ZL1 pump.
Old 11-11-2012, 01:26 AM   #4
rickv16
Drives: 2010 CGM SS
how bout an L99?
rickv16 is offline   Reply With Quote
Old 11-11-2012, 10:09 PM   #5
audiomikej
audiomikej's Avatar
GM part number 19243525 LSA Front accessory drive kit $900 paceperformance.com
LSA 3 pulley balancer $50 used, $135 new
LSA water pump $100 ebay
LSA/LS9 Fuel injectors $200 ebay
ZL1 Fuel pump $273 ebay
Intercooler Pump $100 ebay
Coolant and vacuum hoses $100 Local auto parts store
Air intake (air filter box) $100-$400
Tune $250-$400, there are companies that will write a tune for you. You can ship your ECM to them or you can buy a flash programmer from them and program yourself.
Auto Camaro (L99) also needs timing cover and timing chain. ~$200
I can give you part numbers and vendors for everything you need.
Old 11-16-2012, 11:50 AM   #6
justindewoody
Drives: 2013 Camaro ZL1
Why did you remove this? Was it from YOUR ZL1? I'm curious about your new setup :-)
2013 Camaro ZL1 Silver Ice #3187 TPW 10/22
1100 Preliminary Order Accepted 9/26/2012
1102 Preliminary Order Added Thru Web 9/26/2012
2000 Accepted by GM 10/01/2012
2500 Preferenced 10/02/2012
3000 Accepted by Production Control 10/02/2012
3100 Available to Sequence 10/11/2012
3300 Scheduled for Production 10/11/2012
3400 Broadcast 10/18/2012
3800 Produced 10/22/2012
4000 Available to Ship 10/23/2012
4150 Original Invoice 10/23/2012
4B00 Bayed 10/23/2012
4200 Shipped 10/26/2012
4800 Rail Ramp Unload 11/02/2012
5000/6000 Delivered 11/05/2012
justindewoody is offline   Reply With Quote
Old 11-19-2012, 05:17 PM   #7
EM1/SS
Drives: 11 2SS/RS M6 vert
How many miles on it? It looks new.
LSA supercharger, Borla S-Type cat back, BMR/ Pedders Suspension, Kooks stepped LT's, GM 3.91, and RDP tune.
EM1/SS is offline   Reply With Quote
Old 11-19-2012, 08:49 PM   #8
audiomikej
audiomikej's Avatar
All parts new, never installed on an engine.
Old 11-25-2012, 01:37 PM   #9
Revo1
Don't Like it? Suggit.
Drives: 2010 2SS/RS
DAMN I wish I had some cash.... :(
Old 12-13-2012, 03:32 PM   #10
mysaab
Drives: Camaro 2SS Sumit White
PMd
mysaab is offline   Reply With Quote
Old 01-04-2013, 01:16 PM   #11
maxxer442
Drives: 2010 IOM 2SS M6
Is this still available?
maxxer442 is offline   Reply With Quote
Old 01-05-2013, 01:58 PM   #12
audiomikej
audiomikej's Avatar
Sold
zl1 lsa supercharger
