Old 10-23-2012, 03:40 PM   #71
Chris-HPS
Chris-HPS's Avatar
Drives: 2008Corvette
Originally Posted by nyny69 View Post
The one's that came with the kit. I think the 63lb. I have no internal mods.
When you are dropping pressure are you seeing your duty cycle go up as well?
Chris
Chris-HPS is offline   Reply With Quote
Old 10-23-2012, 03:43 PM   #72
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Hey, Chris, if the injectors are smaller the fuel pressure should stay up even better right?
I mean, I get that they may not stack quick enough for a full fire because of maxing the duty but the pressure should still stay up right?
BTW, How do we measure duty cycle?
Old 10-23-2012, 03:46 PM   #73
nyny69
nyny69's Avatar
Drives: 2010 IOM SS
Chris
I should not be out of injector. The car has less then 550 rwhp. I've tried to find a pid for duty cycle but have had no luck with the sct.
nyny69 is offline   Reply With Quote
Old 10-23-2012, 03:55 PM   #74
nyny69
nyny69's Avatar
Drives: 2010 IOM SS
I've put calls into fastlane for support. I've heard conflicting stories where a value has to be changed in the tune or it's an early vin problem happens to 1 in 100.
Old 10-23-2012, 04:05 PM   #75
Chris-HPS
Chris-HPS's Avatar
Correct, If your injector is to small and fuel pump is large enough/flows enough then your fuel pressure should not drop. In the pids section on HPtuners you can log duty cycle for your injectors.
The max power using a stock pump is around the 550rwhp pump with a supercharger. The supercharger takes some HP as well to make the HP so generally a supercharged car will require more fuel than a turbo for the same hp. I know you said you have a BAP, are you sure it is operating properly under boost?
I noticed in your signature Janetty built the car. Have you called Ted and talked with him about this as well?
Chris
Old 10-23-2012, 04:12 PM   #76
WheelmanSS
Logic is dead
WheelmanSS's Avatar
Drives: 2010 Camaro 2SS/RS
Send a message via AIM to WheelmanSS
I'm at 573 RWHP on stock pump, with no BAP and #66 injectors with the Vortech V3 complete kit with no drop in AFR or FP at WOT.
Just sayin
Granted, I will upgrade my fuel system before adding more power.
2010 Camaro 2SS/RS (LS3)
573 RWHP 498 RWTQ
- Vortech V3 Supercharger
- Kooks Stepped Headers, Magnaflow 16580
- Suspension by Pfadt, Hotchkis.
2007 Trailblazer SS- Sold
2001 Trans Am WS6 431 RWHP 408 RWTQ - Sold
1994 Camaro Z28 - Sold
WheelmanSS is offline   Reply With Quote
Old 10-23-2012, 04:12 PM   #77
nyny69
nyny69's Avatar
Drives: 2010 IOM SS
Chris
Yes the stock pump is good to 550 which was dropping to 48psi. My problem is the fastlane which should be an upgrade even over the zl1 pump is also dropping to 48psi. I have disconnected the bap with the fastlane pump but even connected it was dropping.
I leaving Ted out of this because I purchased from a forum member and it's a pump he doesn't carry.
Fastlane does say it's a plug and play.
Old 10-23-2012, 04:38 PM   #78
Chris-HPS
Chris-HPS's Avatar
Just sayin
That is awesome!
Chris
Old 10-23-2012, 04:40 PM   #79
Chris-HPS
Chris-HPS's Avatar
If your dropping pressure even with a BAP, you have another issue. What is your Voltage doing under WOT. If your voltage is dropping your pump output will follow.
EDIT: to the original poster sorry to hijack the thread.
Chris
Old 10-23-2012, 04:41 PM   #80
PQ
Booooosted.
PQ's Avatar
Just sayin
I wonder if my BAP is not working?
How can I check?
Measuring my fuel pressure from the OBD and WITH the bap it drops to 48psi.
Old 10-23-2012, 04:49 PM   #81
nyny69
nyny69's Avatar
Drives: 2010 IOM SS
Chris
That I will have to check. I'm using the SCT to log so it's trial and error finding the correct pid.
It just doesn't make sense to me.
Old 10-23-2012, 04:57 PM   #82
Chris-HPS
Chris-HPS's Avatar
How can I check?
Unhook your BAP. If you get the same results its not working. Do you have it wired to be on all the time or does it come on with boost?
Chris
Old 10-23-2012, 04:58 PM   #83
Chris-HPS
Chris-HPS's Avatar
I agree, you something going on.
Chris
Old 10-23-2012, 05:06 PM   #84
PQ
Booooosted.
PQ's Avatar
Chris
Mine comes on when the pressure goes possitive.
