Old 10-17-2012, 07:04 PM   #1
eglincamaro
Drives: 2011 5th gen camaro
rookie question about tune
will driving the car with long tubes installed, without a tune hurt the car?
eglincamaro is offline   Reply With Quote
Old 10-17-2012, 07:14 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
you'll be running rich, but I wouldn't say it'll "hurt" the car
Click to view my build thread
Old 10-19-2012, 02:43 AM   #3
Biscuitpie
Biscuitpie's Avatar
Drives: '11 Cammed LS3, '14 Scion FRS
I have longtubes and an intake and I have a code for running too lean. Is that abnormal then?
SOLD with a Z06 in the not too distant future: Cammed, boltons, axles, lowered, and more. | 476 WHP
Biscuitpie is offline   Reply With Quote
Old 10-19-2012, 08:04 AM   #4
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
It wont per say hurt the car. They are very rich with the factory calibration. You're the rear O2 will throw codes, but it wont kill the car. You just are missing out on additional HP performance because how rich the vehicle is and from the factory the KR is about 5 degrees at 4500 RPMs
Correct
You may have a leak around your MAF area, and your PCM is taking its reading from unmeasured air, Or some intakes say they have to be tuned but in most cases its a small air leak.
www.TampaTuning.com
Phil
Tampa Tuning is offline   Reply With Quote
Old 10-20-2012, 01:52 AM   #5
Biscuitpie
Biscuitpie's Avatar
Correct
www.TampaTuning.com
Phil
Hmm thanks for the insight. I have an aftermarket intake (injen longtube) but I think it says it doesn't need a tune, do you think the MAF just isn't tightened down enough? If I can't tighten more should I put silicone sealant around the outside?
Old 10-22-2012, 01:47 PM   #6
Tampa Tuning
Ive seen guys use silicone around the MAF, but I dont recommend it. Having the screws only in the corners can be a problem, and sometimes a better gasket is needed.
