BeckyD @ James Martin Chevy
Old 10-18-2012, 11:11 AM   #29
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Originally Posted by Jayrcr3 View Post
You add the ZR1 MAP sensor and it tells the ECM when you are in boost which increases the PW to the pump. I have the BAP also.
Originally Posted by MANNYS2SS/RS View Post
I am at 665 rwhp with the ZL-1 fuel pump and the BAP off. Fuel pressure is perfect. I am also glad I installed an access door under the rear seat. If I ever have a problem or want to up grade my fuel pump it will only take 15 minutes.
OMG, I'm sooooooo doing it that way.
Assuming there is not structural weakening.
Old 10-18-2012, 01:23 PM   #30
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
Sorry to confuse you. I have a BAP installed, but to be honest it may be turned off. Mike Norris did the install, and the BAP came with the whipple kit. I know it's in there but I don't know if it's doing anything. He also installed a ZL1 pump at my request. If you would like, shoot me a PM or give him a call. He told me that I have no fuel delivery issues with the setup, which was my concern. He said with my mods I already had, the stock pump would be questionable. It's also my understanding that when you I nstall the zl1 pump and a ZR1 map sensor it increases the pulse width on the pump under boost to increase the volume and pressure. Our cars do this already, but the stock MAP sensor doesn't have the range to allow for boost.
Sent from my HTC One X using Tapatalk 2
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 10-18-2012, 01:52 PM   #31
PQ
Booooosted.
PQ's Avatar
I do have a ZR1 MAP sensor but need to get a ZL1 fuel pump.
So have we figured out wether the ZL1 pump needs to be tuned for?
Old 10-18-2012, 02:41 PM   #32
NWSleeper
NWSleeper's Avatar
Drives: 2010 Camaro 2SS RS
If I read everyones comments correctly, sounds like adding the ZL1 pump can be done as a plug and go with no retune required. If you replace the stock MAP (which the maggie install re-uses) with a ZR1 MAP you would have to retune to take advantage of the new 3bar MAP sensor.
Correct?
By the way, thanks for all of the input. Pieces of this discussion has appeared in other areas but I appreciate the info you guys are providing, especially how well the changes appear to be working.
NWSleeper is offline   Reply With Quote
Old 10-18-2012, 03:27 PM   #33
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
Correct?
You are correct.
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 10-18-2012, 03:37 PM   #34
Jayrcr3
Jayrcr3's Avatar
They do have to adjust the MAP scale in the tune for the ZR1 MAP sensor.
Old 10-18-2012, 04:02 PM   #35
PQ
Booooosted.
PQ's Avatar
Ok. But if mine has already been tuned with the ZR1 MAP sensor I can now just plug and play with a ZL1 pump correct?
Old 10-18-2012, 06:30 PM   #36
ITGuy11
Burning up tires
ITGuy11's Avatar
Drives: 2010 Camaro 1SS/RS
Yep!
Blower, cam, supporting mods 644RWHP 615RWTQ
My Build Thread COTW 11/19/12
Detroit 5th Gen Camaro Club
ITGuy11 is offline   Reply With Quote
Old 10-19-2012, 10:55 AM   #37
LyonsViper27
Drives: 2011 1SS/RS - JRE 415
What did you use to cut the tank access with?
Black '11 SS/RS 1 7/8 Dynatech Stainless Headers, Cold Air Inductions CAI, E-force, JRE Tune - SOLD
LyonsViper27 is offline   Reply With Quote
Old 10-20-2012, 02:59 PM   #38
camarostar2010
Drives: 2011 SS
ok I am lost....since I am not a learned as you gys. So let me : " you are saying with a zl1 map sensor and pump....u can run how much boost in that motor max, ...and with what injectors. Please clarify this for me. again I am not really to keen on it it.
camarostar2010 is offline   Reply With Quote
Old 10-20-2012, 03:23 PM   #39
PQ
Booooosted.
PQ's Avatar
Well I am running a ZR1 (LS9) MAP sensor.
It's a 3 Bar sensor. Meaning it can be tuned for higher boost.
If I'm not mistaken a 'Bar' is 1 atmosphere at sea level. (14psi-ish) So a 3 Bar sensor can be tuned for boost levels two times the barrometric pressure. or up to 28 psi??? (The atmospheric bar or 'Barrometric Pressure' being one bar and the two bars of boost)
I bet I got that totally wrong. LOL
Old 10-20-2012, 08:00 PM   #40
AngelSpeedFreak
Most hated in NM....
AngelSpeedFreak's Avatar
Drives: Sold the 6POINT2, went to a 50THZ06
Thanks so much for the pics Manny.... If I have to do anything else with the pump I am going to cut that hole. It looks so much easier and no one will ever see under the seat or even know its there but you.
Very very nice
AngelSpeedFreak is offline   Reply With Quote
Old 10-20-2012, 08:45 PM   #41
MANNYS2SS/RS
Very very nice
Angel your welcome, if you ever decide Pm me and I will give you messurements and some more Pic's.
Old 10-20-2012, 09:11 PM   #42
partymn
partymn's Avatar
Drives: 2014 1ss 1LE
I dont understand why they wouldnt make an access to the fuel pump from the factory. I never thought about putting in an access, this might have to happen when I change my pump.
2014 1SS 1LE, bone stock for now.
partymn is offline   Reply With Quote
