Gen5DIY
Old 10-16-2012, 09:08 PM   #1
Murnaneaa
Murnaneaa
Drives: Black 2011 Camaro
Launching Auto v6 Camaro
What is the BEST RPM to launch my Automatic 2011 V6 Camaro from? Also, should I have stability control and Traction Control off or what?
2011 Black Camaro, K & N Cold Air Intake, VMAX Ice-o-Lator, Varamax Ported Throttle body, Ported Intake Manifold, Port-matched heads,SLP Loudmouth 1 Axel-Back Exhaust, Weight Reductions, 3.55 Rear end and Gear swap, Phase Cam, Pace Setter Long tube Headers, Cat deletes, Trifecta tune, RX oil Catch can, 20inch Motegi Racing Rims, Nitto Radials, etc.
Murnaneaa is offline   Reply With Quote
Old 10-16-2012, 09:23 PM   #2
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
TC and SC should be turned off. Launch ~ 2k RPM. Do not do this on public roads.
soloknight6 is offline   Reply With Quote
Old 10-16-2012, 09:30 PM   #3
black12lt
Drives: black 1lt 2012
As stated above, all stability and traction control off.switch to sport mode, use shifters, hold brake while rev to 2k or greater rpm, release brake and enjoy the ride.
black12lt is offline   Reply With Quote
Old 10-16-2012, 09:37 PM   #4
Murnaneaa
Murnaneaa
do your tires spin because mine do.. isn't that losing time?
Old 10-16-2012, 09:39 PM   #5
Elykson
Custom One Off
Elykson's Avatar
Drives: 2010 Chicago Blackhawks Edition #1
Or you could leave everything on, rev at 1500. I've produced a 2.088 60 ft that way.
Vararam Intake/SLP Loud Mouth II/BBK LT HFC/Magnaflow x-pipe/Pfadt Springs/Black Ice-olator/FE3 suspension/VMAX TB/RX catch can/Trifecta Tune
http://www.camaro5.com/forums/showthread.php?t=129416
Elykson is offline   Reply With Quote
Old 10-16-2012, 09:48 PM   #6
Murnaneaa
Murnaneaa
hmmm not to sure if that would work, i will have to try it
Old 10-16-2012, 10:20 PM   #7
usafboy
usafboy's Avatar
Drives: 2010 Silver SS/RS LS3
I think the best time was when the car was launched between 1000-1200 rpm
2010 Silver Ice Metallic Camaro SS/RS LS3
Mods...so far: resonator/muffler delete, tinted everything, '13 shift knob/boot, bowtie delete, PFADT sway bars, CAI intake, Hurst short shifter, JBA cat deletes, BMR trailing arms/outer bushings/steering rack bushing, Bo White ported TB.
Rhino79 Dyno tuned...405 HP/399 TQ
usafboy is offline   Reply With Quote
Old 10-16-2012, 10:21 PM   #8
The Blue Angel
The Blue Angel's Avatar
Drives: 2014 BRM 1SS/RS
Originally Posted by Comrando View Post
Whack the throttle when the light turns green.
What else do you need?
Last time I did that.....I almost got whiplash!!
2014 Blue Ray Metallic 1SS/RS
A Road Warrior
The Blue Angel is offline   Reply With Quote
Old 10-16-2012, 11:39 PM   #9
KMPrenger
KMPrenger's Avatar
There is a member here who produced consistent 2.0 or 2.1 60 foots with his V6 A6 on stock 20" tires by doing the following:
-During staging, turn off TC
-Spin the tires a bit at least enough to clean them off, but putting a little heat in the Pirelli's is even better
- TC back on
-Hold brake, rpms at around 1,000 to 1,200 rpm
-When you launch, release the brake and simutaneously work into the throttle aggressively but maybe not punching it.
Of course.....there are some who say they feel they do better with TC off, launching at a low rpm and rolling into the throttle so very little wheel spin is produced.
Now go practice.....safely!
Old 10-16-2012, 11:52 PM   #10
tonyko1
Banned
Drives: 2012 Camaro 2SS/RS Convertible, IBM
Get a V8.
tonyko1 is offline   Reply With Quote
Old 10-16-2012, 11:59 PM   #11
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
Originally Posted by tonyko1 View Post
Get a V8.
kjkjr27 is offline   Reply With Quote
Old 10-17-2012, 12:00 AM   #12
soloknight6
SoCal HT5! SD
Get a V8.
Get a Zl1 coupe.
Old 10-17-2012, 12:30 AM   #13
1SSFever
Drives: 2012 1SS
Its a V6 auto, so it's sadly only trying to spin one tire. No performance limited slip differential.
With that fact in mind, it will spin easy. At the dragstrip traction is better so you can launch higher.
Rowing through the gears of an SS Camaro always makes for a better day.
1SSFever is offline   Reply With Quote
Old 10-17-2012, 12:33 AM   #14
tjk_art
Drives: 2010
Originally Posted by soloknight6 View Post
Get a Zl1 coupe.
Get a 10 cylinder exotic.
tjk_art is offline   Reply With Quote
