Old 10-20-2012, 08:15 PM   #43
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Originally Posted by MANNYS2SS/RS View Post
Angel your welcome, if you ever decide Pm me and I will give you messurements and some more Pic's.
I have a ZL1 pump on the way. If you take those measurements I'd vey much be interested. I'll be cutting mine soon.
Old 10-20-2012, 08:19 PM   #44
partymn
partymn's Avatar
Drives: 2014 1ss 1LE
Yes please
2014 1SS 1LE, bone stock for now.
partymn is offline   Reply With Quote
Old 10-20-2012, 08:22 PM   #45
Kronix
NJ/SoCal HT5 COTW 3/25/12
Kronix's Avatar
Drives: 2015 Z06/14 C7/08 Z06/07 Tahoe Z71
Nice move cutting the access door, I dropped my tank to install the ZL1 fuel Pump. It's plug & play and doesn't need to be retuned just fir that addition.
The ZL1 Pump is supposed to be able to handle up to 650RWHP, if not more and so far it's doing it's job. I'm running a ZR1 3 Bar Map, ZL1 Pump, OD Cog Drive, 3.6 pulley, ALKY Meth, Kooks LTs with no cats & SLP Loudmouth II exhaust. So I think the ZL1 pump will fit your needs
Built by Late Model Racecraft
Fastest C7 in Tri-State 10.13 @ 134mph
7/26/14 Corvette Challenge Raceway Park, E-Town, NJ
Kronix is offline   Reply With Quote
Old 10-20-2012, 08:28 PM   #46
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
The hole has to be 7.5" X 7.5" to get the tool in. Take a look at the taped picture you can see the lines where I messured from.
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 10-20-2012, 09:07 PM   #47
PQ
Booooosted.
PQ's Avatar
Good enough. The 7.5"x7.5" is what I needed.
Thank you.
What did you cut it with?
Old 10-20-2012, 09:45 PM   #48
Cpanthers85
Drives: 2011 Camaro 2SS RS
The Eforce uses the 3 bar map, correct? I'm also going to be running a 3.5" pulley with the eforce 60# injectors...
I already have the ZL1 pump in. Hope it's enough...
2011 2SS/RS L99
2013 Cadillac ATS 2.0 AWD Replaced- 2009 Cobalt SS- SOLD!
1979 Z28
Mods: Kooks Long Tube Headers, RotoFaB EForce CAI, American Thunder Catback Exhaust, PFADT Stage 1 Drag Kit + Front Sway Bar, GM Strut Tower Bar. ZL1 Fuel Pump. Nitto NT05R. RX Catch Can.LS9 Cam and Springs.LS3 Conversion.JRE Fuel Rail Upgrade.Edelbrock Eforce.60# Eforce Injectors.Extreme Racing Tune. 523/495
MY BUILD THREAD
Cpanthers85 is offline   Reply With Quote
Old 10-20-2012, 10:55 PM   #49
Nessal
Drives: Exige, Miata, Ghia
Originally Posted by NWSleeper View Post
Do you actually have to drop the tank. Someone said that there is an access panel under the back seat that allows you to access from above without dropping the tank.
Currently I am at 505 WHP and the 52 lb injectors that came with the Maggie. I just ant to get my AFR to the high 11 maabe 12 at WOT.
The engineers at Chevy were not smart enough to do that...
Nessal is offline   Reply With Quote
Old 10-21-2012, 08:12 AM   #50
MANNYS2SS/RS
They are smart... That way you have to go to the dealer and pay for all that labor.
Old 10-21-2012, 08:47 AM   #51
MANNYS2SS/RS
Thank you.
If you think this is for you, when you decide to replace your fuel pump. I recommend having it done by a professional while the tank is out of the way. Their is not to much room between the floor and the fuel tank, fuel lines, and wires. The metal is pretty thin, so you can use any cutting tool. I used a air tool with a cutting wheel. You will only go thru the trouble once, after that anytime you need to replace your fuel pump for what ever reason it will only take minutes.
Old 10-21-2012, 06:52 PM   #52
gwbates3
Ruby & Blu Imp
gwbates3's Avatar
Drives: 2010 LS3 2SSRS M6 & LLT RS A6
Bump...
Ruby
2SSRS M6 - Blown & LLT RS A6
gwbates3 is offline   Reply With Quote
Old 10-23-2012, 11:13 AM   #53
dookie454
Drives: 2010 Camaro 2SS LS3
It actually costs allot of money to add a trap door/access panel to the fuel pump from factory... then you have to worry about it leaking, someone to install/seal the panel up on the assy line... etc. And, based on the failure rate (125-150,000 miles), the dealer would never have to replace a fuel pump under warranty... so... without an access panel GM saves allot of $$.
dookie454 is offline   Reply With Quote
Old 10-23-2012, 12:07 PM   #54
Chris-HPS
Chris-HPS's Avatar
Drives: 2008Corvette
We use the GM ZL1 Fuel pump on all our turbo builds we do. So far we have gone up to 725rwhp with the ZL1 Fuel pump and 80lb. injectors. The duty cycle was 60% on the injectors. No BAP either.
Chris
Chris-HPS is offline   Reply With Quote
Old 10-23-2012, 12:15 PM   #55
PQ
Booooosted.
PQ's Avatar
Chris
Wow. So with only 52# injectors and 9 psi I should be fine then.
Old 10-23-2012, 12:20 PM   #56
Chris-HPS
Chris-HPS's Avatar
I would recommend going up on the injector size. No need in maxing the duty cycle out.
Chris
