Old 10-23-2012, 01:22 PM   #57
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Originally Posted by Chris-HPS View Post
I would recommend going up on the injector size. No need in maxing the duty cycle out.
Chris
You are quite right. And I will but I have no one here that can tune it.
First thing is first though, I gotta get my pressure to stay up. It drops to 48 psi at WOT and at only 7 pounds of boost.
Old 10-23-2012, 01:30 PM   #58
LyonsViper27
Drives: 2011 1SS/RS - JRE 415
Can you read fuel pressure with a scanner on our cars? would save me some money i already have HP tuners and could just use the scanner.
Black '11 SS/RS 1 7/8 Dynatech Stainless Headers, Cold Air Inductions CAI, E-force, JRE Tune - SOLD
LyonsViper27 is offline   Reply With Quote
Old 10-23-2012, 01:40 PM   #59
Chris-HPS
Chris-HPS's Avatar
Drives: 2008Corvette
What type of FI do you have? What fuel pump are you using.
Chris-HPS is offline   Reply With Quote
Old 10-23-2012, 01:46 PM   #60
Chris-HPS
Chris-HPS's Avatar
Yes, Under your PID's there is:
Desired Fuel Pressure
Injector Delta Pressure
Requested Fuel Pressure
Fuel Pump Commanded DC.
Scan all 4 of these and this will give you the info needed for you to tell if your FP is dropping.
Chris
Old 10-23-2012, 02:33 PM   #61
NWSleeper
NWSleeper's Avatar
Drives: 2010 Camaro 2SS RS
I have a ZR1 MAP sensor coming and plan to install once I get the ZL1 pump and perform that install. Can I drive safely to the tuner with the ZR1 MAP and have him perform the tune or do I need to install the sensor at the tuners to avoid driving it without the tables in the ECM corrected?
NWSleeper is offline   Reply With Quote
Old 10-23-2012, 03:13 PM   #62
PQ
Booooosted.
PQ's Avatar
Mine are the stock TVS2300 Magnuson injectors.
Stock fuel pump with a KBB BAP.
I'd just drive it there with the existing sensor. You can swap it out in 5 minutes when you get there.
Old 10-23-2012, 03:33 PM   #63
Chris-HPS
Chris-HPS's Avatar
I would get rid of the bap and switch to the ZL1 fuel pump and upgrade the injectors to 80's.
Chris
Old 10-23-2012, 03:39 PM   #64
PQ
Booooosted.
PQ's Avatar
Chris
ZL1 pump is coming.
Injectors, gonna be a bit. Mainly because I have to find someone to tune them when I swap them.
Old 10-23-2012, 04:11 PM   #65
VanquisherSS
Hasbin of Stock Bottom HP
Drives: CTS-V Coupe, 04 TT Viper
Gonna run a ZL1 Pump with my BAP on my setup. I'm loosing fuel pressure as well.
VanquisherSS is offline   Reply With Quote
Old 10-23-2012, 04:18 PM   #66
nyny69
nyny69's Avatar
Drives: 2010 IOM SS
I'm another that is dropping to 48psi. I found a good deal on the fastlane pump and put that in instead of the zl1. My fuel pressure is still dropping to 48Psi. This is with just the supercharger and bolt-ons
nyny69 is offline   Reply With Quote
Old 10-23-2012, 04:20 PM   #67
PQ
Booooosted.
PQ's Avatar
Really?
Reading from the rail or from the OBD?
Old 10-23-2012, 04:23 PM   #68
nyny69
nyny69's Avatar
Drives: 2010 IOM SS
Really?
Reading from the OBD. I do have the ZR1 map sensor. I was confused also.
Old 10-23-2012, 04:30 PM   #69
Chris-HPS
Chris-HPS's Avatar
What size injectors you running.
Chris
Old 10-23-2012, 04:33 PM   #70
nyny69
nyny69's Avatar
Drives: 2010 IOM SS
Chris
The one's that came with the kit. I think the 63lb. I have no internal mods.
